Old 03-01-2013, 07:22 PM   #1
xwd
Stock ride height numbers?
Anyone measure the stock ride height from a flat surface to the fender or tire to fender lip? I know there are differences car to car just looking for something ballpark.
Old 03-01-2013, 08:06 PM   #2
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I probably do at work, I can look on Monday.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 03-01-2013, 08:36 PM   #3
SVThis
SVThis's Avatar
Drives: Scion FRS
Just went out in the garage and measured for you. The measurement is from the center of the wheel to the fender lip.
Front 14 5/8 inches
Rear 14 1/2 inches
Will vary somewhat depending on amount of gas in the tank and build spec tolerances. The measurement was for the drivers side. I was too lazy to do the passengers.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-03-2013, 01:28 AM   #4
xwd
Front 14 5/8 inches
Rear 14 1/2 inches
That's a little odd since generally the rear is slightly higher than the front from other info I've seen, generally about 1/4". The gas in the tank shouldn't really be enough to cause the springs to appreciably lower.
Old 03-03-2013, 05:48 AM   #5
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
With a driver (and passenger) it may level out a bit more...just a thought...?
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 03-03-2013, 07:43 AM   #6
SVThis
SVThis's Avatar
Drives: Scion FRS
Maybe I measured wrong. Never said I was accurate.
Old 03-03-2013, 08:50 AM   #7
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Mine was 26 3/8" front & 26 5/8" rear on pass side. They were just slightly higher on driver's side (to compensate for driver?).
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-03-2013, 11:26 AM   #8
DarkSunrise
DarkSunrise's Avatar
Ground to top of wheel arch.
F: 26 and 1/4"
R: 26 and 1/2"
L/R sides were dead even.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
FeRS (03-09-2022), smg1138 (08-30-2016)
Old 03-03-2013, 11:55 AM   #9
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
I came in at:
F: 26 1/2 in
R: 26 5/8 in
L/R were the same.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
GotM is offline   Reply With Quote
Old 03-03-2013, 12:29 PM   #10
SVThis
SVThis's Avatar
Drives: Scion FRS
It's better to measure from the center of the wheel. Air pressures of the tire and tire diameter do not come into play. That being said it isn't going to make that much difference.
The Following User Says Thank You to SVThis For This Useful Post:
Hostile_Kittens (08-31-2016)
Old 03-03-2013, 01:41 PM   #11
xwd
Yeah I was about to say the same thing, middle of hub to fender is better. Given how close guys are though it probably doesn't make much difference.
Old 03-03-2013, 03:40 PM   #12
Eric1855
Drives: LP DSP / CSP '13 BRZ
Floor to fender lip on mine before lowering was 26.5" on front and 27" rear. That is with properly inflated oem tires and wheels.
I lowered them both to 25" and I think it looks pretty good, not too low.
Eric1855 is offline   Reply With Quote
Old 08-30-2016, 06:10 PM   #13
aquaman
aquaman's Avatar
Has anyone measuerd to the bottom of the chasis? I've alreay lowered mine and I have aftermarket fenders...
aquaman is offline   Reply With Quote
Old 08-30-2016, 10:57 PM   #14
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
F: 26 and 1/4"
R: 26 and 1/2"
Winner, winner, chicken dinner! These are the correct specs.
A lot of you guys were probably measuring on an uneven surface if you weren't close to these numbers.
smg1138 is offline   Reply With Quote
Stock height + Aftermarket wheels compilation!!!! eddieEndo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 244 03-25-2019 01:32 AM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
