Old 02-15-2013, 06:56 AM   #253
JEFFSTYLE
hi
JEFFSTYLE's Avatar
Drives: 2013 BRZ Limited
Send a message via AIM to JEFFSTYLE
Originally Posted by Phaedrus29 View Post
New pics of the Colins, with clean car!
(Lights are actually on in this sunny pic, giving the light-ish color inside the tails)
Lookin goood!
man.. i really like DGM.. i was so torn when it came to colors!
JEFFSTYLE is offline   Reply With Quote
Old 02-16-2013, 12:54 PM   #254
jshadeck
jshadeck's Avatar
Originally Posted by Honeydew View Post
Is that stock exhaust or aftermarket?
Custom made muffler delete from another forum member.
jshadeck is offline   Reply With Quote
Old 02-16-2013, 03:29 PM   #255
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by Hachiroku View Post
Thanks for the pics and info, took me less than 2 minutes to swap these wires
Sent from my Note 2 on Omega Rom
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 02-22-2013, 02:36 PM   #256
Hix
Hix's Avatar
Drives: 2017 WRB PP
What the heck is this red reflector thing for?
Hix is offline   Reply With Quote
Old 02-22-2013, 09:09 PM   #257
jshadeck
jshadeck's Avatar
Lol mine made a great addition to "spare car parts bin"
But they are intended to be placed somewhere on the rear/side of your car as the states requires that all vehicles have an orange reflector on the front side (wheel well arch on the twins, which my clear sidemarker technically makes me illegal) and a red side marker on the rear/side (was built into the side of the stock taillights, colins dont have any reflector in them, just lights)
Old 02-27-2013, 12:03 PM   #258
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Just a heads up for anyone with a BRZ...
Here are the part numbers for Tail Lamp packing gasket if needed from Subaru
84940CA020 R/H $13.03 Canadian
84940CA030 L/H $13.03 Canadian
2URGSE
Old 02-27-2013, 02:30 PM   #259
Originally Posted by scioneric View Post
Red On Red
So nice!
I may have to have someone "accidentally" take a baseball bat to the OEM ones so I have a reason to replace them.
I have had the good fortune to follow behind a Raven FR-S in traffic a couple of days this week, and I was underwhelmed by the amount of light the OEM taillights put out. It almost borders on a safety issue to me.
Old 04-04-2013, 09:40 PM   #260
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Fawk - I can't get these damn wires out!!!!!
Buggered one the white wire pulled out of the crimped end
I don't understand what tab to depress
Help!
FRS_Ken is offline   Reply With Quote
Old 04-04-2013, 09:58 PM   #261
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Shit now the blue one is off the crimped end too
I guess I quit for the might
I should have just cut and soldered them
Shit
Old 04-04-2013, 10:08 PM   #262
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Aaaargh!
Old 04-04-2013, 11:27 PM   #263
jshadeck
jshadeck's Avatar
If you were local id offer to fix for you :/
Worst case u can cut off the factory ones and splice them onto the new tails, then worry about the stock lights later
Old 04-04-2013, 11:33 PM   #264
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Help!
Gah, sorry you're having so much trouble. Here's my description above, which you probably saw: "You stick the screwdriver in the side of the harness opposite the wires, and decompress the tiny white tab, by pushing it in the direction AWAY from the wire you are trying to remove...while pulling the wire."
The only thing I can think of is that maybe you aren't pushing the tab AWAY from the wire you're trying to remove...it definitely seems opposite of what you would think. The wifey helped me...so if you have someone with small hands and good eyes, try to get some help!
Phaedrus29 is offline   Reply With Quote
Old 04-05-2013, 01:46 PM   #265
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
I guess I need to use a thinner wire than small flat screwdrivers?
Not same connector but similar design...
[ame="http://www.youtube.com/watch?v=1tddRXRLcdU"]LS1 coil plug pin removal tool - YouTube[/ame]
Old 04-05-2013, 02:49 PM   #266
jshadeck
jshadeck's Avatar
It took me a fair amount of messing w it before i got the first one, then the second one was easy. Im trying to remember, there was a piece on the side that i popped loose first (doesnt come out but "releases") then i was able to use a thin nail to press on the tab inside the connector and release them from it
TYC tail lights doggy Cosmetic Modification (Interior/Exterior/Lighting) 90 02-13-2014 02:03 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
frs tail lights.. frsguy707 Exterior Parts (Aero, Lighting, Etc.) 10 11-11-2012 04:53 PM
Fatlace FR-S/BRZ Tail Lights? Broz Cosmetic Modification (Interior/Exterior/Lighting) 69 11-02-2012 09:55 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
