Old 02-21-2013, 12:52 PM   #15
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by Porsche View Post
The alarm system is standard on the 2013 Subaru BRZ Limited model only.
For Canadian owners: alarms are provided on both models. Per the specs on the SOC site, both have the following :
Security: Anti-theft system
Security: Engine immobilizer system
Security: Keyless entry system with panic alarm
Sport-Tech is offline   Reply With Quote
Old 02-21-2013, 09:36 PM   #16
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
[QUOTE=Porsche;748159]Then I suspect that your alarm system is NOT activated.
"The initial flashing merely indicates that the Engine Immobilizer is activated. This system is on all cars, with or without the Subaru alarm.
If the alarm system is ON, then AFTER locking the car, the red lock symbol in the instrument cluster will light STEADILY for 30 seconds, NOT flashing, following locking the car. After this initial 30 seconds, then the lock symbol will begin flashing.
Obviously, this requires visual confirmation following locking the car.
One way to test your alarm to confirm that it is ACTIVATED and ON is to open a window, close the doors, lock the car, remove the key from the vicinity of the car so it is no longer sensed by the car, then return to the car, reach through the open window and unlock the car and open the door. If your alarm is activated, the alarm should sound. If not, then the alarm has not been set.
The "trick" to activating the alarm system is to open the door IMMEDIATELY after first pressing the UNLOCK button. Any delay will result in a failed attempt to set the alarm."
You were right. Re did it while opening the door immediately like you said and heard the honk and saw Al On this time in the dash...
JSUB is offline   Reply With Quote
Old 02-21-2013, 11:43 PM   #17
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
worked for me it beeped and said "AL ON" on the dash cluster
2013 WRB Subaru BRZ Sport-Tech
-TRD intake
-Perrin 2.5 inch cat-back exhaust
lavisxice is offline   Reply With Quote
Old 02-22-2013, 11:05 AM   #18
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
I need a video to show. im retarded i cant figure it out
Marcoscrdo is offline   Reply With Quote
Old 02-22-2013, 01:43 PM   #19
JSUB
JSUB's Avatar
Ok...you can do this buddy!
Sit in the car.
Close all doors (and keep unlock).
Put ignition On (engine not running and all lights on in the dash).
Hold the switch "the unlock door switch" on the driver's door (like you want to unlock the doors) AND
simultaneously (meaning right now) open the driver's door (with your other hand) while STILL holding the unlock button switch...and wait till you hear the honk and see "Al-On" in your dash (bottom of RPM display).
Should work if you do it fast. If not just retry.
Let us know...
Old 02-22-2013, 03:05 PM   #20
Marcoscrdo
Marcoscrdo's Avatar
Sit in the car.
Let us know...
I will keep trying i swear ive tried that lol, but where should the "Al-On" show up? I will try again and let you know. Thanks!!
Old 02-22-2013, 05:29 PM   #21
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
I thought that I'd activated the alarm months ago because I followed the procedure in the manual and heard the horn beep. However, I'd never seen the interior lights go on when I approached the car, nor had I seen the red lock light stay solid on for 30 seconds. This thread got me thinking about it, and I went ahead and used your instructions rather than the manual and voila! I read "al on" in the readout and now the interior light comes on when approaching the vehicle, and the lock light stays solid red for 30 seconds before blinking. Thanks! Curious to see if the OP had the same result.
davesrave is offline   Reply With Quote
Old 02-22-2013, 05:57 PM   #22
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
on ur dash where the odometer usually is!
-TRD intake
The Following User Says Thank You to lavisxice For This Useful Post:
sklimo (02-24-2014)
Old 03-02-2013, 06:16 PM   #23
Marcoscrdo
Marcoscrdo's Avatar
Sit in the car.
Let us know...
Omg it worked!!! I just had to hold it longer lol, supposed to hold it for a while I thought was supposed to instantly happen
thanks!!! Wow this whole time was off, so now that its on that means alarm will go off if doors open?
Old 03-24-2013, 01:14 AM   #24
Boris Badenov
Boris Badenov's Avatar
I just got my BRZ today! I activated the alarm, but noticed that the indicator light with the lock superimposed on a car continuously flashes when the alarm isn't set. Is this normal?
Boris Badenov is offline   Reply With Quote
Old 03-24-2013, 01:42 AM   #25
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I'm a bit confused. Is this button dance thing the same as the dealer activating the alarm? Or does the dealer have to activate it, then the user/owner has to turn it on doing this?
Freude am Fahren is offline   Reply With Quote
Old 03-24-2013, 02:03 AM   #26
Burrcold
Drives: Subaru BRZ Limited
It's one or the other. Either the dealer already activated it, or you follow these steps to do it yourself. In my case, I had to do it myself.
Old 03-24-2013, 02:09 AM   #27
Boris Badenov
Mine wasn't activated when I got it either. I wouldn't mind the flashing light when the alarm is armed. But it appears that the light flashes when the alarm isn't armed. I'd prefer no light if it's not active...
Old 03-24-2013, 08:23 AM   #28
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I am, SO GLAD I got the Premium model.
BRZfan is offline   Reply With Quote
Alarm Systems 31katys Northwest 8 07-11-2014 03:05 PM
Alarm Sigh-on-Rice Hawaii 11 05-24-2013 02:15 PM
After market alarm Yruyur Electronics | Audio | NAV | Infotainment 11 11-24-2012 08:38 PM
FREE ALARM but... Silverback Scion FR-S / Toyota 86 GT86 General Forum 18 09-26-2012 04:51 PM
No Alarm? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 40 07-08-2012 11:35 AM
