Old 02-26-2013, 10:46 PM   #155
Visconti
Drives: 05 STi
This car uses the MAF for fuel calculations. During a MAF issue there is a speed density limp map.
My vortech kit is MAF tuned and has a bigger map sensor for data logging and over boost protection
John
Visconti is offline   Reply With Quote
Old 03-03-2013, 11:11 AM   #156
congiiee
Drives: WRB Subaru BRZ
Originally Posted by Brian@Vortech View Post
Hi guys, I totally hear what you are saying about the harness. I'll talk to the guys and see what we can do. Maybe we can work it into the kit.
any news on the extension harness yet?
congiiee is offline   Reply With Quote
Old 03-11-2013, 02:04 PM   #157
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Wanted to take a minute and apologize for customers experiencing a longer than anticipated lead time on receiving your Vortech Systems both directly and through our trusted vendors at the current time. These systems have been an amazing success, even beyond our anticipation, and we have been doing our best to keep up with demands, but we are behind. We are doing everything we can to keep the lead times as short as possible, and will continue to do so until we catch up.
We definitely thank the FT86 enthusiasts for embracing the Vortech system, and we will continue to our efforts to keep you excited about, and happy with our products well into the future.
Brian@Vortech is offline   Reply With Quote
The Following 4 Users Say Thank You to Brian@Vortech For This Useful Post:
charged86 (03-29-2013), F1point4 (03-15-2013), Huehuecoyotl (03-16-2013), Pete (03-11-2013)
Old 03-15-2013, 01:10 AM   #158
nathan
Drives: Firestorm FRS
Inquiring minds and all...
nathan is offline   Reply With Quote
Old 03-15-2013, 05:25 AM   #159
EZWood
BAMF
EZWood's Avatar
John
Hey, I don't know a lot about tuning, but how would a map sensor provide over boost protection
Old 03-15-2013, 05:32 AM   #160
Visconti
Drives: 05 STi
The map sensor gives the ecu the ability to see higher boost levels.
All my forced induction calibrations have boost limiters setup in the ecu.
-John
Old 03-15-2013, 10:49 AM   #161
djdnz
1337
Drives: 2013 BRZ WRB S/C
-John
Hey John, how do you limit boost without some sort of wastegate? Do you just stop the throttle or something? I'm just generally curious.
djdnz is offline   Reply With Quote
Old 03-15-2013, 11:36 AM   #162
mad_sb
Drives: 2013 Asphalt FR-S
Probably fuel cut and throttle close like the stock rev limiter works and most factory turbo cars, it's over boost protection not boot control from what he is describing.
Old 03-27-2013, 11:29 PM   #163
JordanInnovations
Drives: Forced Induction and LSx Swaps!
Excited to hear our first couple "Complete" system kits are in production! We've gotten great interest in these for the CA crowd, especially once everyone heard they're shipping set up for 9psi out of the box.
Anyone running a Vortech system keep the stock clutch and have it last? That seems to be the biggest question, since the StayCrushing car's OEM clutch went so quickly.
JordanInnovations is offline   Reply With Quote
Old 03-28-2013, 06:40 AM   #164
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by JordanInnovations View Post
E
Gem a.k.a @Huehuecoyotl stock clutch is still holding up.
Old 03-28-2013, 06:45 AM   #165
ft_sjo
Drives: GT86
@Brian@Vortech
Were there design issues which prohibited the retention of the OE washer fluid bottle? Lots of other FI conversions seem to retain it with some more creative pipework.
I for one value the large capacity of the OE resevoir and would prefer not to lose it.
Are there any intentions from Vortech to improve this situation?
Thanks
Old 03-28-2013, 07:01 AM   #166
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
...get a custom pipe fabricated? getting a few bits of alloy tube welded up isn't hard or costly.
JP is offline   Reply With Quote
Old 03-28-2013, 07:05 AM   #167
Sportsguy83
Drives: Limited BRZ
Pretty sure when you are shelling out 5K for a kit, you want it to bolt on and work not have to fab up stuff, hence the question to try and get a solution similar to the other kits.
Old 03-28-2013, 10:56 AM   #168
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
quick update
1-AT 10 PSI this week, sure there is a tiny bit of slip at engagement under full power but its holding upwards ofo 190TQ and 250HP without going into full slip so far
2-next week 11psi!, then 12, maybe we will find clutch TQ limit?
3-their washer reloc kit is brilliant btw
4-I took apart and reinstalled the pipes going to TB -clocked them right, its not easy to get the 1st try, you learn as you do it, and there are zero rub issues for me now. This was more user than engineering.
5-removing the oil cooler from infront FMIC does impact the FMICs temp, and should impact IAT also, tho most of america isnt seeing 92F this time of year, I am.
6-soldering and some heat shrink wrap shouldnt scare anyone
Huehuecoyotl is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
