Old 01-30-2013, 09:35 PM   #1
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive
Hey guys,
Today I installed the new Perrin Engine Mounts and a Cusco Catch Can on the shop car, just thought I'd share a brief review.
Perrin Mounts
Stock Mount
Comparison
Perrin Mount Installed
The install was worry free, no issues to report. The stock mounts are a little tricky to get out because they have a stud in them that slides through the frame held in by a nut vs the Perrin mounts that use a bolt that goes into the mount. I would highly recommend having them put in on a lift, I had to jack the motor up pretty far to get the mounts out.
The good news is, I think the NVH (Noise, Vibrations, Harness) are very low. I am very pleased with the fact that car doesn't have a harsh idle at all. I was concerned that putting mounts in would make the car vibrate and rattle but thus far, its very tame!
I will say this, if you're on the fence about mounts because you don't want to ruin the way the car feels, I highly recommend these mounts, I was honestly shocked at how small a difference the initial test yielded.
Now I just need some driving time to the see how they are in action!
I got the Cusco catch can because I like the fact that it comes with a mounting bracket and puts it up out of the way of the rest of the engine. The hose routing that Cusco recommends is WRONG! There is a certain way that I recommend routing your catch can to retain factory parameters while making it actually functional, along with adding some baffling to the can. I also painted it black to retain the factory style vs bling bling chrome.
Thanks for reading!
We sell everything we review! PM for details!
Pure Automotive is offline   Reply With Quote
The Following 8 Users Say Thank You to Pure Automotive For This Useful Post:
Anthonytpt (01-30-2013), Antihero983 (05-05-2016), Bonburner (01-31-2013), JPxM0Dz (03-07-2013), M1K3 (01-31-2013), reeves (03-05-2013), TRD_07 (03-04-2013), UncleFester (03-04-2013)
Old 01-31-2013, 08:13 AM   #2
M1K3
M1K3's Avatar
Drives: vrooom...
Cool!!! I'm glad to hear NVH increase is minimal. I just ordered these mounts and I appreciate the review.
M1K3 is offline   Reply With Quote
Old 01-31-2013, 09:11 AM   #3
Pete
Pete's Avatar
Drives: 22 BRZ
Yep, I'm waiting on them now, thanks.
Pete is offline   Reply With Quote
Old 03-04-2013, 12:51 AM   #4
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
can be done with 4 jack stands and a jack
about 3" of lift does the trick, right?
however, I have a little NVH at idle, mainly a low freq vibe, but I also have the whiteline tranny insert
Huehuecoyotl is offline   Reply With Quote
Old 03-04-2013, 07:18 AM   #5
Pure Automotive
If you're comfortable laying under a car on jack stands and then jacking the engine up, then yes probably, but I wouldn't recommend it. The NVH you have is probably the Whiteline bushing.
Old 03-04-2013, 09:12 AM   #6
Huehuecoyotl
I'm betting you have ready access to a lift? LUCKY!
I dont, so , I often have all four on stands, so yeah, its something you get comfy with after double checking and triple checking each stand! Scary, yeah a little, but I do the wobble test and she's fine. Theres always a 5th stand under the front end and I toss ramps under the rear wheels, 'just in case'
Yeah, I just wanted to put that out that the NVH is likely even more noted in setups where you have WL x-member, tranny mount and, Perrin Motor mounts, there s little lumpy-ness that can be felt ONLY at idle, and more "driveline-awareness"(in a good way) but raising revs takes it right away. If youre running a tune, simply ask the tuner to raise your revs to mid 800s. Definitely feels better when thrashing it, hard.
Old 03-04-2013, 09:15 AM   #7
Pure Automotive
Yeah, I just wanted to put that out that the NVH is likely even more noted in setups where you have WL x-member, tranny mount and, Perrin Motor mounts, there s little lumpy-ness that can be felt at idle, but raising revs takes it right away. If youre running a tune, simply ask the tuner to raise your revs to mid 800s. Definitely feels better when trashing it, hard.
I own a shop and I am an Ecutek dealer
Old 03-04-2013, 09:43 AM   #8
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Thank you for routing the catch can hoses correctly! Black looks good too!
Old 03-04-2013, 10:58 AM   #9
Huehuecoyotl
so you didnt have to touch the OE idle settings to get rid of any lumpy-ness? just my setup?
Old 03-04-2013, 04:17 PM   #10
Pure Automotive
I don't really get any nvh at idle, I was rather surprised when I did the install
Old 03-05-2013, 04:15 PM   #11
reeves
If your car is on the dyno again, is it possible to get video of the engine bay? I saw my engine jerk quite a bit while it was on the dyno with stock mounts, so I'd be interested to see how much less the engine moves with the Perrin mounts. TIA!
Old 03-06-2013, 11:18 AM   #12
Pure Automotive
Yea, next time I'm on I'll take an engine bay shot.
Old 03-06-2013, 11:34 AM   #13
Huehuecoyotl
Motor mounts Feel tight, I like it, thank you Jeff Perrin!
Old 03-06-2013, 12:25 PM   #14
Pure Automotive
I felt like throttle response improved a little as well.
Cusco catch can install diagram wbradley DIY (Do-It-Yourself) Guides 52 03-02-2016 12:01 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
Cusco catch can install wbradley Engine, Exhaust, Transmission 2 01-11-2013 12:11 AM
