Old 11-09-2011, 03:36 PM   #57
Aki
Drives: '96 beater Corolla
Originally Posted by MatadorRacing_F1 View Post
Air suspension kit so my veilside bodykit and or exhaust can drag on the floor.
Bah too late 90s. Gotta have 18.9.5 et0 rims with 205/35/18 tires, Yakima roof rack with a fixie bike perched atop, Hellaflush sticker on rear windshield. And you know they're acomin'...
Aki is offline   Reply With Quote
Old 11-09-2011, 04:15 PM   #58
Matador
hashiryu
Drives: Mk4 Supra
with 30 deg -ve camber?
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 11-10-2011, 12:14 AM   #59
Chokonen888
Drives: Seibu Shinjuku Line
Originally Posted by mkivalex View Post
19'' wheel = goodbye fun nimble car, too much unsprung weight for a car like this IMO. plus you would have to use rubberband tires.
And yes Obviously I cant make these parts until the car is parked in my garage, but I plan on picking one of these guys up right away, and then right to work on some development.
If all is well I would hope to have a few designs ready for production within a few months of the car being out.
Good wheels weigh less than tire rubber...
...but 19" on this car? Might as well raise it up and call it a donk.
Chokonen888 is offline   Reply With Quote
Old 11-10-2011, 02:45 AM   #60
NorCalRider
Drives: 2009 Toytoa Tacoma 4x4 Dbl Cab LB
It seems there will be quite a few of us developing parts. I know my FR-S/BRZ will go from the dealership to the shop for tear down and measurements. I have quite a few ideas brewing and can't wait for this car to arrive.
2013 SWP BRZ Limited(on order)
2012 Vw Jetta Sportwagen TDI 6mt Navi and Pano
2009 Toyota Tacoma 4x4 Double Cab Long Bed
1994 Honda Civic HB TurboCharged Track Car
NorCalRider is offline   Reply With Quote
Old 11-12-2011, 01:26 PM   #61
SHINCHU86
SHINCHU86's Avatar
Drives: 98 z28 but i miss my ae86
Originally Posted by blur View Post
ITBs
THIS.
and cams. i would love to see tons of NA tuning support.
also yes to carbon/lightweight mods to keep things practical and in the same ideals the designers had when developing this awesome car. not sure if i would get a carbon hood though, since OEM is aluminum already. (if i read that right somewhere?)
Sold my 94 S14 for a 1998 Z28 Camaro. Woops.
Springs, Shocks, Sways, Bushings
Cam, Lid, magnaflow catback, BBK intake manifold, LS7 lifters, ECU tune. good for 400 hp.
sure its fast, but it drifts like a boat.
SHINCHU86 is offline   Reply With Quote
Old 11-12-2011, 03:34 PM   #62
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by SHINCHU86 View Post
THIS.
Then you might as well add a few more things to your list.
  • Ti retainers
  • Stiffer valve springs
  • Oversized valves (possibly Ti, or Sodium filled)
  • Higher Comp. and/or lightweight Pistons
Because you're going to need revs, and plenty of them.
old greg is offline   Reply With Quote
Old 11-12-2011, 06:39 PM   #63
SHINCHU86
SHINCHU86's Avatar
yeah a good valvetrain is important for sure.
not sure about higher comp pistons though. i mean, 12.5:1 is not high enough?
im in CA and we only get 91 octane. more compression is uh, not going to play nice i think.
oh, i would like to add some sort of tuning module. somehting like AEM or greddy. piggyback i guess. something with a nice GUI for the average not so tech savvy guys (like me) to use.
its going to be interesting to see how the engine responds to aftermarket parts.
Old 11-12-2011, 07:06 PM   #64
chopstickz
Drives: Boost.
Originally Posted by Dark View Post
CF hood, Trunk, Duck tail.
Those would be compatible with both FRS and BRZ.
Theres not going to be much weight savings with this car... with those mods, I'm sure the hood and trunk is aluminum.
chopstickz is offline   Reply With Quote
Old 11-12-2011, 07:13 PM   #65
old greg
Rocket Surgeon
Drives: PSM GGA OMG
not sure about higher comp pistons though. i mean, 12.5:1 is not high enough? :confused0068
if it can run 12.5:1 on pump gas, it'll probably handle 14:1 on E85
Old 11-12-2011, 11:42 PM   #66
serialk11r
Drives: '06 AM V8V Coupe
It's direct injected, so probably more than 14:1 on E85 since ethanol has like what 30 times the cooling capacity per unit mass?
Old 11-13-2011, 04:56 PM   #67
Godzilla35
Drives: Nissan GT-R
I will most likely be developing body / aero for this car. Attempt to collab with some engineers using CFD (since I don't have money for a wind tunnel). But also, just come out with tasteful (hopefully) add on parts as well... Nothing is forsure until we see the final product of course.
As for the LSx comment... I am fairly certain the engine WILL not fit.... but another one has been fitted, which you guys will see soon I think. *hint* This was a low-key bit of info passed to me by an insider. Can't say more.
Godzilla35 is offline   Reply With Quote
Old 11-13-2011, 05:09 PM   #68
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Hey man you have got to hook us up with some of those aero kits
I personally would like to see an exhaust so it can sound like an Impreza
I love that exhaust, or at least one that sounds like the 2jz, but that's harder, being a I6
Snoopyalien24 is offline   Reply With Quote
Old 11-13-2011, 07:22 PM   #69
Dark
Elite Padawan
Dark's Avatar
You're right if those come aluminum. Then it would save me a couple hundreds or even a thousand to buy other mods.
Dark
Dark is offline   Reply With Quote
Old 11-13-2011, 08:06 PM   #70
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Man the car is already light and it is pretty well loaded in the high-spec trim at 2711 pounds.
The car doesn't even have an aluminum suspension...so we know the hood is aluminum and probably the trunk. Sure the car is about the size of a 370z so that helps too.
I say go for some good light weight forged rims. I wonder how much the stock rims weigh?
tripjammer is offline   Reply With Quote
TRD Parts for FR-S / 86 Revealed! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 410 02-22-2012 11:04 AM
Aftermarket wheels chopped onto Modellista 86 JDM-dono FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 12-20-2011 04:20 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
after market parts serchmarc Scion FR-S / Toyota 86 GT86 General Forum 90 05-31-2011 08:18 PM
Toyota FT-86: a goldmine for aftermarket parts Axel Scion FR-S / Toyota 86 GT86 General Forum 16 12-27-2009 10:16 AM
