Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-26-2013, 09:04 AM   #57
v3rgil
Drives: Toyota 86 Black (Standard)
Originally Posted by Ryan86 View Post
Hi Guys, a real concern and something to be very aware of.
I parked in an open parking for 2 hours, car stood under the sun at 36 degrees. When I got into the car my dash had bulged and lifted up over the air vents, when I touched it the entire part was all soft. I immediately started the car put aircon on full and held the dash back into place. The aircon cooled the dash, which went back into place and hard as it normally is.
Got such a scare.
Be very aware of this problem, don't leave your car in the sun without a windscreen sun protector.
Going to report to Toyota
Pic attached is after cooling down and back into place, however you can notice it is not entirely as it should be....
smell my finger......
v3rgil is offline   Reply With Quote
The Following User Says Thank You to v3rgil For This Useful Post:
DrSUTRA (10-27-2013)
Old 02-26-2013, 10:21 AM   #58
Naughty
Drives: RunX RSi
Got such a scare.
I have had the same problem and reported to toyota.
They said take before and after pics and the more people report it the better so they can request for a fix.
Naughty is offline   Reply With Quote
Old 03-05-2013, 05:24 PM   #59
light
light's Avatar
Drives: Toyota 86 (2012)
Wink
Originally Posted by Matt_RSA View Post
I have a weird fault.....
Driving on the highway, aircon at coldest on 3.... push the aircon button to turn it off... leave it off for 2 or 3 minutes, then put it back on again. I get a white cloud coming out of the air vents!!! It seems to just be condensation of some sort, but its the weirdest fault i've seen.... And if you know its going to happen its an easy way to scare the #$%@ out of your passengers LOL
I've had this happen to me too. Twice... so you were not high
light is offline   Reply With Quote
The Following User Says Thank You to light For This Useful Post:
Matt_RSA (03-06-2013)
Old 03-05-2013, 05:40 PM   #60
light
light's Avatar
Factory defects
I also started hearing a popping / clicking sound, at first thought it was one of the usual "rear deck" issues. These are ones I researched:
-Emergency boot latch release not attached
-Moving rattling noise of the middle brake light
-A rear seat not clipped in.
-Rattling noise caused by the white plastic clips under the foam layer below the trunk.
-Or the
spot weld issue with flex
http://www.ft86club.com/forums/showthread.php?t=13451
However, the sound got louder when opening the passenger window. Turned out to be some factory defect in the left side drive train. Toyota Culemborg (Cape Town) had to order and fit new rear left driveshaft from Japan. Had them scratching their heads for a while!
Have started to practice heel & toe in case it was my vicious driving
Old 03-06-2013, 01:56 AM   #61
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Hectic
It's been more than a week now without any rear deck noises.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-11-2013, 04:36 AM   #62
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Small window rubber. Seems to be a common issue.
GeeTee86 is offline   Reply With Quote
Old 03-11-2013, 05:21 AM   #63
sav
sav's Avatar
That is not cool.
95RON SAV Tuned
Old 03-11-2013, 06:35 AM   #64
lucius
Drives: Toyota 86 Pearl White
Got such a scare.
Hey Ryan
Mine is exactly the same. Didn't know it was a fault. If you remove that air vent cartridge you'll see that the top piece of rubber is very flexible. There's really nothing holding it in place except a small notch in the center. The sides are free to move up and down.
lucius is offline   Reply With Quote
Old 03-17-2013, 08:47 PM   #65
Hawk77FT
Drives: GTS 86
Originally Posted by Thavash View Post
My friend had that on his 86. He said that its the metal portion just above the inside of the boot. Said that some Q20 spray fixed it temporarily for him but he had to use some silicon sealant for a permanent fix.
OMG that noise is driving me crazy.
Hawk77FT is offline   Reply With Quote
GT factory amp? derka-derka AUSTRALIA 11 11-06-2022 05:27 PM
Factory Turbo BRZ ChocolateNick AUSTRALIA 34 10-31-2012 01:56 PM
factory Turbo BRZ? subatoy BRZ First-Gen (2012+) — General Topics 30 09-26-2012 04:54 PM
electrical faults... tibsy92 AUSTRALIA 22 08-19-2012 11:25 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 11:46 PM
