Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 03-03-2013, 10:40 PM   #57
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any chance of a full red-out (red lense) version of these taillights being made available?
Like these below:
Old 03-03-2013, 10:56 PM   #58
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Thanks for posting Tim.
I don't think they're planning on other versions of tail lamps.
Doboy might red out his himself.
When his come in we'll try to take pics of the back.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
Old 03-03-2013, 10:58 PM   #59
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Chris...do I have a tracking number yet?
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 03-03-2013, 11:09 PM   #60
PhastekSport
All tracking numbers go to the tracking department. I don't have access to their emails. They don't work on the weekends so they don't transfer the tracking numbers to the orders during that period.
I can check tomorrow morning.
Old 03-04-2013, 09:38 AM   #61
PhastekSport
Video added:
[ame="http://www.youtube.com/watch?v=vC6l7qLC3bY"]PhastekPerformance.com - Spyder LED Tail Lights for the Scion FR-S and Subaru BRZ (Demo Video) - YouTube[/ame]
Old 03-04-2013, 10:59 AM   #62
Asphalt~86
Drives: Asphalt AT
Just called and finished my order! Can't wait!
Asphalt~86 is offline   Reply With Quote
Old 03-04-2013, 01:22 PM   #63
PhastekSport
Zgrinch - says that your scheduled delivery date is Thurs. Enjoy!
Old 03-04-2013, 08:49 PM   #64
Zgrinch
Zgrinch's Avatar
I cannot wait! Pics will be coming shortly.
Thanks for staying on top of it Chris.
BRZGrincherhood
Old 03-04-2013, 08:49 PM   #65
Zgrinch
Zgrinch's Avatar
Which way did you go--smoked?
BRZGrincherhood
Old 03-04-2013, 09:16 PM   #66
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
Def interested... Anyway someone can make a DIY video or thread on the install?? Also what is the warranty like on these things?
ThaBigUnit is offline   Reply With Quote
Old 03-04-2013, 09:24 PM   #67
Asphalt~86
Drives: Asphalt AT
It's really just plug and play. When I get mine if no one has done it yet I'll throw one up.
Old 03-04-2013, 09:34 PM   #68
PhastekSport
Warranty is one year one these.
Old 03-04-2013, 09:34 PM   #69
Zgrinch
Zgrinch's Avatar
Got this from another thread
Originally Posted by DarrenDriven View Post
First, pop your trunk and find the single plastic rivet on each side. A small flat-tipped screwdriver will allow you to pop the center out about 1/4".
Once the center of the rivet has been popped out, you can slide the entire rivet out of the hole.
Fold the carpet back to reveal the area behind the tail light.
Using a small tool (like a pick, or even a nail) you can lift the plastic catch inside of the zip tie.
With the catch lifted, you can pull the zip tie loose from the wiring bundle.
Then unscrew the zip tie assembly from the stud and set it aside.
Almost ready, just need to unplug the tail light. Push the tab in while you pull the plug out.
Now you can remove the four 10mm nuts. It's easiest with a deep 10mm socket, but even with an adjustable crescent wrench it is pretty easy. Now you can pull the lamp assembly off of the car.
Then just reverse the process to install and you should be good to go...
BRZGrincherhood
Old 03-06-2013, 10:12 AM   #70
PhastekSport
You can see the lights for a second here...
[ame="http://www.youtube.com/watch?v=Xpx2G5CEphg"]Toyota 86 Vortech Supercharged Launch Control - YouTube[/ame]
Thanks for the orders. They have all been processed up to this morning.
lights, sema, spyder, tail light, tails
Spyder Tail Lights for FR-S & BRZ DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 113 04-21-2019 05:16 PM
DIY: Black Housing Tail Lights sw20kosh DIY (Do-It-Yourself) Guides 151 11-21-2016 04:08 PM
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
