Old 02-19-2013, 10:37 AM   #57
Hix
Hix's Avatar
Drives: 2017 WRB PP
WOAH Woah woah woah... That is crazyness... I need some info on the girl in your avatar.
Hix is offline   Reply With Quote
The Following User Says Thank You to Hix For This Useful Post:
1strwdcar (02-19-2013)
Old 02-19-2013, 11:02 AM   #58
Subforever
Drives: SWP BRZ
I just sent your photos to my Service Manager he will be in touch with Subaru Canada today about this issue.
They will probably take a car on the lot to check everything.
I will let you know.
Anyone contacted SOA ?
Subforever is offline   Reply With Quote
Old 02-19-2013, 11:44 AM   #59
Turbowned
Turbowned's Avatar
Great, so when I get my BRZ I can't even let myself drive it until I tear the f#%ker apart and seal all these, and opti-coat the exterior and do clear bra. Anyone making replacement carpet that's more plush than the $#!tty stock carpet? Might as well do that while it's all apart... At least I have no plans to drive mine in the snow...
Old 02-19-2013, 12:17 PM   #60
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I dont think sealing that hole might be a good idea. It will make a nice place for water to settle in from condensation (if you live in a cold climate area). The doors have drain holes and are exposed to the outside elements.
I would personally shoot rust protectant in there and call it a day.
Rayme is offline   Reply With Quote
Old 02-19-2013, 12:54 PM   #61
1strwdcar
Drives: 2013 scion frs Whiteout
Thanks i go in for first oil change Saturday
1strwdcar is offline   Reply With Quote
Old 02-19-2013, 12:57 PM   #62
1strwdcar
This is body sealant! Its what auto manufacturers use to seal body panels where water could sneak in. Every car is loaded with casmoline and body sealant. I wont seal the water in since the car is dry now. And im not gonna seal the does. They are already filled with casmoline. (Oily wax) and yes all cars havw that too.
Old 02-19-2013, 12:59 PM   #63
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
If this turns out to be a real problem, we might have to take it to Autoblog/Jalopnik/TTAC to generate a little pressure for a fix....
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
Old 02-19-2013, 01:31 PM   #64
Marrk
Drives: Honda Fit
Originally Posted by cf6mech View Post
You obviously never have lived in the rust belt, earlier Japanese cars rusted like crazy there, A buddy of mines (bought new) Totota p/u had total rust threw in 3 years, like dime size holes. They have gotten better but the old Jap cars,.... you could almost watch them rust.
I lived in New York and New England for a few decades. Don't know if that counts.
I'm just wondering what era of Japanese car it is that you keep referring to. There were Japanese cars that I recall on the streets of the U.S. as early (in my memory) as the early '60s. Are these the infamous "rust buckets" of Nippon? And which of these terrifying marvels of oxidation have you owned personally?
Again, just wondering.
Marrk is offline   Reply With Quote
Old 02-19-2013, 05:32 PM   #65
Employee
Drives: XXX
Originally Posted by 1strwdcar View Post
That is a stamped hole (for a datum pin)they would not cover it with sealer it's simply too big. It is either something missing or a drain hole.
Employee is offline   Reply With Quote
Old 02-19-2013, 05:35 PM   #66
1strwdcar
I know that now. Pointing to another crack look at first post
Old 02-19-2013, 06:43 PM   #67
Employee
Drives: XXX
Okay I see what you are pointing at. There is no light inspection that anyone would see a gap like that. The water test wouldn't show it as the location would not likely be a focus area. Again it's hard to see a quick easy fix is a heat gun and marine grade sealant Canadian Tire. That's all they will do if you take it in for service. If the other hole is a drain hole I wouldn't be worried about the gap.
The Following User Says Thank You to Employee For This Useful Post:
Old 02-19-2013, 07:07 PM   #68
1strwdcar
Okay I see what you are pointing at. There is no light inspection that anyone would see a gap like that. The water test wouldn't show it as the location would not likely be a focus area. Again it's hard to see a quick east fix is a heat gun and marine grade sealant. That's all they will do if you take it in for service. If the other hole is a drain hole I wouldn't be worried about the gap.
Yep like i said ill probably repair it myself
Old 02-20-2013, 10:17 AM   #69
Turbowned
Turbowned's Avatar
Any old car is usually a rust bucket if it was daily driven in New England weather, regardless of what country it came from. I know the Japanese cars were more susceptible to it only because the metal they used was lower quality for a long while. I've seen plenty of rusty Datsuns on my quest for a clean 240Z (the one I bought had the fenders, quarters and floors replaced and still needed more work) and owned quite a few rusty MR2's. Then again I also had a rusty BMW 325i and Chevy Camaro. I will say this though; you don't see many pre-1985 Japanese cars in New England, and rust is likely a good reason for this.
Old 02-20-2013, 10:56 AM   #70
Hix
Hix's Avatar
Drives: 2017 WRB PP
This thread has lost all of it's charisma since the OP changed his avatar.
Drilling a Hole for Tow Hook or License Plate Hanakuso DIY (Do-It-Yourself) Guides 28 04-12-2019 06:02 PM
BRZ tow hook cover hole mod for license plate holder TSY BRZ First-Gen (2012+) — General Topics 19 05-10-2013 03:58 AM
Torque hole discussion jeebus Engine, Exhaust, Transmission 19 08-28-2012 08:51 PM
Mysterious microscopic hole Aznek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-09-2012 09:22 PM
New Theory: Every Black Hole Contains a Unique Universe. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 0 06-04-2012 10:41 AM
