Old 02-18-2013, 08:03 AM   #15
whtchocla7e
Drives: 2013 FR-S Hot Lava
Today I went to start the car after more than 24h. It was 15*F outside.
I got like five or so good (loud) knocks in the first few seconds.
I was expecting this so I set up two cams for recording. The bulit-in mics blow but maybe I'll be able to salvage something.
Not happy..
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 02-19-2013, 03:33 PM   #16
getbent
Drives: 2013 FR-S Blue MT
I wonder if the anti-drainback valve in the oil filter isn't functioning properly and the oil is draining out of the filter.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 02-19-2013, 04:29 PM   #17
Hanakuso
I've noticed a "knock" a few times while warming the engine up. It sounds more like something is loose and slightly rattling.
Btw weather is 40-60F
Hanakuso is offline   Reply With Quote
Old 02-22-2013, 08:31 AM   #18
Wattage
Wattage's Avatar
Drives: scion fr-s MT
I think this happened to me today. Went to start my car in the morning, first try it would not start, second try it started after about 5 or more seconds with the same kind of knocking you guys are describing. It went away after about a minute and the drive to work seemed normal, although i kept the revs as low as possible. The temp was zero celcius. Ive never had this issue before today, even when it was minus 20 C.
Kinda concerned, really thinking of going to the dealership about this.
Wattage is offline   Reply With Quote
Old 02-22-2013, 10:02 AM   #19
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
My car does this every cold morning, coughs a few times during the first 10 seconds
shu5892001 is offline   Reply With Quote
Old 02-22-2013, 11:22 AM   #20
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I've run into this issue in the past few weeks. I went to start my car after work and it started but then sounded like it was going to stall and then was ok. This past weekend I started the car and it hesitated like it wasn't fully on.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 02-23-2013, 10:21 AM   #21
whtchocla7e
Dropped my car off at the dealer and got a rental. I recorded the knocking and gave them a video. Interested in what they find.
The Following User Says Thank You to whtchocla7e For This Useful Post:
A5D5TRYR (02-23-2013)
Old 02-23-2013, 10:28 AM   #22
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I'm interested to hear what they have to say. Seems a number of people are running into this to some degree or another.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 02-23-2013, 02:52 PM   #23
Wattage
Wattage's Avatar
I'm curious, how much fuel did you guys have left in your tanks when you encountered this?
After asking around a bit, people have told me this can happen in cold temps with low fuel levels due to condensation. My Dad said it happens occasionally in low temps with his BMW M coupe when it is low on fuel.
When it happened to me, I had a quarter tank of fuel at 0 Celcius.
Old 02-23-2013, 04:20 PM   #24
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I wouldn't call it a knock, but my dad said it's got a miss on start up. Not sure if it's only the cold starts though since I've only had it since it's been cold. It misses for the first few minutes of idle. Not sure if this similar.
Nevermore is offline   Reply With Quote
Old 02-24-2013, 10:12 AM   #25
A5D5TRYR
A5D5TRYR's Avatar
Yeah that sounds EXACTLY like what mine does. But if I just start driving it's fine. Even if I only drive for 30 seconds or so and come to a stop again it's gone.
Old 02-24-2013, 10:13 AM   #26
A5D5TRYR
A5D5TRYR's Avatar
Happens at every fuel level for me. And it seemed a little bit worse on Shell 91 than it did with Ultra 94, but that could be me.
Old 02-24-2013, 11:43 AM   #27
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I get one bad hiccup on start up and that's pretty much it. Not completely positive if it's knock but I can't suggest anything else it could be.
I was so sure it was due to my tune until I flashed to stock and still had the same issue. I'll try to take a video and see if other people can agree they have a similar issue.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 02-24-2013, 01:13 PM   #28
Opposed
Drives: 2013 Asphalt FR-S
Mine has been doing this all winter when its below maybe 10 degrees. Mostly sounds like its oil starved (valve tick, piston slap, ect)
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
cold weather & remote starter jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 11-10-2012 06:03 AM
Cold-weather morning shifts NetMagi Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 11:05 AM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 11:42 AM
Pretty sure car hates the cold weather HuntingtonFRS Issues | Warranty | Recalls / TSB 28 10-21-2012 04:52 PM
