Old 02-21-2013, 05:46 AM   #29
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Name:  ImageUploadedByTapatalk 21361443578.355689.jpg
Name:  ImageUploadedByTapatalk 21361443594.901709.jpg
86•BRZ is offline   Reply With Quote
Old 02-21-2013, 08:14 PM   #30
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
Got the tires today and will be getting them mounted tomorrow.
Pilot Super Sports 245/40/17
23.1lbs on bathroom scale
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 02-21-2013, 09:33 PM   #31
Captain Insano
I like this in +35.
Captain Insano is offline   Reply With Quote
Old 02-22-2013, 01:54 PM   #32
wgnzlz
wgnzlz's Avatar
Got the tires mounted today and put them on the car to see what it looks like at the stock ride height. Excuse the picture quality, they were taken with my phone.
PSS mounted on wheels, 39.3lbs.
Stock wheel and tire, 40.9lbs.
245/40 vs 215/45
Some pictures on the car.
The Following 3 Users Say Thank You to wgnzlz For This Useful Post:
akahenry (01-03-2014), BR-ZED (04-21-2017), normancw (04-10-2013)
Old 02-22-2013, 03:54 PM   #33
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I wish I could get et35 for the rear and 45 for the front.
Old 02-22-2013, 04:11 PM   #34
wparsons
wparsons's Avatar
+45 with a 5mm spacer out back looks perfect to me.
flickr
Old 02-22-2013, 04:53 PM   #35
wgnzlz
wgnzlz's Avatar
To me, the poke looks worse in pictures than it really is. I think after its lowered and a little negative camber is dialed in up front, it will look perfect.
Old 02-22-2013, 05:11 PM   #36
alex88
alex88's Avatar
Drives: whiteout frs
Looks great man! Where did you get your PRF1's?
I am considering going with 17x8+35 Enkei RPF1, 245/40 tire. Is there a reason why you didn't consider the 8in wide wheel?
alex88 is offline   Reply With Quote
Old 02-22-2013, 05:15 PM   #37
wgnzlz
wgnzlz's Avatar
Thanks. I got them from Dezod Motorsports, but I think Ft86eedfactory might still have a set left and they are on the forum. I went with 9" over 8" to get the flat face.
Old 02-22-2013, 05:22 PM   #38
alex88
alex88's Avatar
Are the 8 in wheels really bent? I was hoping they would be closer to 9in than 7in especially with the +35 offset
Old 02-22-2013, 05:24 PM   #39
wgnzlz
wgnzlz's Avatar
From what I've seen, the offset doesn't change the wheel design. The rpf1 doesn't get the flat spoke look until you go 9" width.
Old 02-22-2013, 05:25 PM   #40
BlaineWasHere
Grip>Drift
Drives: FRS
You can run up to 9" for STX so why not? I'm running 245/40 on 17x9 and like it more than 245 on 8" that I had on my last car.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
alex88 (02-22-2013)
Old 02-22-2013, 05:28 PM   #41
BlaineWasHere
Grip>Drift
Drives: FRS
For sure. A little negative camber will do wonders.
Old 02-23-2013, 09:39 PM   #42
Captain Insano
Looks awesome. I just pulled the trigger on tc105n in 17x9 +35 so VERY helpful to see how ur setup fits. I am dropped 1" on eibach pro springs with -1 front & -1.8 rear camber. Plan to get same tire size as you!
Feldy I PMed you about that smaller size to not threadjack...
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
