View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler
WITH Oil Cooler Spirited Street Driving < 195 F 12 8.28%
WITH Oil Cooler Spirited Street Driving 195-215 F 9 6.21%
WITH Oil Cooler Spirited Street Driving 215-230 F 11 7.59%
WITH Oil Cooler Spirited Street Driving 230-245 F 3 2.07%
WITH Oil Cooler Spirited Street Driving 245-260 F 0 0%
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) 0 0%
With Oil Cooler Tracked 195-215 F 5 3.45%
With Oil Cooler Tracked 215-230 F 4 2.76%
With Oil Cooler Tracked 230-245 F 7 4.83%
With Oil Cooler Tracked 245-260 F 6 4.14%
With Oil Cooler Tracked 260-280 F 2 1.38%
With Oil Cooler Tracked 280 + F 0 0%
W/O Oil Cooler Spirited Street Driving < 195 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 195-215 F 6 4.14%
W/O Oil Cooler Spirited Street Driving 215-230 F 30 20.69%
W/O Oil Cooler Spirited Street Driving 230-245 F 16 11.03%
W/O Oil Cooler Spirited Street Driving 245-260 F 11 7.59%
W/O Oil Cooler Spirited Street Driving 260-280 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 280 + F 0 0%
W/O Oil Cooler Tracked 215-230 F 0 0%
W/O Oil Cooler Tracked 230-245 F 2 1.38%
W/O Oil Cooler Tracked 245-260 F 8 5.52%
W/O Oil Cooler Tracked 260-280 F 24 16.55%
W/O Oil Cooler Tracked 280-290 F 5 3.45%
W/O Oil Cooler Tracked 290 + F 4 2.76%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
Old 02-27-2013, 11:06 PM   #15
brillo
Drives: 2013 Firestorm FR-S
I've been monitoring the oil temps through my Scan gauge and driving home in stop and go with keeping it under 4,000rpm my temps top out at 212f. Where does the ECU read the temp? I assume that's coming out of the engine?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-27-2013, 11:09 PM   #16
The Slow One
Track Junkie
Drives: Argento Scion FR-S
There's a oil temp sensor right by the oil filter.
The Slow One is offline   Reply With Quote
Old 02-27-2013, 11:40 PM   #17
Xdragonxb0i
Drives: ex500r
I'm really sorry, while I was writting the post I was going to add it but forgot. It was 72 F. Will update first post.
Can you make another record as well in 80-90 degree weather. This assuming it warms up before you get your turbo
Xdragonxb0i is offline   Reply With Quote
Old 02-27-2013, 11:44 PM   #18
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
so basically this is pointless for us down here if it's jus a N/A DD?
lbroskee is offline   Reply With Quote
Old 02-27-2013, 11:44 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Definitely IMO.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-27-2013, 11:45 PM   #20
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I'm installing sc in coming weeks, and will gladly try and capture same stuff, before and after oil & IC temps; logging using ECUTek which uses the factory sensor
Huehuecoyotl is offline   Reply With Quote
Old 02-27-2013, 11:53 PM   #21
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by polancd View Post
I Am goining to have to keep an eye on this. I was planning to do the same kind of testing in the future, but also comparing the temps i get from different locations (ie: sandwich plates, oil galley) to the stock sensor. Anyway, Thanks for doing this. Curious to see what your daily drivng temp was?
It was 72 F. I updated the first post.
I definitely will if we get a hot day soon.
Agree with Dave and you.
On the street at 90+ you'd probably see lower temps assuming you are cruising because of air flow. I normally drive around 80mph or so on the highway and it's cooler than when I'm cruising at 45mph. I need to get torque (main thing holding that up is the lack of an android device, although a friend has an old droid that might work) to read a value from the OEM location for good comparison.
Robi saw 290-295 on track (not 100% sure on where that was read from). I saw 230-235 on track in 87 degree weather reading it under the filter. On the street in the same location in regular driving I never see more than 175-180, if I beat on it I can get close to 200.
When I said I would see higher oil temps, I meant doing the same test I did today but ambient temp. at 90+.
When I install the temp gauge to the oil galley I will do comparisons to the OEM sensor.
Thanks for sharing your numbers!
Sent from my HTC One X using Tapatalk 2
Old 02-28-2013, 12:32 AM   #22
Sportsguy83
Drives: Limited BRZ
290 is WOW...
Your numbers are prior to oil cooler or after?
Old 02-28-2013, 01:13 AM   #23
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Thanks for the results, I was actually going to try this myself once raining season gets here.
Well, not if you plan on fleeing from the popo. lol jk jk dont do it.
LeeMaster is offline   Reply With Quote
Old 02-28-2013, 01:25 AM   #24
ft_sjo
Drives: GT86
Why do you think an unloaded engine tells you anything about oil temperature?
Old 02-28-2013, 01:47 AM   #25
Sportsguy83
Drives: Limited BRZ
Care to elaborate?
Old 02-28-2013, 02:09 AM   #26
Sportsguy83
Drives: Limited BRZ
Originally Posted by LeeMaster View Post
I think he was trying to say that an oil cooler is worthless on a daily driven car that is not constantly being abused like a dedicated track car.
If that's the case,
#1) He has not been reading the forum in which vendors are saying an oil cooler is ABSOLUTELY necessary even for a DD (thus why independently test it myself on harsher conditions).
#2) He didn't read my first post to see what type of tests I did.
Old 02-28-2013, 02:17 AM   #27
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
It would be interesting to see data of NA with oil cooler.
jacjac3 is offline   Reply With Quote
Old 02-28-2013, 02:20 AM   #28
Sportsguy83
Drives: Limited BRZ
@jacjac3 Look at Dave-ROR's numbers, they are with oil cooler:
oil cooler
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 05:02 PM
