Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 02-22-2013, 07:24 PM   #15
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by Blue86 View Post
Sweet!
I still thought some were concerned about proximity to the steering box and therefore heat issues
I was worried about it at first but after nearly 2 summer months it seems to be fine. There are space around it for hot air to escape.
I don't want heat wrap as they might cause rust and/or other issue as heat are being trapped. I couldn't get ceramic coating done b4 installation due to being close to Xmas.
Nardi330 is offline   Reply With Quote
Old 02-22-2013, 09:13 PM   #16
mswhong
Drives: FT86
Well that settles it then Thanks Nardi!
mswhong is offline   Reply With Quote
Old 02-23-2013, 02:23 AM   #17
Ryan1JZ
Drives: AE93, JZZ30, ZN6
i have no idea what an over pipe is. is it another name for a down pipe??
Ryan1JZ is offline   Reply With Quote
Old 02-23-2013, 02:43 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Old 02-23-2013, 02:44 AM   #19
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Called Dan from Car Mods Aust a while ago and he confirmed that the Perrin headerback system is perfectly fine for our RHD cars, as many aussie owners can now confirm...
proficience is offline   Reply With Quote
Old 02-23-2013, 04:14 AM   #20
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
You could get a pipe made from any half-competent fabricator in Aus. There's only $60 worth of stainless and flanges in one.
JP is offline   Reply With Quote
Old 02-23-2013, 05:19 AM   #21
86drift
86drift's Avatar
Drives: Toyota 86 GT
There's been some problems with the alignment of the Perrin over pipe.
Is there any reason to change the over pipe?
I don't think it makes hp or changes the sound and you can't see it so no bragging rights.
86drift is offline   Reply With Quote
Old 02-23-2013, 06:04 AM   #22
mswhong
Drives: FT86
Those problems are minor I assume? I hope they are
Well, reason for the change is so i can rightfully say i have a full exhaust system on the car once headers are introduced
Old 02-23-2013, 06:45 AM   #23
Nardi330
Nardi330's Avatar
Drives: 86
as far as i know, there are only problems when mixing and matching.
if u fit it between stock parts or stock and Perrin parts then i haven't seen anyone who have issues. please correct me if i'm wrong.
the reason i want overpipe is the stock one is restricted and i want a 2.5" one to match my front pipe and cat back.
stock vs Perrin:
Old 02-23-2013, 03:23 PM   #24
86drift
86drift's Avatar
The two people I know to have trouble both have Perrin from the header back.
One has the AVO kit and the other has the standard header.
The flanges didn't match up correctly so the bolts were used to pull the flanges together. The bolts later snapped.
There's more restriction from the cat in the headers. I have custom headers and over-pipe back 2.5". I will replace the over-pipe but probably not until I'm searching for 0.5 of a kW.
When someone releases one for $150 it will be more tempting.
Old 02-23-2013, 03:32 PM   #25
Nardi330
Nardi330's Avatar
Drives: 86
With the one bolting onto the standard header, was it on a standard front pipe?
What's behind it effects the fitment of the front too.
I would like a header to complete my system in the future, when someone produces one that I like with a cat at a price that I can afford. I'd then get a tune done for max result.
Why didn't you get it custom made when u got the header done for a complete 2.5" system?
Old 02-23-2013, 06:20 PM   #26
JiB
JiB's Avatar
Drives: GT86
I think thats me, but when fitting we re-used stock bolts accidentally. refitted supplied bolts and so far so good
@Nardi330 - If you have the Perrin over, front and catback unresonated, is it really raspy for you before it warms up? Mine is crazy raspy until exhaust heats up, then its perfect
JiB is offline   Reply With Quote
Old 02-23-2013, 09:08 PM   #27
Nardi330
Nardi330's Avatar
Drives: 86
Yeah same here but it only takes 30 odd seconds for idle to settle.
While the car warms up I think the whole 2 levels of basement carpark could hear me.
Btw the stock bolts were too short so using the Perrin supplied bolts were no brainer.
Old 02-23-2013, 09:18 PM   #28
JiB
JiB's Avatar
Drives: GT86
You planning on changing headers?
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
M R TIRE SOLUTIONS SG Valley/So Cali TSW Nurburgring Interlagos Mallory Max Donington MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-14-2012 03:19 AM
New Vendor - Intro- M R Tire Solutions of Southern California - Tires-Wheel-Brakes MIKE@MRTIRESOLUTIONS Wheels and Tires 2 12-13-2012 06:59 PM
Few complaints about the handling need solutions regal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 10-01-2012 06:21 PM
