Old 02-22-2013, 09:42 PM   #15
Tiremonkey0824
Drives: 2013 Argento 6mt
People in major cities like the greater houston area won't see ethanol free gas because ethanol is required in large population areas.
Tiremonkey0824 is offline   Reply With Quote
Old 02-22-2013, 09:58 PM   #16
mush
mush's Avatar
non in houston
Old 02-22-2013, 10:24 PM   #17
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Originally Posted by Poogles View Post
Noob question here. What effect does the ethanol have of the quality of the gas?
While it is true that ethanol has a higher octane rating that gasoline, the overall octane rating of E10 or non-ethanol gasoline of the same grade will be the same.
Ethanol is added because it is contains oxygen, and can help create a more complete burn, reducing emissions. It replaced MTBE, which was the previous oxygenate additive. MTBE caused nasty things to happen when it got in people's ground water.
Ethanol also reduces the amount of gasoline we use by 10%, which in turn reduces our crude oil importation and refining requirements.
TheRipler is offline   Reply With Quote
The Following 2 Users Say Thank You to TheRipler For This Useful Post:
Allch Chcar (02-22-2013), Poogles (02-23-2013)
Old 02-22-2013, 10:32 PM   #18
dsgerbc
Drives: BRZ(sold), STI
Always ask what's in their "ethanol-free" gas. It could well be something like 89-octane gas with a boatload of octane booster. Might be okay for their customers (off-road vehicles, boats and other engines w/o cats). But you can end-up damaging your catalytic converter and cylinder walls real quick.
Old 02-22-2013, 10:35 PM   #19
Allch Chcar
Drives: N/A
Originally Posted by metalmoses View Post
I just put 93 Octane Ethanol free gas in my FR-S and the crickets went away almost empty. For reference, my car was almost empty when I added fuel.
Could you clarify that first sentence for us? Did you test the gasoline yourself with a tester?
Yes to everything else but as for that last part, actual reduction is more like 2/3. There's the bit worse fuel economy to consider.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-22-2013, 10:41 PM   #20
metalmoses
metalmoses's Avatar
Drives: 2013 Scion FR-S Firestorm MT
I live in a small town here in TN, we only have two gas stations that do not put Ethanol in their gas, one even sells racing fuel! To answer your question, no I have not personally tested the gasoline. I noticed my "cricket" noise being unbearably loud on the way home from work this evening. I figured I would try putting Ethanol free gas in the FR-S. I was reading on break at work that quite a few people on the forum has had good luck with Ethanol free fuel solving their *cricket* noise problem. I can vouch that it has helped me.
metalmoses is offline   Reply With Quote
The Following User Says Thank You to metalmoses For This Useful Post:
PeterFRS (01-24-2016)
Old 02-23-2013, 08:20 AM   #21
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Originally Posted by KyleGato View Post
Lucky. I paid $4.50 this AM to fill up on 91 Octane with ethanol.
yikes. If the government is careful we may see another dip in the economy. People have to buy gas to get to work. If it gets too out of hand they will do this instead of paying their bills. Family has to work in order to put food on the table.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 02-23-2013, 12:21 PM   #22
Allch Chcar
Drives: N/A
Thanks for clarifying. I find it interesting that Gasohol would make it chirp when pure gas makes it stop. That's not a comforting sign to be sure. Chirps I can handle, it's the ancillary concerns that bother me.
I live in a smaller town than you but we've got 3 stations that sell pure gas. I'm still upset that the local E85 station closed down right before I moved here and now the nearest E85 pump is 20 miles away.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
metalmoses (02-23-2013)
Old 02-23-2013, 01:51 PM   #23
blackraven1425
Drives: raven at
The government cannot affect gas prices the way you think they can...
blackraven1425 is offline   Reply With Quote
Old 02-23-2013, 02:09 PM   #24
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Thanks for posting. Their app is easier. I really have to go out of my way to get to a gas station here in Miami.
http://itunes.apple.com/us/app/pure-...9068?ls=1&mt=8
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 02-25-2013, 04:33 PM   #25
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
I just put 93 Octane Ethanol free gas in my FR-S and the crickets went away almost immediately. For reference, my car was almost empty when I added fuel.
This! my car is a idle dipping, chirping and pulsing mess with gas containing 10% Ethanol. Switching to ethanol-free gas eliminated all those symptoms.
I've experimented with to 10% ethanol gas, only to have those symptoms reappear after several miles of driving.
Same deal when going back to ethanol-free gas, all abnormal engine noise just seem to vanish after a few miles of driving.
TennisHsu is offline   Reply With Quote
The Following User Says Thank You to TennisHsu For This Useful Post:
metalmoses (02-25-2013)
Old 02-26-2013, 01:36 PM   #26
Allch Chcar
Drives: N/A
Probably a fluke, several people ran pure gas only to have the chirps come back after awhile.
Weren't there recalls for the idle dip and chirps?
-Allch Chcar
Old 02-26-2013, 01:38 PM   #27
CrazyWookiee
Drives: Whiteout FR-S
The canadian is a bit slow on updates and listing. Alberta says only CO-OP has ethanol free, but I know Super Store's 91, Hugh's 91 and All the Shell V-Power 91 are ethanol free.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 02-26-2013, 02:01 PM   #28
blackraven1425
Drives: raven at
Did you try adding them? Otherwise, it might just be that nobody posted them. Also, a couple of those are listed as "all stations" on the website, I don't know about the app:
Alaska: all stations dispense ethanol-free gasoline.
Alberta, New Brunswick, Newfoundland, Nova Scotia, PEI, Quebec: all stations dispense ethanol-free premium.
British Columbia: Chevron 94
Ontario: Shell V-Power 91; Costco 91; Canadian Tire 91; Esso 91; Ultramar 91
The Following User Says Thank You to blackraven1425 For This Useful Post:
CrazyWookiee (02-26-2013)
Premium unleaded w/o Ethanol? - Thurston Co.? PNW FRS Northwest 1 01-17-2013 02:52 AM
Where to get non ethanol fuel? mhigham Engine, Exhaust, Transmission 19 11-13-2012 11:27 AM
Ethanol fuel treatments JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-19-2012 11:42 AM
Website that locates ethanol-free fuel wbradley Issues | Warranty | Recalls / TSB 8 07-24-2012 12:47 AM
