Old 02-05-2013, 06:39 PM   #15
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
I'm getting this sound now too. 2200ish miles. Also have the crickets and a very odd lope. Kind of sounds like it's misfiring. On top of this, last night I walked out to the garage and the rear of the car just started buzzing. I didn't even touch it.
Needless to say, it's in the shop now and I'm rocking a loaner Outback.
Jaylyons1 is offline   Reply With Quote
Old 02-05-2013, 11:50 PM   #16
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I'm having this sound as well but I'm not sure if its the natural resonance of the exhaust system or loose exhaust shields. If it were loose exhaust shields I would think that the noise would be present throughout the rpm range, but the fact that we all experience the sound at the same rpm would lead me to believe its a natural resonance. I've experienced this in other cars.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
tripjammer (02-19-2013)
Old 02-19-2013, 06:53 PM   #17
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Folks I got this sound too. It's got to be the sound tube rattling on the intake manifold. I might try that rubber thing fix. And get those heat shield bolts fixed on my first trip to the dealer.
tripjammer is offline   Reply With Quote
Old 02-19-2013, 10:00 PM   #18
whtchocla7e
Drives: 2013 FR-S Hot Lava
Originally Posted by Panecki17 View Post
Just an update - I removed my sound tube (and plugged my intake and firewall holes) and that seemed to cure the problem. No more weird noise/vibration. Interesting.
Most likely the sound tube delete didn't cure the problem, it just masked it.
The sound tube amplifies all sound (including noise) and sends it into the cabin.
The noise could still be there, just not enough for you to hear it.
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following 2 Users Say Thank You to whtchocla7e For This Useful Post:
FT86Z (04-20-2018), tripjammer (02-19-2013)
Old 02-19-2013, 11:57 PM   #19
tripjammer
tripjammer's Avatar
I got some perrin exhaust tips attached to the stock exhaust. I thought I was them rattling but they are on tight. It sounds like it's coming from the sound tube. I heard it a little bit today, but later on in my driving I did not hear it at all. It's only at 4k to 5k rpms....weird.
Old 02-23-2013, 04:06 AM   #20
shrike92
shrike92's Avatar
Drives: '13 CBS BRZ
I have the sound as well. Mine goes away after about 20 minutes of driving. Is this the same for you guys or does it happen all the time?
shrike92 is offline   Reply With Quote
The Following User Says Thank You to shrike92 For This Useful Post:
tripjammer (02-24-2013)
Old 02-24-2013, 10:14 AM   #21
tripjammer
tripjammer's Avatar
It does seem to go away slightly after the car warms up.
It's definetly the sound tube rattling on the manifold cover or the lower engine cover bolts.
Old 03-16-2013, 10:41 AM   #22
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I got it too! I tightened up the heat sheild near the overpipe and put some o rings on the loose under engine cover bolts. Still have the noise. No noise generator on my car. this seemed to develop after installing my overpipe. The flange is awfully close to the hestshielding but i don't think its the problem. I'm thinking of removing the heat shields completely on the header and putting exhaust wrap on it. I don't know but anyone that has fixed it please chime in.
FastLane1000 is offline   Reply With Quote
Old 03-16-2013, 04:19 PM   #23
tripjammer
tripjammer's Avatar
I would wrap it...
I have not done anything, and I don't have the noise anymore.
Old 07-05-2013, 02:12 AM   #24
Chele
Drives: WR Blue BRZ
Did someone find out where this rattle is coming from? It happens at 4k rpm and it goes away by 4300 rpm . It sounds like a loose heat shield. Only happens under load.
I have a perrin silicone hose so the noise generator is gone.
I put a few washers in the lower engine cover so its all tight in there and i still have it. All bolts are torqued to spec.
Someone mentioned the shifter, which I also removed to try it out without any luck.
I had it before I installed the perrin overpipe, so its no that.
I'll be installing a Vortech SC in the next few weeks so I really want to fix it before that.
Please someone point me in the right direction.
Chele is offline   Reply With Quote
The Following User Says Thank You to Chele For This Useful Post:
juliog (03-20-2014)
Old 08-14-2013, 10:21 PM   #25
Animal63
Drives: 2013 ultramarine scion fr-s
Cricket sound
Well about the cricket sound! I took mine yesterday to the dealer, drop it off at my lunch hour, and by 3:00pm they had the noice gone! They told me that the high presure fuel pump is the cause, so the replaced it under warranty...so far the noise is gone and all i hear is the sound of the engine. The other sound on the rear i heard is normal! But i havent experience it. Good luck
Animal63 is offline   Reply With Quote
Old 08-14-2013, 10:25 PM   #26
Jaylyons1
Jaylyons1's Avatar
Don't worry, they will return. I had my pump replaced as well and they came back after about another 1000 miles. So far everyone I have talked to that has gotten it warrantied has had the crickets return. One guy actually said they were louder during the second coming. Mine aren't as loud but they are still quite offensive to my ears.
Old 08-15-2013, 09:01 AM   #27
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Still curious if anyone found the reason. I get the same vibrations.
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 08-15-2013, 03:37 PM   #28
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I have a rattle coming from the support bracket for the front pipe. U guess the bolt got loose. And then the pipe moved under load and repeatedly hit the bolt... That caused the bolt to become misshapen and not screw in all the way.... Replaced the bolt and made sure it was tight...2 days later the eagle came back. I need to figure out why the bolt won't stay tight.
Anyone have a similar problem?
Propaganda is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 05:52 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
