Old 03-04-2013, 09:48 PM   #141
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by vtmike View Post
It's secure. The resonator has some play in it when attached to the box so no loss in rigidity.
Also after having the resonator off and getting some more seat time in the induction noise is louder at about 2500-3000 rpms when the engine is under load. Not much difference in sound at other rpms.
Sent from my Nexus 7 using Tapatalk HD
After my BRZedit custom dyno tune you can hear a noticed difference from 3k-redline.
NickFRS is offline   Reply With Quote
Old 03-04-2013, 10:09 PM   #142
NickFRS
Also something to consider is the throttle body/after MAF is a bottle neck. there isn't really any reason to get an intake thats huge and not alter the throttle body. You wont see any real gains. My whole reason to delete the resonators is to get more sound from the intake, which i accomplished. Also the car seems to be extremely responsive and smooth after the tune. Don't really see the need for a CAI. I even try to convince someone to let me swap the CAI on the car and go get it retuned to see if there are any true gains with the drop in filter w/silicone inlet tube w/resonators deleted vs the CAI. But this is a maybe due to the fact it will cost me $200 bucks unless I can find a shop to do it for free purely for the community.
Old 03-04-2013, 10:22 PM   #143
Turdinator
Señor Member
Turdinator's Avatar
From all reports the throttle body on our FA20 is huge for a 2lt engine. The manifold may present a bottleneck but i doubt the throttle body is.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
NickFRS (03-04-2013)
Old 03-04-2013, 10:23 PM   #144
vtmike
vtmike's Avatar
Drives: Scion FR-S
The stock throttle body is over sized and not a restriction. Most say there is no need to upgrade it.
I still think there are gains to be had in a good cai. Perrin said the gains they saw on their panel filter were actually more to do with changing the air/fuel ratio than air flow. Their cai still made more power than the drop in filter while running closer to stock a/f ratio.
vtmike is offline   Reply With Quote
The Following User Says Thank You to vtmike For This Useful Post:
Old 03-04-2013, 10:29 PM   #145
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Originally Posted by sierra View Post
Do you have yours with those 2 ports open for extra airflow?
If so have you noticed any gains at the top end?
I haven't removed the resonators on the snorkel yet, just all the others. I can't really say on the top end gains, I installed the Nameless Performance cat less front pipe, axle back, and a K&N filter at pretty much the same time, so I'm feeling some pretty big gains on the butt dyno.
Cade01 is offline   Reply With Quote
Old 03-04-2013, 10:29 PM   #146
sierra
Drives: Skoda Yeti DSG diesel 4x4
You guys beat me to it!!!:happy0180:
The throttle body internal diameter is 65mm which is exactly twice the cross sectional area of the 46mm internal dia of the stock cold air intake.
This snorkel is looking like a must fix item.
sierra is offline   Reply With Quote
Old 03-04-2013, 10:33 PM   #147
NickFRS
I have a hard time believing this because my car was running extremely rich even with the silicone inlet tube and drop in filter before my tune. I mean clouds of black smoke rich.
Old 03-04-2013, 10:35 PM   #148
NickFRS
In this case i'm feeling a need of moding before my car goes back on the dyno this week! Good to know. Thanks for the info folks. :happy0180:
Old 03-04-2013, 10:39 PM   #149
sierra
The drop in filter and silicone inlet tube must have altered the speed of the air through the MAF sensor and caused the ECU to supply more fuel than was actually required.
Old 03-04-2013, 10:39 PM   #150
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'm not saying it was running lean but more lean than the stock filter according to perrin. They seem very thorough and transparent in their testing.
Sent from my Galaxy Nexus using Tapatalk 2
Old 03-04-2013, 10:44 PM   #151
NickFRS
"Testing" is very hard to put data back to back. Unless the dyno pulls were in the same temp on the same dyno on the same day. Simply changing the temperature of air changes how much air is needed or how the car reacts. This also can change the amount of power the car makes. Unless they do back to back testing with parts I don't exactly trust data. Also it would be better if they used percentages then actual HP readings. I made a post about this and they ignored me lol
Old 03-04-2013, 10:47 PM   #152
vtmike
vtmike's Avatar
Drives: Scion FR-S
Their methods seem pretty legit to me.
Old 03-04-2013, 11:11 PM   #153
Turdinator
Señor Member
Turdinator's Avatar
Interesting. I have a Perrin foam filter and their silicon intake due to me this week. I will have to watch for this. Did you reset the ECU after install?
1974 TA22 Celica
2013 86 GT
Old 03-04-2013, 11:28 PM   #154
NickFRS
Yup! Keep in mind this was at 6k-redline hard shifts.
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
