Old 02-21-2013, 05:45 AM   #15
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Thanks for this thread Mike. Good insight here!
Coheed is offline   Reply With Quote
Old 02-24-2013, 09:10 AM   #16
himbo
Drives: Lightening Red BRZ Ltd.
Bump for awesome thread!
himbo is offline   Reply With Quote
Old 02-24-2013, 10:18 AM   #17
Sargy
Long Distance Driver
Sargy's Avatar
Awesome
Possible to drive up there when the time is right?
Sargy is offline   Reply With Quote
Old 02-24-2013, 11:06 AM   #18
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Subscribed. I thought it would be hard to start another tuning thread and show any insight over what has already been posted by the other guys (hats off to them), but this thread delivers.
Thanks for taking the time and effort to give us yet another well researched, well tested, well described option for tuning. Can't wait to see your final results.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 02-24-2013, 11:13 AM   #19
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by Sargy View Post
Awesome
Give Mike a email or call, he can hook you up.
Definetly worth the drive.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
Sargy (02-24-2013)
Old 02-24-2013, 07:26 PM   #20
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
I am in PA, Let me know if you need another test car Its my second car so Can be up with ya for over a week if needed
Outlawstar98 is offline   Reply With Quote
Old 03-05-2013, 03:30 PM   #21
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The more the merrier!
Testing continues, currently playing with the E70 available. So far so good. Should be back to the dyno in the next week or two if all goes well. Current tune shows the following on the g-meter with e70:
Overall higher and more consistent. After finally getting a BRZ and really putting some miles on it, that dip bugged me even more. Buried in engineering papers the last few weeks I'm pretty confident that it is about as good as we'll get that dip with stock cams/header/intake manifold. It is mostly a cam issue, but tuning does absolutely help.
Below is a torque/HP curve of an MX-5 (2.0l port injection) vs the BRZ (early prototype tune).
Note how they are an inverse of one another. You can't have it everywhere, even with continuously variable dual VVT. Note the FA20 dip is really the up top HP. I'd have to agree subaru/toyota figured you'd be in that range the least. Either getting down low torque putting around town or all out HP on the course or track.
E85 opens up a whole slew of possibilities here. I have it set now that it is map switchable and not needing the sensor; however that route would still be more ideal. Auto-x rules don't permit it for the particular class we're worried about here, not to mention it is rather steep at the moment.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
illmatic (03-05-2013), Sargy (03-13-2013)
Old 03-05-2013, 03:48 PM   #22
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
Mike - do you have a revised tune available? If so, send it my way.
Willie
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 03-05-2013, 04:47 PM   #23
Shit Luck
Drives: red frs
where exactly are you guys located?
I am in york Pa and trying to find a "local" shop to work with for tuning.
Shit Luck is offline   Reply With Quote
Old 03-05-2013, 05:35 PM   #24
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
...so basically OP is saying that all tunes claiming 20whp+ are bullsh*t?
I need to start saving for a turbo. All of this work for a few measly HP is painful to watch.
AM I THE MEANEST?
AM I THE PRETTIEST?
AM I THE BADDEST LOW DOWN MOFO AROUND TOWN?
SHO-NUFF!
ShoNUFF is offline   Reply With Quote
Old 03-05-2013, 05:50 PM   #25
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I don't believe that's the main point of what OP is saying. I think the most important part is that these car's take multiple data logs and reflashes, over an extended time period, to get the most consistency and maximum power.
Even with a turbo, nearly every kit out there requires a license, and practically speaking, a cable. You will still need to data log and update your flash to get the best results.
enjoyminutemaid is offline   Reply With Quote
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
Xero-Limit (03-05-2013)
Old 03-05-2013, 09:39 PM   #26
Xero-Limit
Xero-Limit's Avatar
Exactly...the first time on the dyno it looked like an easy 15+ hp across the board. But with the learning on this car it is difficult to pinpoint exact gains. Between the fine learning and the advance multiplier, the stock car starts off strong, but after a few runs and some miles the power would drop off. Initial testing then proved disappointing when compared to a freshly reset stock tune....just a few hp in the dip and up top. But further testing showed that consistency on the stock tune was terrible, and if you averaged the HP gains on the stock tune car vs the tuned car, the gains were more substantial. With ethanol I was surprised to see that today in 50 deg weather we're pulling the same g's and the car feels just as fast as in 30 deg weather. Stock car it was night and day.
In the dip and up top as you can see in the dyno (vs fresh reset stock tune) we still did good. While the stock tune would falter after a while, the performance of the tuned car would be more consistent.
As to what others do I have no idea and it is not relevant to this thread, but gearing has an effect on dynojet type dynos and you have to compare 4th to 4th 5th to 5th etc....
Having done this in the MX-5 arena for a few years the last thing I want is a customer doing a dyno and finding no gains...but what we see at times is the stock tune works good most of the time, but when you average out runs, or look at sustained performance; the tuned cars are faster.
I wish I could make public the stuff we have on the backend of the EcuTek platform (it would be giving it away...) but the featureset and map switching ability here is unprecedented.
An update for pump gas folks is in the works as well, waiting for the weather to warm up a bit to make sure we make the most of it.
In regards to the turbo/SC options--absolutely, you'll love it. The MX-5 I have is a rocket at 2450lbs and ~350whp at this point. But two different beasts. One spins the wheels at command, the other is a balanced and precise tool that needs little to no maintenance. Both are incredibly fun, but it stinks to be half way through the rev range and lose power. 10 lb/ft down low and 15 hp up top don't seem like much, but given the cost/hp and the additional features it is a bargain.
Located in Easton, PA, but we have dyno availability either out of Easton, Nazareth, and Lansdale, PA. Since so many of the customers are located quite far away, we have done remote dyno sessions via e-mail/skype from AU to EU to CT. As long as the dyno operator has WiFi we can dyno remotely by receiving the logs/plots and sending tunes. Never thought this would be possible even 5 years ago but it works!
Old 03-05-2013, 10:10 PM   #27
Shit Luck
Drives: red frs
ok good to know...
i am almost ready for a tune so i will be looking soon.
Old 03-05-2013, 10:15 PM   #28
AllDayJonRay
Drives: 2013 Ultramarine FR-S
I'm well within driving distance. Currently have just a drop-in filter, and will have a catback on the way in the very near future.. If you would like a donor for some tuning, please PM me. I've got plenty of free time to come visit...
AllDayJonRay is offline   Reply With Quote
CEL Of Death ProTekk Issues | Warranty | Recalls / TSB 41 05-26-2013 11:29 AM
Bored to death, give me some movie names! 82mm 4g63 Off-Topic Lounge [WARNING: NO POLITICS] 36 03-07-2013 03:02 PM
Concorde’s death and our relationship with machiens... dem00n Off-Topic Lounge [WARNING: NO POLITICS] 10 10-26-2012 08:53 AM
Stretching will lead to a firey death frosty86 Off-Topic Lounge [WARNING: NO POLITICS] 6 10-19-2012 03:31 AM
The Future and Potential Death of the Car Hobby. Asterisked Accolade Other Vehicles & General Automotive Discussions 22 09-04-2012 04:18 PM
