Old 03-04-2013, 11:41 PM   #1
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Question Track / AutoX Suspension. Suggestions?
Hey guys. Very new to BRZ, coming from an Acura RSX-S.
I tracked my RSX for the last few years with Progress Coilovers and loved them. However, they don't have a kit for BRZ yet.
So, for the purposes of AutoX and full track use, what are your recommendations?
I don't care about street comfort, I know very little about spring rates, and I'd like to keep it around $1500.
I know i'll probably hear that KW V3 is the way to go, but gawd they are spendy.
I appreciate your help in advance.
Thanks!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 03-05-2013, 12:40 AM   #2
Racecomp Engineering
What kind and what size tire do you plan on running?
- Andrew
Old 03-05-2013, 12:41 AM   #3
Gopherboy6956
Well, I plan on jumping into STX, so probably a 235/40 on 17x8's
Old 03-05-2013, 09:30 AM   #4
If you could stretch your budget a little bit, you could get on the RCE Tarmac II coilover preorder deal. Based on KW clubsports, but with a warranty and a much better price. Focused on track and auto-x performance but still very much streetable.
At the 1500 mark you have a few options. Koni yellows with a good set of springs, some bushings, swaybars, all the toppings, etc., will take you pretty darn far. It's worthwhile to budget the bushings and camber adjustment into your buy...they make a big difference. There may be some coilovers in the future worth buying in that price range if you're patient.
- andrew
Old 03-05-2013, 09:41 AM   #5
Gopherboy6956
So that being said, I have a few questions and statements:
How much are we looking at for the Tarmac II?
What do you mean when you say 'based on kw clubsports'?
I would like to try to avoid doing separate springs/shocks in favor of ready to go coilovers.
Old 03-05-2013, 10:03 AM   #6
I'm not sure I'm allowed to post pricing here so I'll PM you.
They are built by KW in Germany to our specs. The starting point is their KW clubsport line of coilovers, which are a step more aggressive then their KW Variant 3 coilovers. We worked with them to develop our own spring rates and modified valving, and we get a warranty.
- Andrew
Old 03-05-2013, 12:21 PM   #7
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
If your planning on running your car in STX, then take a look at the Ground Control Complete system for your car. This system is complete (to include top mount camber/caster plates, stress bar, custom made and powdercoated front strut housings, rear shock mounts, Koni adjustable dampers Eibach springs, and Ground Control coilover hardware) and custom tailored to you, your driving style, and the environment you will be driving in. Our systems are not just some run of the mill suspension siting on a shelf waiting to ship. We have all components in stock and ready to build a system for you.
All of our products also carry a lifetime warranty.
I know you said you where looking for something around $1500- but if you want to be competitive in STX then you need to take advantage of what you are allowed to use.
GC_Adam is offline   Reply With Quote
Old 03-05-2013, 01:56 PM   #8
Gopherboy6956
Good point. Lots of solid advice here so far. So now it's just price vs benefits...
Old 03-05-2013, 02:35 PM   #9
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Standard KW V3 spring rates are going to be a bit soft for your needs IMO.
GTM_Challenge is offline   Reply With Quote
Old 03-05-2013, 02:50 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Definitely agree here.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-05-2013, 02:54 PM   #11
Gopherboy6956
Ok, thanks for the advice guys. What do you recommend instead?
Old 03-05-2013, 03:17 PM   #12
Turn in Concepts
Turn in Concepts's Avatar
My advice is to do one thing, and one thing only to start.
Get a good performance alignment on it.
THEN go track and autocross it.
Make a list of shortcomings you would like to address, THEN research who can help you fix those issues.
THEN spend some money.
Turn in Concepts is offline   Reply With Quote
Old 03-05-2013, 03:34 PM   #13
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Seconding TiC's comment. There's alot of good stuff about the suspension as-is.
If there's too much body roll, get stiffer springs.
If there's too much oversteer, get stiffer front sway bar.
If there's too much understeer, get stiffer rear sway bar.
If there's not enough grip, get wider tires.
If your tires wear unevenly, get camber plates/LCA's.
If the car is too unstable, get toe and caster links/plates.
If there's too much chassis flex, get strut and chassis braces.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-05-2013, 03:40 PM   #14
Gopherboy6956
Man... and here i was thinking i'd get a bunch of "Suspension X IS DA BOMB" answers.
Lots of good thoughts.
Well, part of my quest for suspension as a starting point is i HATE wheel gap. I know i will have 235/40/17's, i know they will be Dunlop ZII's. I probably track twice a summer, and autox 5 or so times.
So, i guess I'd just like to start somewhere with coilovers and work things out from there.
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
What is your motivation? Why do you track/autox/etc.? What are your motorsport goals? CSG Mike Tracking / Autocross / HPDE / Drifting 22 02-20-2013 09:18 PM
Autox competetive street tire vs. RA-1 (or similar) for track use johhnc479 Tracking / Autocross / HPDE / Drifting 10 02-06-2013 02:49 AM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
