View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler
WITH Oil Cooler Spirited Street Driving < 195 F 12 8.28%
WITH Oil Cooler Spirited Street Driving 195-215 F 9 6.21%
WITH Oil Cooler Spirited Street Driving 215-230 F 11 7.59%
WITH Oil Cooler Spirited Street Driving 230-245 F 3 2.07%
WITH Oil Cooler Spirited Street Driving 245-260 F 0 0%
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) 0 0%
With Oil Cooler Tracked 195-215 F 5 3.45%
With Oil Cooler Tracked 215-230 F 4 2.76%
With Oil Cooler Tracked 230-245 F 7 4.83%
With Oil Cooler Tracked 245-260 F 6 4.14%
With Oil Cooler Tracked 260-280 F 2 1.38%
With Oil Cooler Tracked 280 + F 0 0%
W/O Oil Cooler Spirited Street Driving < 195 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 195-215 F 6 4.14%
W/O Oil Cooler Spirited Street Driving 215-230 F 30 20.69%
W/O Oil Cooler Spirited Street Driving 230-245 F 16 11.03%
W/O Oil Cooler Spirited Street Driving 245-260 F 11 7.59%
W/O Oil Cooler Spirited Street Driving 260-280 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 280 + F 0 0%
W/O Oil Cooler Tracked 215-230 F 0 0%
W/O Oil Cooler Tracked 230-245 F 2 1.38%
W/O Oil Cooler Tracked 245-260 F 8 5.52%
W/O Oil Cooler Tracked 260-280 F 24 16.55%
W/O Oil Cooler Tracked 280-290 F 5 3.45%
W/O Oil Cooler Tracked 290 + F 4 2.76%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
Old 02-27-2013, 08:46 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Oil cooler needed? Don't know? See some results inside
GEM (a.k.a) @Huehuecoyotl had the great idea of adding a poll. PLEASE vote once for each Track/ Spiritred Driving situation and read carefully WITH Oil Cooler and WITHOUT Oil Cooler Options. Once you vote you can't vote anymore so choose wisely. You can vote for more than one option if you have logged temps while spirited driving AND track driving. After voting, please post your experience in the thread.
Thanks to all!
BIG Disclaimer: This should not be taken as the end be all of information regarding Oil Cooler Need. This is just a SIMPLE test done by me trying to get where we stand regarding oil temperatures on different driving conditions. Much more test and numbers are needed to determine for real and definitive who does or doesn't need one. I will keep the OP updated as more numbers come in.
So I started today logging Oil temperatures in hopes of finally deciding if the Oil Cooler is REALLY NEEDED or not. (As a minor parenthesis, the coolant temperature stayed steady like a champ, between 190-206 F)
My car is in N/A form right now and will be Turbo in a couple of months, so today I started some testing in hopes of finding the truth. Ambient Temperature was 72 F for N/A test.
N/A results:
I simulated two different scenarios and here they are:
1) Flogging it on the street, pretty HARD, spirited type of driving. Starting hard from a stop and flooring it through fourth gear. Tried it several times, one after the other. I could NOT get the Oil Temperature to rise above 223 F . I tried it on a highway and on a three lane main street (only through second on the main street), and i just COULD NOT get it over 223 F. At this point I was getting pissed off thinking the Oil Temp PID had a cap of 223.8 F to be exact. So next up...
2) Simulating track condition, since I was going nowhere I went to the extreme. I put it in second and kept the Revs over 6K for about two minutes. Now that is what I was expecting to see. Temperature rose steadily until 252 F. I hit a traffic stop and did the same thing now in first. Temperature stayed in the 245-252 F range. I kept doing this for about 8 minutes and had the same result.
Later on: WITH TURBO
3) Flogging it on the street.
4) Simulating track conditions.
So as you can see, this is not perfect or the end of it, but its a good starting point. Even better would be doing a track day with temp. logging (most probably someone has already done it). I'm sure with more time at 6-7K RPMs you will get the temperature to rise above 252 F. As it stands, 252 F is not really a MAJOR concerns, just something to keep an eye for.
So IMHO (a.k.a take with a grain of salt), if you are staying N/A with bolt ons AND you don't plan on tracking the car more than 2-3 times a year, you DONT need an oil cooler.
If you plan on doing track days at 1+ a month, I suggest to get an oil cooler, BUT more actual track data is needed to make the final decision.
Turbo results and conclusions to come.
Edit: Actual track temperature information WITHOUT Oil Cooler
@robispec saw 290-295 F on the track, reading from the same location as the OBD2 sensor, 76 F ambient temp.
@nzer
Track day with ambient temperature around 78F (26C) my oil temp topped out at 255F (124C).
A more spirited and accomplished track racer here in NZ topped their oil temp out at 284F (140C)
Originally Posted by keelerad View Post
Did a training/trackday here in the UK on Feb 14th. Ambient was about 3 C (37 F) had to wait for the snow to melt a bit before we could start
Car is standard apart from a K&N air filter, with moderate track use (as fast as I as a beginner wanted to go) it peaked at 120 C (250 F)
Normal daily driving sees it get up to between 90 - 100 C (194-212 F), a bit of a thrash on the road takes it up to 108-110 C (226-230 F)
Alec
Originally Posted by 2forme View Post
I've reached 218 degrees BARELY flogging it on the street. 30-34 F degree ambient. I might need an oil cooler LOL. Coolant holds steady at 196 F.
Originally Posted by The Slow One View Post
I'm barely seeing 250-260 F in the Houston weather, sometimes topping at 270ish F. It does depend on what track I go on though...
on the street, I'm seeing anywhere between 195-215 F(hit 215 while cruising at 85mph.) So I personally don't see the need for a oil cooler yet, but I see myself needing one if I ever decide to track the car during the summer.
Originally Posted by Pure Automotive View Post
Just logged some around town driving and some high rpm highway miles. 15 minute trip, the highest I got was 230 F. Car is stock with stage 1 flash, 995 miles, stock Toyota oil. I felt like I was being hard on it holding 6500 RPMs on the highway, but I guess not that bad temperature wise. Before I push it further I'm switching to motul.
Actual track temperature information WITH Oil Cooler
@Dave-ROR
saw 230-235 on track in 87 degree weather reading it under the filter. On the street in the same location in regular driving I never see more than 175-180, if I beat on it I can get close to 200.
@nzer:
One of our club has installed the HKS oil cooler and on track it now tops out now at 212F (100C).
The Following 21 Users Say Thank You to Sportsguy83 For This Useful Post:
Apex Chase (02-27-2013), ATL BRZ (02-28-2013), B L U E S L A T E (02-28-2013), BatStig (03-18-2013), Bg8780 (05-28-2013), Black Tire (02-27-2013), Bonburner (04-15-2013), BRZranger (02-27-2013), CA2 (03-06-2013), Chewie4299 (02-27-2013), Huehuecoyotl (03-07-2013), industrial (02-27-2013), LeeMaster (02-28-2013), Mikem53 (05-22-2013), ML (02-28-2013), suaveflooder (02-28-2013), The Slow One (02-27-2013), ultra (06-20-2013), whataboutbob (02-27-2013), WillRacer1jz (02-28-2013), zoomzoomers (03-27-2013)
Old 02-27-2013, 08:53 PM   #2
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I have the Perrin cooler in mine right now, and honestly can feel the difference. Normally after a bit of hooning, it feels as if the power is dropping off. Now.. it just keeps going. I plan on turboing this summer, and knew it was just a good idea to get an oil cooler for that. I love the research though, will be subbing this thread for sure.
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
The Following User Says Thank You to Batman For This Useful Post:
Old 02-27-2013, 09:08 PM   #3
Sportsguy83
Drives: Limited BRZ
Originally Posted by Batman View Post
I have the Perrin cooler in mine right now, and honestly can feel the difference. Normally after a bit of hooning, it feels as if the power is dropping off. Now.. it just keeps going. I plan on turboing this summer, and new it was just plainly a good idea to get an oil cooler for that. I love the research though, will be subbing this thread for sure.
Appreciate the feedback and want to make this clear:
This is NOT a thread on how good or bad is an oil cooler. Getting an oil cooler does NO wrong, its mostly positives aside from 1 or 2 minor drawbacks (introducing more potential points of leakage etc..).
This is a thread on how ABSOLUTELY necessary (or not) is an oil cooler for the different types of driving styles making the baseline a hot humid place.
Old 02-27-2013, 10:28 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
@sportsguy83-What was the ambient air temp when you were doing these runs?
Old 02-27-2013, 10:29 PM   #5
Sportsguy83
Drives: Limited BRZ
I'm really sorry, while I was writting the post I was going to add it but forgot. It was 72 F. Will update first post.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Lonewolf (02-27-2013)
Old 02-27-2013, 10:32 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
I wonder if your results would change much if it was in the high 80's/90's....
Old 02-27-2013, 10:36 PM   #7
Sportsguy83
Drives: Limited BRZ
I honestly don't think much. When you are flogging it on the street, there is so much air going so fast at the engine. I expect at 90+ It might have gone up, but I would say 235 F max. 235 F is still acceptable. Of course, there are extreme situations of 110 F temperatures. At that point, all bets are off.
Old 02-27-2013, 10:36 PM   #8
BRZranger
When Bob @Drift-Office dynoed my AVO'd BRZ, he said the oil temps remained surprisingly cool. As I approach the next stage, we'll monitor the oil temp to see if a cooler is needed. Paul @AVOturboworld said he had no issues with his oil temps on his drive to Sema.
Obviously, if I was to do serious tracking / longer track laps, an oil cooler would be needed.
BRZranger is offline   Reply With Quote
The Following User Says Thank You to BRZranger For This Useful Post:
Astroboy (03-15-2015)
Old 02-27-2013, 10:38 PM   #9
Sportsguy83
Drives: Limited BRZ
That's very encouraging to know. I would love to see the turbo not change much these N/A results.
Old 02-27-2013, 10:50 PM   #10
polancd
Drives: a few
How were you logging these temps?
polancd is offline   Reply With Quote
Old 02-27-2013, 10:51 PM   #11
Sportsguy83
Drives: Limited BRZ
Via OBD2 with Torque
Old 02-27-2013, 10:57 PM   #12
The Slow One
Track Junkie
Drives: Argento Scion FR-S
Thanks for posting this. I was trying to tell the local members that a oil cooler is not needed at all.
The Slow One is offline   Reply With Quote
The Following 2 Users Say Thank You to The Slow One For This Useful Post:
Dwood11 (01-08-2014), Sportsguy83 (02-27-2013)
Old 02-27-2013, 10:59 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
On the street at 90+ you'd probably see lower temps assuming you are cruising because of air flow. I normally drive around 80mph or so on the highway and it's cooler than when I'm cruising at 45mph. I need to get torque (main thing holding that up is the lack of an android device, although a friend has an old droid that might work) to read a value from the OEM location for good comparison.
Robi saw 290-295 on track (not 100% sure on where that was read from). I saw 230-235 on track in 87 degree weather reading it under the filter. On the street in the same location in regular driving I never see more than 175-180, if I beat on it I can get close to 200.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Astroboy (03-15-2015), Sportsguy83 (02-27-2013)
Old 02-27-2013, 11:05 PM   #14
polancd
Drives: a few
I Am goining to have to keep an eye on this. I was planning to do the same kind of testing in the future, but also comparing the temps i get from different locations (ie: sandwich plates, oil galley) to the stock sensor. Anyway, Thanks for doing this. Curious to see what your daily drivng temp was?
oil cooler
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 05:02 PM
