Old 03-02-2013, 05:45 PM   #99
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Originally Posted by sevi21 View Post
Where did you buy them from and for how much if you dont mind me asking?
I have a set of 530s for the summer and i was thinking about buying stainless
ones to replace the plastic ones i have.
http://item.mobileweb.ebay.com/viewi...d=290865374534
SMOKETREES is offline   Reply With Quote
Old 03-02-2013, 08:07 PM   #100
NJA
Drives: Supercharged Saturn ION
Diggin the setups guys
NJA is offline   Reply With Quote
Old 03-02-2013, 09:51 PM   #101
yohan04
yohan04's Avatar
Drives: Your sister
18 x 9.5, +33 RPF1
F. 255/35
R. 265/35
yohan04 is offline   Reply With Quote
Old 03-02-2013, 10:24 PM   #102
HATED1
HATED1's Avatar
Drives: 86
anymore pics? looks good so far!
HATED1 is offline   Reply With Quote
Old 03-02-2013, 11:49 PM   #103
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
Originally Posted by yohan04 View Post
18 x 9.5, +33 RPF1
F. 255/35
R. 265/35
Nice ! Post more pics please, always cheering on the MID A guys to have the best set up LOL
Old 03-03-2013, 05:19 AM   #104
dobbrz
Drives: RB v1 FRS
Originally Posted by Beyer Subaru View Post
Ummm. No. This set-up is form over function.
Negative camber is a function. = negative camber improves grip when cornering. This is because it places the tire at a better angle to the road, transmitting the forces through the vertical plane of the tire rather than through a shear force across it. Another reason for negative camber is that a rubber tire tends to roll on itself while cornering. The inside edge of the contact patch would begin to lift off of the ground if the tire had zero camber, reducing the area of the contact patch. This effect is compensated for by applying negative camber, maximizing the contact patch area. Note that this is only true for the outside tire during the turn; the inside tire would benefit most from positive camber.
He likes form over function. You don't need to set-up any fr-s, 86 or BRZ to these specs to go out and drift.
Negative camber is the only way anyone could fit a 10" and 10.5" under the factory sheet metal. 6" of negative camber with offsets at +12 and +17 isn't functional for daily driving.
He is crazy low. These cars start life crazy low from the factory. That's kinda the point. We have a lower center of gravity than a Ferrari. All you need to do is get springs and voila, you are even more crazy low and entering supercar territory. He is only a couple inches off the ground. The only way to go lower would be bags and scraping.
This kinda helps prove the point -
Don't get me wrong. I love his set-up, appreciate the skill and craftsmanship that went into it. If I had silky smooth JDM roads to ride on daily I would consider a set-up this agro.
My current set-up:
Even he knows that it's not a functional set-up and is in the process of having a wide fender kit put on. He had the fronts on at the messe.
what I was trying to say was that in this case he isn't losing the ability to do what he wants to do with his car just because it is slammed and cambered out...I know what people use it for and I understand what you are saying but I am just pointing out that its not like hes hard parking his car...because it works functionally and it looks good imo as well. Which is where I was coming from with the function + form comment...not trying to start a fight or an argument because I'm not an expert by any means..just sayin..he looks like he kills it with this setup so you can't really say there is no function to it..
and these cars don't really come out crazy low from the factory..lol yes the center of gravity is amazing but in terms of ride height and clearance it seems pretty average to me...Maybe I am used to slammed cars and when I looked at mine at stock height it was an eye sore...
dobbrz is offline   Reply With Quote
Old 03-03-2013, 10:20 AM   #105
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I guess I can kinda see where your coming from a lil bit. I am of the firm belief that how a car is set-up is one or the other. Form over Function or Function over Form. Will the car still drive either way? Yes. So regardless of which one you choose-the car still "functions".
No argument here brother. Just differing opinions. You see it one way, I see it another.
If I feel like I can elaborate on a subject to get "my" point across, I will. No worries.
And yes, our cars do look like monster trucks to all of us from the factory. But that doesn't change the fact that they are crazy low to begin with.
Beyer Subaru is offline   Reply With Quote
Old 03-03-2013, 05:04 PM   #106
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
18x8.5 +42/+30
215/40
gloomy2 by jszumita, on Flickr
gloomy by jszumita, on Flickr
close-up by jszumita, on Flickr
Jesse is offline   Reply With Quote
Old 03-03-2013, 07:47 PM   #107
yohan04
yohan04's Avatar
Drives: Your sister
Thanks! My car is far from the best or most aggressive -- it's not low as most others here, but I only had the car for 2 month and hasn't been dialed in yet.
Old 03-03-2013, 07:49 PM   #108
636
636's Avatar
Drives: '23 CWP BRZ
I've got 18x9.5 +35 on order. I'm on BC Racing Extreme Drop Coilovers maxed out. So we'll see how it is!
636 is offline   Reply With Quote
Old 03-03-2013, 08:30 PM   #109
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Tire specs you going with?
Old 03-04-2013, 06:37 PM   #110
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Originally Posted by SMOKETREES View Post
XXR 527 18x8.75 35mm all round with dunlop direzza dz101 225/40/18 all round also. Thinking of 5mm spacers in rear tho....
Attachment 29555
Attachment 29556
Attachment 29557
Attachment 29558
I love your wheels and setup...clean and stealthy.
MightyMeeple is offline   Reply With Quote
Old 03-04-2013, 08:36 PM   #111
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Originally Posted by doricar View Post
Not sure if you would call them agressive but these wheels are my current favorite wheel for a normal body car
Specs on thos TWS wheels
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 03-06-2013, 01:00 PM   #112
Beyer Subaru
Per engrishy translation - The image has been mounted on T-66F 18 インチ
http://www.ft86club.com/forums/showthread.php?t=13054
http://www.tws-forged.com/new/entry_000326.html
http://www.tws-forged.com/gallery0/toyoya_index.html
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
