Old 02-13-2013, 03:05 PM   #183
blkwrxwag
Drives: DS FRS
I don't think you'll want a bigger rear bar IMHO. Other than possibly making the car too loose, the diff won't like it.
blkwrxwag is offline   Reply With Quote
Old 02-13-2013, 03:06 PM   #184
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
In short yes. I would consider putting the stock rear bar on after you do the coilovers too.
EDIT: Max and typed the same thing more or less
TomR
ABQautoxer is offline   Reply With Quote
Old 02-19-2013, 12:14 PM   #185
Im_SPEED
Drives: FRS hot lava
well thats what i get of being a slacker.... the bar is on back order tell the end of the month..
Im_SPEED is offline   Reply With Quote
Old 02-19-2013, 01:37 PM   #186
zo7vette
Drives: 2013 Scion FRS - Hot Lava
Has anyone sourced some centering rings for this bar?
zo7vette is offline   Reply With Quote
Old 02-19-2013, 02:21 PM   #187
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
More are coming. As for locking collars, if you want them I can get them but we designed the bar to bend right at the bushing so you shouldn't need them. If you wan them, you can find them at most super home stores like a Lowes. 7/8" ID and run them inboard of bushings....
And more are coming, and it won't take long since all the early glitches are worked out.
Sam Strano is offline   Reply With Quote
Old 02-19-2013, 02:32 PM   #188
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Sam, on a car that has the stock struts and springs, running 225/45 tires on the stock wheels. Do you think its a worthwhile upgrade to do the front bar before coil overs? Or should I wait for coil overs and see how the car handles for me?
Ranatsu is offline   Reply With Quote
Old 02-19-2013, 02:42 PM   #189
Sam Strano
Sam Strano's Avatar
Well, a bar is certainly a lot more cost effective. But you are kind of comparing apples and oranges.
I can tell you that the way every coil-over setup comes (spring rate wise), I'd put a front bar on with any of them. I have KW's with a stiffer front/softer rear setup than they come, and still run my front bar.
Old 02-19-2013, 03:16 PM   #190
Ranatsu
Cone basher
Hah, yea I do realize that its a backwards comparison. I only ask because I'm curious of the effect a larger front sway is going to have with the stock springs and strut.
Its more of a monetary mattery. I can't afford to buy coilovers right now, but other than seat time I would like to continue prepping my car for STX.
I may still consider the Koni's as I just read your other post about coilovers.
Thanks for your response though.
Old 02-19-2013, 03:21 PM   #191
blkwrxwag
Drives: DS FRS
I would defintely highly recommend the bar on a stock setup. It helps a lot controlling front roll, and taming the back end when you autocross.
Old 02-19-2013, 04:01 PM   #192
zo7vette
I have over an inch between the bushings and the bend in the bar, allowing the bar to slide back and forth quite a bit. Rings will be necessary.
Old 02-19-2013, 04:24 PM   #193
celica73
That was my experience. My bar kept moving all the way to the passenger side, and at near full steering lock the tire (passenger side) would rub the bar badly (245/40-17 Star Spec, 17x8-45mm wheel). A 10 minute drive around town was sufficient to get the bar to move over an inch laterally.
I ordered a pair of collars from Amazon, $17 with prime shipping.
Old 02-19-2013, 04:30 PM   #194
Sam Strano
Sam Strano's Avatar
Here's a link, they're about $5 each from McMaster-Carr (other places have them too). Remember you want a 7/8" ID, two-piece collar. http://www.mcmaster.com/#split-shaft-collars/=ljtsd3
Old 02-19-2013, 04:31 PM   #195
Sam Strano
Sam Strano's Avatar
I will look into getting them included in the next batch (in fact I already made the call).
Old 02-19-2013, 06:40 PM   #196
xwd
Interesting, I think my 2nd gen? bar there is no space between the bend and the bushing. In fact the bend starts before the end of the bushing with the bar centered so the bushing is a little pinched. I haven't had any problems with it moving.
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 09:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 07:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 07:52 PM
