Old 02-25-2013, 03:57 AM   #1
sidnacious
sidnacious's Avatar
Drives: Argento FR-S
Wheel Directory: WedsSport TC105N 18x9.5 +35
Weds Sports TC105N 18x9.5 +35 square
R-255/35/18 +5mm spacer
F-245/40/18
Please enjoy the crappy pictures
sidnacious is offline   Reply With Quote
The Following 5 Users Say Thank You to sidnacious For This Useful Post:
Anthonytpt (02-25-2013), Beyer Subaru (03-04-2013), F1point4 (02-26-2013), sal (02-26-2013), ScionFamily (02-25-2013)
Old 02-25-2013, 06:10 AM   #2
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Looks great. How does the set up drive?
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following User Says Thank You to Metabrz For This Useful Post:
sidnacious (02-25-2013)
Old 02-25-2013, 07:39 AM   #3
mswhong
Drives: FT86
wowwwww. I was really split between these and the gramlights.. but i think these take the cake. Love the aggressive-look they bring to the car!
Any idea on weight?
mswhong is offline   Reply With Quote
The Following User Says Thank You to mswhong For This Useful Post:
Old 02-25-2013, 07:39 AM   #4
Paragon
Guest
Posts: n/a
Looks good but I dont get why ppl run a square setup with wheels but then go put on different tyre's? You would not be able to tell the difference from the above setup to one running 245 all round except now its awkward for you to rotate tyres? But meh its your car
Old 02-25-2013, 11:28 AM   #5
sidnacious
sidnacious's Avatar
Any idea on weight?
18 pounds without tires
The Following User Says Thank You to sidnacious For This Useful Post:
SkAsphalt (02-25-2013)
Old 02-25-2013, 11:30 AM   #6
sidnacious
sidnacious's Avatar
Got a great deal/steal on the rears that I couldn't pass up; Had the fronts lying around. The next set of tires will be true square.
Old 02-25-2013, 11:35 AM   #7
sidnacious
sidnacious's Avatar
The steering feels a lil more heavy which I don't mind cause it felt too sensitive before. The zippy feeling from turning is gone but replaced with grip.
Old 02-25-2013, 12:20 PM   #8
s14sleepyeyez
Drives: 2013 Argento Scion FR-S
What kind of suspension are you running? Any issues with rubbing?
s14sleepyeyez is offline   Reply With Quote
Old 02-25-2013, 12:24 PM   #9
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
These look awesome!
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
fenixv8 is offline   Reply With Quote
The Following User Says Thank You to fenixv8 For This Useful Post:
Old 02-25-2013, 12:30 PM   #10
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
F-245/40/18
gorgeouse my dude
DanoFA20 is offline   Reply With Quote
The Following User Says Thank You to DanoFA20 For This Useful Post:
Old 02-25-2013, 01:12 PM   #11
VoiD
Drives: 13 WRB BRZ
Why did you opt for running summer tires up front and all season pilots on the rear?
VoiD is offline   Reply With Quote
Old 02-25-2013, 01:45 PM   #12
Foobar
SLO NO MO
Foobar's Avatar
He addressed the tire mismatch question here:
The Following User Says Thank You to Foobar For This Useful Post:
Old 02-25-2013, 03:38 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Interesting decision to go with a 245/40/18 instead of the more OEM diameter 245/35/18. Did you need the 5mm spacer in the rear to get the 255 tire to clear on the inside?
Old 02-25-2013, 04:08 PM   #14
sidnacious
sidnacious's Avatar
Tein flex, roughly around a 2 inch drop. I only rub a little going up and down steep driveways.
Wheel Directory: WedsSport TC105N 17x9.0 +35 twincamRob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 397 06-04-2021 01:16 PM
Wheel Directory: Wedssport SA-67R 18x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 06-01-2021 05:28 PM
Wheel Directory: WedsSport SA-15R 18x9.5 +48 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 09-13-2020 02:22 PM
Wheel Directory: WedsSport SA-10R 18x9.5 +45 sdemo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 03-26-2017 02:16 AM
Wheel Directory: WedsSport TC105N 18x8.5 +43 / 18x9.5 +35 switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-29-2016 01:26 PM
