View Poll Results: Did your crickets return and how many pumps have been replaced?
My crickets are gone and the pump replacement worked 18 32.14%
My crickets are still here, and I've had one replacement 32 57.14%
My crickets are still here and I've had two replacements 3 5.36%
3+ Fuel Pumps replaced and still have crickets 3 5.36%
Voters: 56. You may not vote on this poll
Old 02-23-2013, 09:48 AM   #29
EBMCS03
Drives: Argento FR-S
Originally Posted by FR-S Matt View Post
You can tell right away when you give it a little gas and let it go back to idle. If you hear the tone get more rapid then slow down to a chirp, you'll know it is the fuel pump rather than the DI.
Thanks. I'll try that.
EBMCS03 is offline   Reply With Quote
Old 02-23-2013, 12:05 PM   #30
Frs300
Frs300's Avatar
Drives: Pile of junk
i had mine replaced the first time at 3500 miles after waiting 3 months for the part because of chirping. finally got it replaced and it started chirping again that same day i drove maybe 60 miles on the new pump. i will not be getting it replaced again just going to turbo it.
Frs300 is offline   Reply With Quote
Old 02-23-2013, 12:10 PM   #31
ftc~brz
Done
Drives: WRB BRZ
had mine replaced last week @6700 mi. Not a chirp yet, but I'm waiting for them to come back.
I only mentioned the noise and I guess there was a tsb so they ordered it. I didn't mind them really.
ftc~brz is offline   Reply With Quote
Old 02-23-2013, 12:13 PM   #32
wbradley
Sarcastic SOB
wbradley's Avatar
Don't feel so bad people,in Canada they deny the chirp exists.
Old 02-23-2013, 12:59 PM   #33
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
These noises are due to alcohol mixed fuels and are inherent to Subarus based on what a Subaru master tech told me (mine was the first BRZ he serviced). I once had an occasional chirp but when I switched to 93 octane ethanol-free fuel, it went away.
From my understanding the TSB replaces the existing HPFP with the same HPFP, correct? Or do they re-install it a different way? My friend is on his 3rd HPFP (replaced twice) and the chirps eventually came back in each instance. He hasn't been using ethanol-free fuel so I believe it's all in the fuel.
My other friend conducted a test. He used 93 octane ethanol-free fuel and had no chirps. Then switched to 93 octane *with* ethanol and the chirp came back. Then switched back to ethanol-free 93 and the chirp was gone.
Old 02-23-2013, 01:18 PM   #34
FR-S Matt
Yeah, ethanol free here in Texas is impossible from what I've seen. All gas stations have at least 10% ethanol in them. I'm going to research and see if I can find one that is ethanol free just to see about the chirp. I know this is one of the reasons the GT86 owners in other countries haven't had issues with this because they're ethanol free from what I read.
Old 02-23-2013, 02:28 PM   #35
sf86
sf86's Avatar
Drives: Red Scion FRS AT
Its 1700 miles after the 4th fuel pump replacement and i only hear the cricket once in a while just for a minute or two when the engine is not fully warm up. Even when its there, I can only hear the cricket when I'm at 900-1000 RPM. . I'm very happy with my car as is now. Cricket, Please don't come back
sf86 is offline   Reply With Quote
Old 02-23-2013, 05:17 PM   #36
SilentMike
Drives: 2013 FR-S 6MT Asphalt
Criminy! Four fuel pumps! You sir, have the patience of Job. I had my original pump replaced in the fall after taking delivery during the summer. My chirps returned within a few hundred miles. I've just been grinning and bearing it since (made easier by the winter and windows-up driving most of the time). I guess I'll wait until my next oil change and see about getting pump #3.
SilentMike is offline   Reply With Quote
Old 02-24-2013, 07:55 PM   #37
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
forgot to update, but i've noticed that it only makes the cricket noise on occasion. And from my scientific engineering genius background, it seems like the pump gets crickets when you switch fuel qualities, i.e from 1 station to another. example, after i gassed up at valero on premium it started making it for about 48 hrs. then it settled. then i gassed up at a murphys usa, and it started for a bit and then stopped.
sofrsnsokleen is offline   Reply With Quote
Old 02-24-2013, 08:14 PM   #38
EBMCS03
Humm are u sure it's not after every fill up since that causes a change in pressure in the fuel tank.
Old 02-25-2013, 03:16 PM   #39
Raven604
chevron 94. no more crickets. 0 ethanol
Raven604 is offline   Reply With Quote
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 08:53 AM
Fixing crickets/chirping sound in Canada? i_4got CANADA 54 06-30-2013 01:48 PM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-05-2013 11:29 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
