Old 02-25-2013, 07:37 PM   #1
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
New Subaru BRZ Accessory Catalogs for 2013
FT86CLUB Homepage Featured Story
http://www.subaru.jp/accessory/catal...3newoption.pdf
The big ones are:
Racing Stripe Decals
Shark Fin Antenna - Prolly won't be applicable to US harness
Carbon Look Key Fob Cover
Rear Seat Privacy Cover
Floor Mats - RHD only
http://www.subaru.jp/accessory/catal...Navi-Audio.pdf
New Subwoofers with enclosures - More info as follows from the October Press Release - http://sonic-design.co.jp/news/pdf/t..._renew2012.pdf
October 30, 2012 press release Sonic design company
Sonic special design, "SUBARU BRZ"
Orders from Co. FHI speaker enclosures integrated set Jua
(2-6-18 Minami-cho, Chuo-ku, Chiba City, Chiba Prefecture, President: Takashi Sato Mamoru) Sonic Design, Inc. This time, the speaker set is integrated enclosures Jua dedicated sports car "SUBARU BRZ" of FR layout horizontally opposed engine received an order from the Corporation Fuji Heavy Industries.
In addition, the "R-grade *" and "S" grade of "SUBARU BRZ" This set of speakers that can be mounted as a dealer option, FHI 4 "speaker set, manufactured by Sonic Design" from the Corporation "(Part No.: H6317CA300) sold under the name of. Please visit the official Web site SUBARU http://www.subaru.jp/ the product information.
* "Optional speaker harness" when attached to the "R" grade of this product is: is required separately (Part No. H6317CA900). I can not attach it to "RA grade" this product.
Enclosures with integrated speaker set only Jua "SUBARU BRZ"
(: "4 speaker set manufactured by Sonic Design", Part Number Product Name: H6317CA300)
* The image is a prototype. There is a part of the specification and appearance may differ slightly from the actual.
Summary-only speaker set "SUBARU BRZ"
Speaker-only set "SUBARU BRZ" was an order, is a speaker set high quality for make you feel the pleasure and enjoyment that everyone manipulate the car, sports car "SUBARU BRZ" of engine FR layout horizontally opposed this. By adoption of the door woofer module integrated enclosures Jua was built in the speaker unit to the cabinet high rigidity aluminum structure hybrid, while delivering high quality sound no turbidity with reduced resonance and other interior materials, a quiet residential area and wait for signal also reduces sound leakage to the outside of the vehicle to be worried about in the run, such as *. Of course, it has become a big attraction of this product is also a good sound bite by utilizing suitable for excellent handling performance, ultra-low center of gravity due to packaging "SUBARU BRZ", the characteristics of compact, high-performance 77mm speaker.
Corresponds to the attachment to "R grade" and "S" grade speakers dedicated set of "SUBARU BRZ" This requires unbundled "speaker harness" is attached to the "R" grade. Also front four speakers When installed in a "S" grade of this product is 6 If you want the speaker system + rear (this product) 2 speakers (standard equipment) front four speakers were mounted on the "R" grade this product ( It is 4 speaker system only). In addition, I can not attach it to "RA grade" this product.
* I am not a function completely prevent sound leakage. Please enjoy the appropriate volume for safety. In "S grade" Also, sound leakage from the rear speakers (standard equipment) will not be reduced.
Press Information
The main features speaker-only set "SUBARU BRZ"
Specially designed for each model that does not impair the value of the vehicle is also simple and reliable mounting 1.
Because they are designed to use the coupler wiring conversion speaker and the attached mounting hole speakers genuine, can be mounted in the bolt and the coupler on, it is not necessary to perform such processing and routing drilling to the vehicle, impair the value of the vehicle no.
By pursuing further action precision 2., Relaxed sound quality at high density.
Woofer Unit 77mm micro speaker technology adoption
The unique micro speaker technology to achieve both play wide range of unique sound that breaks sharpness and small diameter, the limit of small caliber, relaxed sound quality at high density. We are seeking to reproduce the true face of such difficult music with a sense of dynamic bass with less treble, a clear ambiguity in natural, traditional in the car speakers.
Microfiber diaphragm was adopted to ensure the unity of tone 3. Woofer.
High-performance dome tweeter smoothly extends high frequency reproduction
Diaphragm dome tweeter employs a high-performance microfiber with a unified tone and woofer unit. Together, you can enjoy the high region play no habit that extends smoothly with narrow gap motor system of its own.
Easily achieve the ideal of 4 Play. Car audio enclosures in the door Jua
Jua hybrid aluminum enclosures designed high rigidity and low resonance
Die-cast aluminum baffle and ultra precision casting equivalent to the "Premium Line" series our thoroughly suppress unwanted resonance in a two-piece structure heterogeneous material tightly bound back chamber and special plastic (case back). Achieved with structure and clear sound enclosures in the door that are ideal Jua of car audio playback and less sound leakage to the outside of the vehicle *.
Contact us about this matter
Sonic Design, Inc.:
Telephone 043-209-1777, e-mail info@sonic-design.co.jp
It looks as though the Subs are available now but again I would need a JDM contact to give me confirmation. http://yahoo.aleado.com/lot?auctionID=h170331048
Page for all models - http://www.subaru.jp/accessory/catalog/index.html
STi Accessory site has been updated with the new Trailing Link Set - http://www.sti.jp/parts/catalogue/brz_zc6/2.html.
Beyer Subaru is offline   Reply With Quote
The Following 14 Users Say Thank You to Beyer Subaru For This Useful Post:
chanomatik (02-25-2013), fjcruiser (03-05-2013), Fly Guy (03-04-2013), Giccin (03-04-2013), kwood9000 (03-04-2013), lazyluka (03-04-2013), mackeye (02-25-2013), MannyO (03-04-2013), Ricepuddin (03-04-2013), switchlanez (02-25-2013), TRD_07 (03-04-2013), Turbowned (02-26-2013), Zaku (02-25-2013), zoomzoomers (03-06-2013)
Old 02-25-2013, 07:39 PM   #2
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I need that floor carpet in my life.
Old 02-25-2013, 07:49 PM   #3
Beyer Subaru
Yep. They look kinda like a cross between Karoism/ASM/Monster Sport and ZeroSports floor mats.
Old 02-25-2013, 07:53 PM   #4
ayau
Drives: Some rust bucket
Everything looks meh except for the carpet lol.
Old 02-25-2013, 07:56 PM   #5
Beyer Subaru
Yeah, most of it is pretty meh. The biggy for me is the shark fin. It would be pretty kick-butt if it was plug-n-play.
Old 02-25-2013, 08:00 PM   #6
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Like that Carbon key FOB
These available for purchase.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
The Following User Says Thank You to Zgrinch For This Useful Post:
DriftEightSix (03-06-2013)
Old 02-25-2013, 08:33 PM   #7
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I second the key fob, but do not like the blue lettering. SPT exhaust looks nice too but will probably cost upwards 1500 or so. Short throw shifter anyone?
Old 02-25-2013, 09:10 PM   #8
Beyer Subaru
Nope. Prolly a few weeks or months out.
Old 02-25-2013, 09:13 PM   #9
Beyer Subaru
It's an STi Exhaust and it is currently 1,572 and about 200 in shipping.
SPT is SOA's murrican aftermarket arm.
Old 02-25-2013, 10:19 PM   #10
chandz05
chandz05's Avatar
Drives: CBS BRZ limited MT
I really like the spoiler gurney and the STi front lip. Probably really expensive though :/
chandz05 is offline   Reply With Quote
Old 02-25-2013, 10:29 PM   #11
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
is... that like a " we know you like spoiler, so we put another spoiler on top of your spoiler and it will cost you" At least it matches the rest of the car I guess, I'm not a fan of racing stripes because to me it just screams Mustang and I really like it on just the mustang. But this BRZ in this brochure seems to pull it off well.
Old 02-25-2013, 10:41 PM   #12
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
MUST HAVE THEM ALL!
Marcoscrdo is offline   Reply With Quote
Old 02-25-2013, 10:54 PM   #13
Buggy51
Drives: Put Put
Whatever happened to the arm rest -_-
Buggy51 is offline   Reply With Quote
Old 02-25-2013, 11:08 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Beyer Subaru View Post
Rear Seat Cover/Delete?
It's actually called "Privacy Cover", so when you go track to bring some tires & other stuff, you can hide from outside... so no one will think about robbin' the car
The Following 7 Users Say Thank You to ichitaka05 For This Useful Post:
Beyer Subaru (02-26-2013), chanomatik (02-26-2013), ericmpena (01-12-2014), Fly Guy (03-04-2013), LeeMaster (03-04-2013), MannyO (03-04-2013), Roadliner (03-05-2013)
brz forum, brz forums, subaru brz, subaru brz forum, subaru brz forums
WTS 2013 SWP Subaru BRZ Limited MT jrodz09 Cars for Sale/Trade 18 03-04-2013 04:11 PM
2013 Subaru BRZ Spotlight video by Subaru switchlanez BRZ Photos, Videos, Wallpapers, Gallery Forum 0 09-25-2012 01:47 PM
Media: 2013 Subaru BRZ Ko6pa90 BRZ Photos, Videos, Wallpapers, Gallery Forum 25 04-20-2012 10:01 AM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
