gmookher
Old 02-12-2013, 05:04 PM   #295
reeves
Originally Posted by luuser75 View Post
how hard is it to replace the fluids yourself? i'm calling shops and they're charging a good amount for labor since i already have the fluids and washers...
Not hard at all.. it's pretty much like changing your engine oil, except you unscrew two bolts instead of one.. And when you fill the transmission with fluid, you need a funnel & long tube.
You can get a pump instead, but I found the pump to be useless and more messy than it's worth. Just place the funnel at the top of the engine bay, near the firewall, and run the rubber tube down directly to the filler hole of the transmission. There's more than enough access room from the engine bay to the filler hole so that makes it easier too.
This funnel from AdvanceAuto worked for me.. although you might want to find one with a slightly longer tube.. I had to manuver the funnel down through the engine bay a little more because the tube wasn't long enough to reach, but it worked just fine.
Don't let some mechanic who doesn't know or care about your car do this for you.. it's really easy. Better to save your money and take the time/effort to do it yourself correctly. Good luck!
The Following User Says Thank You to reeves For This Useful Post:
luuser75 (02-12-2013)
Old 03-07-2013, 03:32 PM   #296
developer
Drives: BRZ Limited
My Pentosin fix stopped working about a couple of weeks back. The first to second notchy resistance is back. Sometimes I can feel it bump me back several times before it goes into second. I am even getting it every so often going into third. I am at about 4800 miles. The Pentosin fix lasted me about 1700 miles. Oh well, a trip to the dealer soon.
developer is offline   Reply With Quote
Old 03-07-2013, 03:46 PM   #297
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Thats weird. Mines going strong. Whats even more weird is our 2nd BRZ didnt even need the Pentosin fwiw.
Huehuecoyotl is offline   Reply With Quote
Old 03-07-2013, 04:34 PM   #298
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Didn't you get banned?
JesseE is offline   Reply With Quote
The Following User Says Thank You to JesseE For This Useful Post:
developer (03-07-2013)
Old 03-07-2013, 06:09 PM   #299
whiteoutfr-s
whiteoutfr-s's Avatar
Drives: whiteout
mine started to be notchy last week at 450miles im bringin it to the dealer..
whiteoutfr-s is offline   Reply With Quote
Old 03-07-2013, 06:39 PM   #300
fenton
I switched to pentosin a month ago and it might be a little better bit still notches in sometimes.
I don't know if it isn't worth the 120 I paid to get mine here in Canada plus 60 to swap the fluids.
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline   Reply With Quote
Old 03-07-2013, 08:49 PM   #301
sid325
Drives: Ultramarine FR-S 6MT
I'm running Pentosin too. Better, but not perfect. 2nd is still an issue.
sid325 is offline   Reply With Quote
The Following User Says Thank You to sid325 For This Useful Post:
schtebie (03-07-2013)
Old 03-07-2013, 09:14 PM   #302
superpilun
Drives: 1986 MR2
Have any of you guys tried redline mt-85?
superpilun is offline   Reply With Quote
Old 03-07-2013, 11:21 PM   #303
roddy
roddy's Avatar
Drives: '13 Ultramarine
Pentosin is still working great for me. It has got to be close to 10,000 kms (6K miles) since I put it in. I didn't try MT-85, but suspect it would give similar results. I did try MT-90 and it was good until the cold temperatures were below 50F or so.
The Following User Says Thank You to roddy For This Useful Post:
tech4pdx (03-15-2013)
Old 03-09-2013, 02:32 AM   #304
whiteoutfr-s
Drives: whiteout
my friends are telling me thats its normal to have notchy 2nd gear.. told me to ignore it.
Old 03-09-2013, 10:09 AM   #305
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
They're pretty much right as long as the notchiness goes away after it warms up. But Pentosin has definitely made the initial 1-2 shift much smoother in the cold. Can't wait to try it out today when it's 55F out
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Huehuecoyotl (03-09-2013)
Old 03-09-2013, 12:44 PM   #306
Huehuecoyotl
glad it worked!
Old 03-11-2013, 01:01 PM   #307
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Just ordered some Pentosin. Can't wait to give it a shot!
Chimpo is offline   Reply With Quote
Old 03-11-2013, 03:49 PM   #308
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Ordered mine! Just waiting for my car back to change fluids
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 07:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 10:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 12:05 PM
