Old 02-26-2013, 07:33 PM   #43
Turbowned
Turbowned's Avatar
Electronic throttle, pedal deadzone, and throttle tip-in tables are all to blame here methinks.
Omg how many cars do you have man?!
Technically 4; it's a long story. MR2, E30 BMW, Celica convertible, M-B E320. The Celica I bought to fix up and flip; I've yet to drive it nor do I plan on driving it. The E30 was supposed to be my winter beater because I was borrowing my mom's old car (E320), but it hasn't left the garage due to mechanical overhaul. The Merc lasted much longer than I thought it would, but it and the Celica are going bye-bye when the BRZ comes this April. Possibly the E30, too. Maybe the MR2 as well. I don't even know anymore. Cars ruined my life.
How'd you change your user title, btw?
Old 02-26-2013, 10:46 PM   #44
orthojoe
Originally Posted by Fizz View Post
Get racerom with the downshift rev match function....
Wow. That's a really nice feature. Pretty cool that ecutek can do that now.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 02-26-2013, 10:50 PM   #45
OrbitalEllipses
Drives: Attitude
Sounds like you don't need a used German bruiser in your life. I changed it in my profile.
Old 02-26-2013, 11:06 PM   #46
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by KSC View Post
Normally when downshifting, in all my previous cars, a slight "blip" of the throttle with the side of my foot during heal/toe was all that was needed to rev match, but in this car I'm finding he RPMs fall almost immediately and much, much faster than everything else I'm accustomed to. I literally have to stab the gas peddle to the floor to keep the RPMs high enough for the lower gear.
Ha! You should be so lucky...Subaru could have designed it the way the new Civics work by making the RPM's hover for 1/2 a second before the needle drops. It makes shifting smoothly difficult in certain scenarios and I'm guessing will result in premature clutch wear.
It is refreshing to learn that the twins do not have this idiotic implementation for the Greenie Weenie crowd(apparently the reason it exists). The Accord doesn't have this system, but an Si does?!?
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
Subie (02-26-2013)
Old 02-27-2013, 12:23 AM   #47
emutcfut
Drives: 2013 Argento
Dual-mass flywheel? I noticed my 318is is sluggish to rev, too. Can't wait to swap out for a single mass.
Had me a 325is so it wasn't that. I'm pretty sure it was the prehistoric AFM system the car had.
emutcfut is offline   Reply With Quote
Old 02-27-2013, 01:11 AM   #48
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
A lightweight Flywheel + lightweight pulley will surely diminish this issue, I think(Because I never done it on this car before yet). It's something I will take priority once my clutch runs out or my power level is too much for the OEM clutch to handle.
LeeMaster is offline   Reply With Quote
Old 02-27-2013, 07:01 AM   #49
KSC
KSC's Avatar
Drives: Ion Redline
Yes, "rev hang"! I first heard about this when I was reading up on the Gen Coupe. In fact, that, along with the seemingly terrible trannys they come with, are the reasons I'm here. I wasn't dealing with that.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 02-27-2013, 07:04 AM   #50
Foobar
SLO NO MO
Foobar's Avatar
I think it would be a wash or worse. Yes, less rotational mass will give better throttle response, but it also exacerbates the initial power drop which the OP complained of to begin with upon releasing the accelerator since you have less rotational momentum.
Sent from my Nexus 4 using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
strat61caster (02-27-2013)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
