Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-23-2013, 09:26 AM   #1
Mike Hoxbig
Mike Hoxbig's Avatar
Drives: Toyota 86 High 6MT
Dead spot when changing from 1st to 2nd?
Hey guys, has anyone experienced a dead spot when snap-changing from 1st to 2nd? I've noticed this happen even in Sport mode, so traction control would have been off. It's happened to me twice so far - changing up from 1st at about 7,000, it moves to about 5,000 in second which should be in the optimal power band, but went dead before coming alive again.
Mike Hoxbig is offline   Reply With Quote
Old 02-23-2013, 11:21 AM   #2
sav
Official anti-BS squad
sav's Avatar
Nope, snap changing from 1st to 2nd results in the rear wheels spinning up, no flat spots...
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-23-2013, 11:37 AM   #3
sierra
Drives: Skoda Yeti DSG diesel 4x4
How many km/miles on the clock?
Mine had a throttle delay that gradually improved and was good by about 1,000km. Could it be that, with the ECU learning?
sierra is offline   Reply With Quote
Old 02-23-2013, 01:05 PM   #4
Mike Hoxbig
About 2,500 km, engine has already been run in doesn't happen all the time, but I've noticed it twice so far.
Old 02-23-2013, 09:28 PM   #5
sierra
Try turning everything off? The traction control will still be active in sports mode.
Old 02-24-2013, 08:29 PM   #6
Mike Hoxbig
Thanks I'll try that, although its not really suitable for everyday driving. The bit I'm confused about is that when you put in in sports mode, the indicator light on the dash shows traction control being off, with only stability control being in sports mode.
Old 02-24-2013, 08:45 PM   #7
sierra
I only meant to try it turned off to test that scenario. I leave mine on all the time and still get plenty of noise from the tyres.
In sports mode the stability control might still cut the power if the back wheels were losing it big time?
Old 02-25-2013, 12:00 AM   #8
KapteinBos
KapteinBos's Avatar
Drives: Toyota 86, Pearl White, Manual
Manual says in sports mode SC is still on but less sensitive...?
KapteinBos is offline   Reply With Quote
Old 02-25-2013, 12:21 AM   #9
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
How do you turn the feature on properly? Is it just a matter for pressing the button?
Argento ate6
mRdeMs83 is offline   Reply With Quote
Old 02-25-2013, 12:39 AM   #10
KapteinBos
KapteinBos's Avatar
Hold Traction Control (left button) in for 3 seconds and all are completely off. Press same button once when stationary and TC is off untill you get to 50kmph (for mud and snow). Press Sport button (right) once and Sport mode is on...
Sent from my GT-I9100 using Tapatalk 2
Old 02-25-2013, 12:50 AM   #11
sierra
Argento ate6
It's always on when you start up. You can then either select 'sports'' to reduce the intervention or choose 'off'. To turn it completely off you need to hold down the 'off' button for 3 secs.
Got sidetracked halfway through and missed you had already answered.[good colour choice]
Old 02-25-2013, 01:27 AM   #12
mRdeMs83
mRdeMs83's Avatar
Vcs/sport button? Hold it down or the trac button?
Argento ate6
Old 02-25-2013, 10:35 AM   #13
brian_c_m
brian_c_m's Avatar
Drives: Toyota 86 - Silver High Spec
Hi Mike
I haven't noticed any issues on mine either. Like Sav, I happily spin from 1st to 2nd and even 2nd to 3rd without dead spots and with nanny aids on.
Sounds like it might be a fuel injection issue which i've heard is also responsible for the Check Engine Light (CEL) issue that a lot of other members are experiencing. What might be useful is, if you have a smart phone, to get yourself an OBD ii device and see if the car is reporting any error codes?
I think that if it were the nanny controls causing this then they'd be flashing whenever this issue occurred.
Good luck.
brian_c_m is offline   Reply With Quote
Old 02-25-2013, 11:58 AM   #14
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Is this a flat spot? I have found giving it a blip between changes my compensate. My first test drive was met with the dealer power-shifting aggressively. the car had less than 100km!
Vic_RSA is offline   Reply With Quote
The Walking Dead DIM Off-Topic Lounge [WARNING: NO POLITICS] 286 11-03-2014 12:19 AM
Installed exhaust and Intake, pedal dead spot. How long does it last jflogerzi Engine, Exhaust, Transmission 24 02-23-2013 06:11 PM
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 01:42 AM
spot cleaning jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-26-2012 07:12 PM
g35 brought from the dead bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-26-2012 12:22 AM
