Old 03-01-2013, 05:18 PM   #85
ebphoto
Drives: FR-S, NA8, S13
Originally Posted by KSC View Post
This is gonna come off like trolling, but I'm not, seriously, I'm just old and have trouble understanding such things...
What's going on here, exactly? Are the treads of these wheels not fully touching the road or are the fenders making it look that way? Is this at all functional for driving, or do I just cruise up and down city streets @ 20mph looki...okay, I'm getting trolly now. Sorry!
ebphoto is offline   Reply With Quote
Old 03-01-2013, 08:36 PM   #86
blags
Drives: Toyota 86
18x9.5 +20
18x10 +22
On order... Keep your eye peeled
blags is offline   Reply With Quote
Old 03-01-2013, 09:29 PM   #87
dobbrz
Drives: RB v1 FRS
Originally Posted by Beyer Subaru View Post
This is a form over function mentality. This would not be a street set-up. This wouldn't even be a "proper" track set-up. But apparently they do drift with the car. You can see more of the car here. http://www.ft86club.com/forums/showthread.php?t=24694
This would be hella flush, poke, tuck, stance, blah, blah, blah, etc... I'm a big fan of these cars "look" but I could never go this crazy with my car as it is a DD.
It is form + function if anything...Negative camber isn't just a "form" adjustment...in this case it helps him do what he likes to do with his car...which apparently is be super dope and slide everywhere..and negative camber also helps him fit the wheels he wants so it looks good to his liking..I don't see a problem daily driving that either..its not THAT crazy low or anything...
dobbrz is offline   Reply With Quote
Old 03-01-2013, 09:32 PM   #88
dobbrz
Drives: RB v1 FRS
Originally Posted by NemeGuero View Post
This thread started off well and then progressed to "not really aggressive but..."
No fender mods = not aggresive
people with frs/gt86/brz tend to think that they are ruining the car if they put aggressive wheels on it and lower it.....I have people begging me not to lower my car more because they think it will ruin the car...fools..they also think the only purpose of camber is to make room in your fenders..
Old 03-01-2013, 10:22 PM   #89
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
Originally Posted by NemesisPrime909 View Post
If you don't mind me asking, how does the ride differ from the standard 17's?
I really can't tell the difference, i changed my wheels 2 weeks after car purchase. definitely more grip, as far as weight. the "sluggishness" is very unnoticeable.
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
Old 03-02-2013, 05:25 AM   #90
doricar
Drives: AE86
Not sure if you would call them agressive but these wheels are my current favorite wheel for a normal body car
Check out my FR-S, 86 & BRZ tuning page on Facebook
doricar is offline   Reply With Quote
Old 03-02-2013, 08:44 AM   #91
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Ummm. No. This set-up is form over function.
Negative camber is a function. = negative camber improves grip when cornering. This is because it places the tire at a better angle to the road, transmitting the forces through the vertical plane of the tire rather than through a shear force across it. Another reason for negative camber is that a rubber tire tends to roll on itself while cornering. The inside edge of the contact patch would begin to lift off of the ground if the tire had zero camber, reducing the area of the contact patch. This effect is compensated for by applying negative camber, maximizing the contact patch area. Note that this is only true for the outside tire during the turn; the inside tire would benefit most from positive camber.
He likes form over function. You don't need to set-up any fr-s, 86 or BRZ to these specs to go out and drift.
Negative camber is the only way anyone could fit a 10" and 10.5" under the factory sheet metal. 6" of negative camber with offsets at +12 and +17 isn't functional for daily driving.
He is crazy low. These cars start life crazy low from the factory. That's kinda the point. We have a lower center of gravity than a Ferrari. All you need to do is get springs and voila, you are even more crazy low and entering supercar territory. He is only a couple inches off the ground. The only way to go lower would be bags and scraping.
This kinda helps prove the point -
Originally Posted by RRnold View Post
Don't get me wrong. I love his set-up, appreciate the skill and craftsmanship that went into it. If I had silky smooth JDM roads to ride on daily I would consider a set-up this agro.
My current set-up:
Even he knows that it's not a functional set-up and is in the process of having a wide fender kit put on. He had the fronts on at the messe.
And he wasn't sporting 6" of negative camber with the new fenders on.
Beyer Subaru is offline   Reply With Quote
Old 03-02-2013, 01:06 PM   #92
philstar
philstar's Avatar
Drives: Argento FR-S
Those fenders are not Rocket Bunny, They are called Todorokki I believe and will be available soon. Definitely my favorite 86!
philstar is offline   Reply With Quote
Old 03-02-2013, 01:30 PM   #93
Beyer Subaru
Thanks. I must have still been thinking about their hot lava 86 that's rocking the RB kit.
Old 03-02-2013, 03:47 PM   #94
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Those fenders are sex for sure. And do help support nasty wide rims =)
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 03-02-2013, 04:33 PM   #95
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
XXR 527 18x8.75 35mm all round with dunlop direzza dz101 225/40/18 all round also. Thinking of 5mm spacers in rear tho....
SMOKETREES is offline   Reply With Quote
Old 03-02-2013, 05:11 PM   #96
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
@SMOKETREES Hey are you using plastic or metal hub rings?
Instagram @admsevi
Old 03-02-2013, 05:33 PM   #97
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Plastic cause I'm waiting till mine come in the mail which are stainless
Old 03-02-2013, 05:38 PM   #98
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Where did you buy them from and for how much if you dont mind me asking?
I have a set of 530s for the summer and i was thinking about buying stainless
ones to replace the plastic ones i have.
Instagram @admsevi
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
