Old 03-01-2013, 09:09 PM   #407
terrypm
First86 & burning gas!!
terrypm's Avatar
Drives: Asphalt 2013 Scion FR-S
I have a question for everyone who is using one of Nigel's harnesses. How did you wire it up?
1.There are both a black and red wire coming out of the relay. What did you wire these up to?
2. There is both a black and red wire coming from the on/off switch harness? What did you wire these up to?
Thanks
terrypm is offline   Reply With Quote
Old 03-01-2013, 09:38 PM   #408
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Thanks
I'm waiting on mine to come from him. I assume from the relay, red goes to battery positive, black grounds to anything metal on the frame of the car. The switch should also be black to any ground and red i guess to any 12v source? Maybe the cigarette lighter or something? Is there another wire to connect to the side markers? Definitely need some clarification on this as well
abutterman is offline   Reply With Quote
Old 03-01-2013, 10:07 PM   #409
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
still waiting on my harness. should have went with ebay or amazon.
anyone running l.e.d bulbs?
Old 03-01-2013, 11:28 PM   #410
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Originally Posted by emutcfut View Post
Got these on order at the Subbie dealer. Not sure if Toyo has these.
Tapping screw: 904510053
J nut: 902510037
Kinda expensive at a dollar a piece.
Is the J nut plastic or steel for this part??
b$m1th91 is offline   Reply With Quote
Old 03-02-2013, 12:09 AM   #411
Snowblind
It's metal if I'm not mistaken.
Old 03-02-2013, 05:48 AM   #412
b$m1th91
b$m1th91's Avatar
If that's the case, i'll just go to homedepot or autozone. I might try and use a license plate mounting kit because those usually have plastic bolts and the bumper is plastic. I have the bezels and lights as well and just put in an order for the harness from nigel. I plan on running it along the driver side and putting the button beside the trunk button. I also found that the fuse box under the dash already has FL Fog and FR Fog so i will probably tie into that. Anyone know if Nigel's harness already has fuses in the harness???
Old 03-02-2013, 05:51 AM   #413
b$m1th91
b$m1th91's Avatar
Originally Posted by DarrenDriven View Post
A Ferrari is always a nice background car to show off this one:happy0180:
Old 03-02-2013, 06:01 AM   #414
b$m1th91
b$m1th91's Avatar
Thanks
The red and black coming out of the relay are for the relay itself. The red needs to be hooked up to the battery with a fuse in between, and the black is the ground for the relay. Put this on another ground in the car(non-painted surface). The switch is the same, red goes to battery(with a fuse between it) and the black grounds wherever there is a good connection.
The Following User Says Thank You to b$m1th91 For This Useful Post:
terrypm (03-02-2013)
Old 03-02-2013, 06:58 AM   #415
terrypm
terrypm's Avatar
I was confused because others, along with the DIY video, were saying you need to tap into the side marker for the fog lights to work.
Nigel's harness comes with a fuse included on the harness off the red wire from the relay but there is no fuse on the red wire from the switch.
Old 03-02-2013, 09:28 AM   #416
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
yes there is no fuse from the switch. i tap the red wire from the switch to my ignition key to make the switch work, so i can turn it on the fogs anytime i want without turning my headlights on. some they tap it on parking lights. its a personal preference.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-02-2013, 10:27 AM   #417
abutterman
abutterman's Avatar
so the red wire from the switch could just go to the side marker and if needed add some extra wire to make it long enough to go in through the firewall to wherever you want the switch?
Old 03-02-2013, 01:48 PM   #418
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
so my bezels came in yesterday, but i wasnt home so they left a notice for "redelivery". does any1 know if i need to fill that out or if they will just try again on the next business day?
lbroskee is offline   Reply With Quote
Old 03-02-2013, 01:55 PM   #419
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
same thing happened to me. i don't know if they redeliver, but this morning i went and picked it up from the post office with that slip they left.
mezdup is offline   Reply With Quote
The Following User Says Thank You to mezdup For This Useful Post:
lbroskee (03-02-2013)
Old 03-02-2013, 02:00 PM   #420
lbroskee
lbroskee's Avatar
ok, thanx. ill have to try that monday (stupid sundays off )
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 05:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
