| CANADA Canada |
#15 |
Drives: Black on Black on Black
woah, all i see in here is an opinion and as far as the word meh goes last time i checked i use that for good things, bad things, and when i don't care about things...
#16 | |
#17 | |
Drives: TBD
Update - I have submitted an email request for clarification, no-one is at HQ to talk to as they are all at the show. Last edited by Sport-Tech; 02-21-2013 at 01:09 PM. |
#18 |
No point, there is zero difference in the drivelines. The differences are limited to bumpers, spoiler (or lack of), head unit, HVAC controls and front seat material.
#19 | |||
Drives: 99' SIR Kswapped Racer/Showcar
I reserved my opinion as I knew how it would be taken.
Completely wrong context for the use of the word hate but nice try. Quote:
Morons gonna be morons. See above for the firt hater reply. Quote:
If this were in fact a case of hate I would have explained what is was exactly I didn't like. My general impression of the "build" is meh. I've seen more done with less effort but for Canada I guess it's kind of a big deal.. but not to tuners. Sorry my opinion doesn't serve the masses. It is afterall my opinion. |
#20 |
Drives: hybrid + racecar + FR-S
Like I said, I don't think Orthow was hating. Just stating that its "meh" relative to tuners.
That is the key point. To tuners. Its "meh". And I agree. For that crowd, I have a full blown race car. I've built full blown race cars and modified cars w superchargers and bbk's and volks etc. But as I stated, this vehicle was meant to show the mild. The mild has clearly garnered enough mainstream media attention. Becuz. U know what? The mainstream group of ppl are not tuners. Don't shop at nextmod or even know what it is. But actually drive corollas and 4 door civics and other relatively mild (compared to a tuner-scene car) cars. So if the objective is to show what a mild FRS can be that will garner attention of the masses - then I think that objective has been met. Could you highlight some examples of how more could be done with less in order to meet my objective?
Team Lexus IS300 race car '14 Lexus RX450h Sport Design daily driver '14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp! |
#21 |
Showing ppl spectrum was also the objective. Right next to my car was a full blown "non-meh" FRS!
I should add that the point of me posting this in here was to show the possibilites of mild. And that it is on display at the CIAS. Everyone is also entitled to their opinions. But opinions don't drive success. Planned objectives + solid execution drive success. Part of the reason why some ppl may view opinions as wasteful is because they don't help drive anything or push anything forward. Constructive opinions however, DO push things forward. So I look forward to hearing how more can be done with less. I am open to hearing some ideas. One more thing. In order to help facilitate the discussion, I should explain my choices to achieve the objective. The choice of orange was because my racecar is orange. And its also a head turner. The choice of asseto garas was because it was inexpensive for an 18" wheel (18 needed for head turning) So balancing inexpensive + head turning was a target.
#22 | |||
Drives: TBD
Also I have an official Subaru options sheet PDF entitled "Canadian BRZ options" and dated 20/4/2012 that lists all the code numbers for model, paint etc., prices (correct), and every known Sport-tech option (most listings omit the minor items: heated seats, vanity and courtesy lights, and silver trim). It adds (for the Sport-tech only): Quote:
#23 |
If you look at the Subaru site right now, it lists both models as having the 294x24mm front rotors and 290x18mm rear rotors.
http://www.subaru.ca/WebPage.aspx?We...&WebSiteID=282 The FRS also has 24mm thick rotors: http://www.ft86club.com/forums/showthread.php?t=16252 Forget the Subaru marketing stuff from before launch, the brakes are identical on both trim levels. They all get 2 piston sliding front calipers and 1 piston sliding rear calipers too.
#24 |
Drives: SOLD...
Someone (with a car) get out there and measure em!
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
| The Following User Says Thank You to Skurj For This Useful Post: | Sport-Tech (02-22-2013) |
#25 |
Drives: TBD
I mentioned that myself, but the Subaru rep checked her internal info and said (and I repeat) the site is wrong. I hope to get more from a product specialist/manager after the show.
#26 |
The only difference in brakes listed anywhere I can find is the Australian GT86 GT, which has 277mmx24mm discs up front and 286mmx10mm discs in the back. The Australian GTS has the same brakes as the FRS and BRZ.
If somehow the base BRZ here comes with the smaller brakes it should be pretty obvious since they're about an inch smaller in diameter. If you want a solid answer call a parts guy and ask for part numbers for both models. If you do that, also check to see if that's something new after a certain build date since I've seen no indication by aftermarket companies that there's a difference up to this point. http://www.ft86club.com/forums/showthread.php?t=21267
#27 |
Drives: TBD
The rotors are not supposed to be smaller on the base model, they are thinner, so it won't be evident from a quick visual comparison across models (I did one at the auto show, saw no differences, but I did not check thickness). Australian GT86 case is not relevant here.
#28 | |
Sarcastic SOB
To the OP, 40 mm rotors really? Over an inch thick? Think about it. To the owner of the GT3 styled FR-S: nice! I had no idea you were a serious racer. Rallying! Very cool man! If anyone wants a Pat Cyr Formula D poster just PM me. I have 2 extra ones.
| The Following User Says Thank You to wbradley For This Useful Post: | l8apexr (02-24-2013) |
| CIAS '13 | Sport-Tech | CANADA | 7 | 02-15-2013 04:33 PM |
| CIAS: Does it look better in the flesh? | Sport-Tech | CANADA | 14 | 02-23-2012 04:39 PM |
| CIAS 2012 Media Day Photos | RobStar86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 26 | 02-23-2012 02:06 PM |
| CIAS Talk with SCION...No red stiching at all for Canada???? | mankarn86 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 02-21-2012 02:33 PM |
| Scion FR-S Launch at the CIAS in Toronto | rL-gT | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 02-18-2012 04:50 AM |
