Old 02-05-2013, 05:08 AM   #29
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Originally Posted by boredom.is.me View Post
May I ask where you purchased these springs from?
i got them from young at FRS 86
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
The Following User Says Thank You to Tylub For This Useful Post:
boredom.is.me (02-25-2013)
Old 02-08-2013, 04:26 PM   #30
Tylub
Tylub's Avatar
Originally Posted by Khánh View Post
looks good.. any straight side shot?
here you go
instagram @Tylub
Old 02-08-2013, 05:24 PM   #31
Khánh
Khánh's Avatar
Drives: sc00ter
looks good.. have u done any alignment yet?
Khánh is offline   Reply With Quote
Old 02-11-2013, 10:37 PM   #32
Tylub
Tylub's Avatar
yeah, it cost me like $90 but I don't really think it was necessary
after install i was pulling slightly left but others swear by alignment because of tire wear and all the other technical stuff
instagram @Tylub
713_GT86 (02-12-2013)
Old 02-12-2013, 04:31 AM   #33
Khánh
Khánh's Avatar
Drives: sc00ter
by any chance u have specs after alignment?
Old 02-12-2013, 05:29 AM   #34
Boost_Junkie
3.141592654
Boost_Junkie's Avatar
Drives: 2013 Galaxy Blue BRZ
That looks really, REALLY good!
Boost_Junkie is offline   Reply With Quote
The Following User Says Thank You to Boost_Junkie For This Useful Post:
Tylub (02-12-2013)
Old 02-12-2013, 12:35 PM   #35
Tylub
Tylub's Avatar
yeah, I'll snap a picture for you later today if I can still find the paper
I have a really neutral set up, despite me being staggered because at the track I can still kick the tail out at ease, and I had very little body roll, nothing stiffer sway bars can't fix hehehe
instagram @Tylub
Old 02-12-2013, 05:25 PM   #36
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
spring rates?
Goya is offline   Reply With Quote
Old 02-21-2013, 05:51 AM   #37
Tylub
Tylub's Avatar
Originally Posted by *KID* View Post
These look legit. Wonder how they handle at the track
they handled great, very little body roll. I expect with some struts I'll be good to go
instagram @Tylub
Old 02-24-2013, 10:59 PM   #38
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Hey @Tylub any idea on the lowest height on the car is now? Would be curious to know how low the car is (at lowest point) for legality reasons here in Aus.
JDMSushi is offline   Reply With Quote
Old 02-25-2013, 03:20 PM   #39
Tylub
Tylub's Avatar
I'll measure it and check it out for you, I'm assuming my mudflaps don't count as "lowest point" correct? because it's 2 fingers off the ground hehehe...
instagram @Tylub
Old 02-25-2013, 10:06 PM   #40
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Haha prob best to not count from the mudflaps then
Old 02-25-2013, 10:37 PM   #41
JDMSushi
JDMSushi's Avatar
Drives: JDM86
http://www.mann-engineering.com/cata...z-fr-s/exhaust
The Following User Says Thank You to JDMSushi For This Useful Post:
Tylub (02-26-2013)
Old 02-25-2013, 11:09 PM   #42
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I "ran into them" last night. I like how there are four spring options. There are two drop levels and two spring rates for each.
BRZ 35mm
Drop - Front: -35mm, Rear: -35mm
Rate: - Front: 3.26kg/mm(183lb/in), Rear - 3.94kg/mm(220lb/in)
BRZ 25mm
Drop - Front: -25mm, Rear: -25mm
Rate: - Front: 3.02kg/mm(169lb/in), Rear - 4.28kg/mm(240lb/in)
FR-S 35mm
Rate: - Front: 3.16kg/mm(177lb/in), Rear - 3.93kg/mm(220lb/in)
FR-S 25mm
Rate: - Front: 3.06kg/mm(171lb/in), Rear - 4.18kg/mm(234lb/in)
http://www.mann-engineering.com/cata...ension/springs
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 06:26 PM
BRZ DRIVEN FULL REVIEW (lowering springs pics too) Racecomp Engineering BRZ First-Gen (2012+) — General Topics 99 12-14-2019 05:14 PM
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 09:59 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:39 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
