Old 02-26-2013, 01:56 PM   #43
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by chanomatik View Post
18x8 +48 Gold Wheels option?! Horsepucky!
or silver
Those look like the wheels from the XT Line Concept.
The Following User Says Thank You to switchlanez For This Useful Post:
chanomatik (02-26-2013)
Old 02-26-2013, 02:15 PM   #44
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Originally Posted by switchlanez View Post
I think I gotta have this:
@Beyer Subaru, I was never familiar with how the US antenna base/pedestal compares to JDM. I guess you've been able to see that the US base is larger? I'm also curious to see if that OEM sharkfin will be a direct fit for us. Was there an ETA for its release?
Also, got any idea if these are a direct plugin for USDM models?
Yep, I like the BRZ door decal alot. I think it would really pop on your car. I feel as though I've seen the decals in other world markets as well but I can't remember where.
Yep, I dismantled the OEM BRZ antenna to see what all was goin on inside. It's a pretty big circuit board and associated electrics vs the very simple Legacy antenna. This is because the Legacy uses an antenna wire in the rear windshield and throughout the actual body of the car.
The JDM BRZ antenna is the same size as the USDM FR-S antenna. I seriously doubt that the JDM BRZ fin will be plug-n-play. But it is being offered for most of the new models, so it is a possibility?
I was unable to find any form of release date. We will need Yuki or one of our JDM contacts to investigate to see when it will be released. I would assume it will be available in the second quarter of 2013CY.
I don't know of any USDM, JDM or other antenna that will be plug and play with our ginormous antenna. I think that a Mfr would need to make a antenna base to fit all of the OEM guts into, to get it p-n-p.
The subs should be plug-n-play. Should be. But I can't say for sure. Even if they aren't it shouldn't be to hard to get the right harness swapped onto it. It would be very different (easier) than an antenna.
Yep, they look to be the same Speedline Corse wheels as the Xt Concept. Speedline wheels have been associated with Subaru for a long time in Europe. Some of the old Prodrive branded wheels were rebadged Speedlines.
Beyer Subaru is offline   Reply With Quote
The Following 2 Users Say Thank You to Beyer Subaru For This Useful Post:
chanomatik (02-26-2013), switchlanez (02-26-2013)
Old 02-26-2013, 02:58 PM   #45
KSC
KSC's Avatar
Drives: Ion Redline
Originally Posted by DSOmegaX View Post
These pieces are already released or to be released for the current car...STI is no different than TRD or the M division for BMW. They regularly release parts for the "base" cars as accessories.
I really hope the actual STI car doesn't use the bits from this catalog just to makes these items more unique.
Ah, gotcha. My bad, I was never really a Scooby guy. My friend just linked me pics to STI Foresters and Legacys. I had no clue the moniker ever extended past the WRX.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 02-26-2013, 03:21 PM   #46
DSOmegaX
DSOmegaX's Avatar
Yeh don't worry about it. The problem is that STI rarely releases parts for any other car except the Impreza in the US, which is why people here just associate the STI moniker with the Impreza. There's no plans to release the STI catalog for the BRZ here.
@dsomegax.cars
Old 02-26-2013, 06:00 PM   #47
Skurj
Drives: SOLD...
Lotsa nice stuff... must save the nickels...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Last edited by Skurj; 02-26-2013 at 06:00 PM. Reason: pennies no longer available..
Skurj is offline   Reply With Quote
The Following 2 Users Say Thank You to Skurj For This Useful Post:
Beyer Subaru (02-26-2013), chanomatik (02-27-2013)
Old 02-26-2013, 06:42 PM   #48
Beyer Subaru
Yep, I'm trying to figure out what organs I don't reeelly need.
The Following User Says Thank You to Beyer Subaru For This Useful Post:
Old 03-04-2013, 11:14 AM   #49
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Short shifter is a bit interesting.
Old 03-04-2013, 12:51 PM   #50
Hanakuso
I need that floor carpet in my life.
Too bad they aren't compatible with LHD cars
Originally Posted by Beyer Subaru View Post
Yep. They look kinda like a cross between Karoism/ASM/Monster Sport and ZeroSports floor mats.
The ASM Karoism IMO looks much better and the checkers are very subtle.
Hanakuso is offline   Reply With Quote
The Following 2 Users Say Thank You to Hanakuso For This Useful Post:
Beyer Subaru (03-04-2013), chanomatik (03-04-2013)
Old 03-04-2013, 12:55 PM   #51
Beyer Subaru
Yep, if they'd bring a LHD version, I'd sign up.
Old 03-04-2013, 12:58 PM   #52
RoryTate
Drives: 2013 Subaru BRZ
Can someone educate me as to the use of a "flexible tower bar"? I always believed that you wanted zero flex, hence a solid bar between the strut towers.
RoryTate is offline   Reply With Quote
Old 03-04-2013, 01:26 PM   #53
Beyer Subaru
Per the STi site - translated - Strut tower bar put the ball split the tower bar link aluminum. For dodging a moderate external pressure, such as the gap of the road to effectively use the bending of the chassis, without compromising ride comfort, when cornering is hold on tight, we achieve improved handling to the limit from the range commonly used initial steering.
Basically it will make the ride more stiff but not to the point of teeth shattering. The bar connects the strut towers but not as rigidly as a comparable bar.
Old 03-04-2013, 01:28 PM   #54
RoryTate
Cool, thanks. Learn something new everyday. I think I like the idea of a magnetorheological damper better.
Old 03-04-2013, 01:33 PM   #55
Hanakuso
You talking about the ASM Karoism or the JDM Subaru mats? I've spoken to ASM about the Karoism mats in LHD, they would need the stock ones we have, then they would design one and then ship both back. BTW, they are very expensive. Very high quality but expensive.
Old 03-04-2013, 01:59 PM   #56
Beyer Subaru
Any of them would suit my fancy. I'm reaching out all over the freaking world right now to get some kind of floor mat solution. I'm just so sick of looking at the USDM mats.
I'd be interested in what you are proposing. It would just come down to overall cost of part/shipping.
brz forum, brz forums, subaru brz, subaru brz forum, subaru brz forums
WTS 2013 SWP Subaru BRZ Limited MT jrodz09 Cars for Sale/Trade 18 03-04-2013 04:11 PM
2013 Subaru BRZ Spotlight video by Subaru switchlanez BRZ Photos, Videos, Wallpapers, Gallery Forum 0 09-25-2012 01:47 PM
Media: 2013 Subaru BRZ Ko6pa90 BRZ Photos, Videos, Wallpapers, Gallery Forum 25 04-20-2012 10:01 AM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
