Old 03-04-2013, 11:31 PM   #155
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by NickFRS View Post
Yup! Keep in mind this was at 6k-redline hard shifts.
I drive like that daily
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Plxdjake89 (03-15-2013)
Old 03-05-2013, 12:30 AM   #156
NickFRS
Drives: 2013 Asphalt FRS
After the tune I honestly can't keep my foot out of it... it's just to fun ahahaha
NickFRS is offline   Reply With Quote
Old 03-05-2013, 03:07 AM   #157
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by sierra View Post
46mm dia seems too small considering the size of the throttle body.
I've just measured the stock snorkel intake and it's 60mm at the opening give or take, which is plenty. IMO you want as little to disrupt the airflow as possible so I have blanked off the resonator holes inside the snorkel and capped them at the bottom to reduce any possible heat soak.
I have also capped off the 50mm hole in the airbox and cut a 46mm cardboard blanking plug for the inside of the airbox and used tape to airtight the hole like so:
This means that there is noting to disrupt any airflow from entering the snorkel all the way past the filter. I'm still awaiting a silicone bung to remove the resonator in the intake pipe.
FWIW, I've got airflow results for my setup with the snorkel. I can test some without the snorkel on if some would like to see whether it makes much of a difference? That will stop all the assumptions about how well the snorkel actually does!
.: Stealth 86 :.
Kodename 47 DJ:
NickFRS (03-05-2013)
Old 03-05-2013, 06:04 AM   #158
sierra
Drives: Skoda Yeti DSG diesel 4x4
Sorry. I read the 46mm as being the ID of the snorkel inlet.
60mm is much better but still 15% smaller in area than the 65mm throttle body. So a 15% restriction to the potential of the throttle body.
sierra is offline   Reply With Quote
Old 03-05-2013, 06:44 AM   #159
Kodename47
Kodename47's Avatar
Drives: UK GT86
Right, I've got some definitive numbers for you. Some interesting figures though. My setup is a K&N filter & AVO pipe for reference.
Full intake system, ambient temperature 4*C:
Max MAF - 144.0g/s
IATs - 4-15*C
Snorkel removed, ambient 8*C:
Max MAF - 140.27g/s
IATs - 22-34*C
I actually saw temps of up to 44*C on the IAT pre-logs when connected via ECUTek. Sounded great but the car could not handle the high IATs and started bogging really badly!
One conclusion, removing the snorkel has made no difference except made the intake incredibly prone to heat soak. I'll run some further tests once I return the snorkel with all resonators removed.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 7 Users Say Thank You to Kodename47 For This Useful Post:
200hp/tonne (06-02-2013), ddevl_86 (03-31-2021), EAGLE5 (03-19-2013), LeeMaster (03-08-2013), Sargy (03-05-2013), sinigang_guy (03-09-2013), Vegas Racing (06-14-2013)
Old 03-05-2013, 07:01 AM   #160
vtmike
vtmike's Avatar
Drives: Scion FR-S
Did you get data logs with the stock intake system to see if there was any change in a/f ratio after the intake install. It's my understanding the car stock runs rich which most factory cars do anyway.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 03-05-2013, 09:38 AM   #161
Sargy
Long Distance Driver
Sargy's Avatar
Max MAF - 144.0g/s
IATs - 4-15*C
Max MAF - 140.27g/s
IATs - 22-34*C
keeps us posted for the last data with resonators removed. Great info!
Sargy is offline   Reply With Quote
Old 03-05-2013, 09:38 PM   #162
NickFRS
Max MAF - 144.0g/s
IATs - 4-15*C
Max MAF - 140.27g/s
IATs - 22-34*C
What about with all resonators deleted? Not necessarily the snorkel deleted. Thats what im interested in! But this is very cool!!!
Old 03-05-2013, 10:18 PM   #163
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
this is my car, a true cold air home made intake. it extends off the stock snorkel and i felt a bigger gain with that, then with a drop in. this is a honda thing though lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-05-2013, 11:06 PM   #164
Turdinator
Señor Member
Turdinator's Avatar
Any other pics of this setup? I imagine it would be a really cost-effective CAI
1974 TA22 Celica
2013 86 GT
Old 03-05-2013, 11:36 PM   #165
NickFRS
Ahhhh yea suck in all that water!!!!
Old 03-06-2013, 03:02 AM   #166
Kodename47
Kodename47's Avatar
Drives: UK GT86
I refitted everything yesterday. I might get a run out in the car later or tomorrow morning so I'll get some more data for ya.
With OBD readers (ECUtek, Torque, Rev etc) people can start getting data rather than speculating and actually test things. Following my results yesterday I'm going to test how bad the heat soak on an injen is on a mate's car.
Grip Ronin, do you have access to any of the above and what's the rest of your intake setup?
.: Stealth 86 :.
Kodename 47 DJ:
NickFRS (03-06-2013)
Old 03-06-2013, 03:58 AM   #167
NickFRS
thank you!!!!!
Old 03-06-2013, 09:51 AM   #168
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i dont have anymore pics. its just 2 elbows and a pipe.
hyrdo lock is a fear but id have to submerge the entire intake opening underwater for that. id just open the air box in the engine bay before that lol. ive had this setup for months no problems yet
the rest of my setup is stock. with no dyno runs
IG-Joey_Soul
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
