Old 02-22-2013, 11:54 PM   #15
GaN-MaN
WA 86/BRZ Club
GaN-MaN's Avatar
Drives: Toyota 86 GT MT Sonic Blue
Originally Posted by Turbowned View Post
@GaN-MaN, can you post a pic of your car with the Colin taillights? I've been trying to see more pics of that color car with the smoked taillights. Thanks! Super clean audio install btw!
Haha. Sure man. A lil off topic but no probs at all. Pics are all here man and if you've got Facebook give the page a like.
http://www.facebook.com/media/set/?s...2548469&type=3
2012 Toyota 86 Sonic Blue GT 6MT
GaN-MaN is offline   Reply With Quote
The Following User Says Thank You to GaN-MaN For This Useful Post:
Turbowned (02-23-2013)
Old 02-23-2013, 07:19 AM   #16
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
How are you liking the PDX? Where did you shove the Bit Ten?
Skippman is offline   Reply With Quote
Old 02-23-2013, 09:37 AM   #17
Turbowned
Turbowned's Avatar
Yep, those lights look perfect with that color, just as I thought! Thanks
The Following User Says Thank You to Turbowned For This Useful Post:
GaN-MaN (02-25-2013)
Old 02-23-2013, 09:41 AM   #18
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I have to say that I think using the spare tire well for sub enclosure and amps is a much better design than molding enclosures on each side of the trunk. Not only do you retain more usable trunk space but you also keep the center of gravity as low as possible. If you're going to add weight to a car with a big, heavy sub, then keeping the box as low as possible is key on a car like this.
I've built many similar setups with the amps and subs all integrated into one, removable piece. I use forklift disconnect plugs for the 4 gauge or 1/0 gauge power and ground wires for a solid connection and easy to disconnect for removal. I also like to use hood latch mechanisms for the mounting points so there are no screws or bolts to remove...just pull a lever and the box releases. Just a few ideas if you ever plan on doing track day events with your car.
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Old 02-24-2013, 11:45 PM   #19
matchamochi
matchamochi's Avatar
Drives: swp brz
Looks awesome - only concern is what happens when you get a flat?
matchamochi is offline   Reply With Quote
The Following User Says Thank You to matchamochi For This Useful Post:
Old 02-25-2013, 02:47 AM   #20
GaN-MaN
WA 86/BRZ Club
GaN-MaN's Avatar
PDX is working beautifully. It's just so much simpler having to use only a single amp to power the whole system. It also comes with plug in power points so makes it a bonus and easy to disconnect.
Bit ten is on the left side of boot behind the carpet in the rear quarter panel. It's screwed into the already existent holes.
Thanks Chad. I agree with you on this 100%. It's just a simple design without taking away any boot space.
As for your latch idea, this sub/amp box is a mold of the original spare tyre delete foam so it sits in there without any movement at all. No extra holes or anything at all needed. Remove the mesh and two side pieces, then pull out 6 RCA's, 4 channel plugs and power plug and just lift the box out. Easy as that.
I never got a spare. Haha. Instead I received a tyre repair kit. So just a little bag.
Skippman (02-25-2013)
Old 02-25-2013, 07:21 AM   #21
chadstyle
chadstyle's Avatar
Subaru road side assistance or AAA. Many of the people doing audio upgrades have also done wheel/tire upgrades also. I know I wouldn't run a spare with 18s as I don't want to mess anything up.
Old 02-25-2013, 07:43 PM   #22
matchamochi
Drives: swp brz
Or some people get a 5th rim/tire for a full sized spare
Old 03-26-2014, 03:25 AM   #23
marsh
Drives: ft 86 black
may i ask what it cost in total for labor. dyno matt install etc, i feel i am being charge too much for labor on my system and mine is similar to yours and i have my 3 ways mounted in existing locations.
marsh is offline   Reply With Quote
Old 03-26-2014, 05:43 AM   #24
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Bit ten is a nice piece that and an Audison 5.1k amp will be my next move on stereo. Currently running a HDP5 Hertz which has served well but soon hopefully up the anty.
Very nice install!!!
Custom audio in the FRS Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 1 11-12-2012 06:27 AM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 07:42 PM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 06:11 PM
Any specs on the standard Audio setup? viking84 Electronics | Audio | NAV | Infotainment 72 05-30-2012 03:34 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
