| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
BTW did anyone notice MPG loss doing this or is it just that im a horrible driver? |
#30 |
Drives: SUBARWD
Shouldn't affect mpg at all since it's only diverting sound to the cabin. Love this little mod btw.
#31 |
Drives: JRSC'd Asphalt FR-S
Yeah you're probably just on the throttle more to hear the sound therefore affecting mpg, i know i am lol
#32 |
Drives: 86 GTS
Oh c'mon. There is no way this can affect mpg!
| The Following 2 Users Say Thank You to 86•BRZ For This Useful Post: | Charleswinky (06-21-2013), jeebus (12-21-2012) |
#33 |
I had to giggle too
#34 |
Drives: Honda Fit
Thanks for the DIY!
Just did it and got the app read it as 2 dB louder at 5000 rpms. Haven't taken it for a drive yet so I can't speak to that and I'm not sure about how accurate the app is, but there seemed to be a difference to me.
"When we first approached Subaru they couldn’t believe that our plans for a sports car wasn’t a four-wheel drive or a turbocharged engine. ‘Who is going to buy this car?’ they said." -Tada-san |
#35 |
Drives: WRB BRZ
i wonder what would happen if i modified a duck call and plugged it into the firewall......
![]() brrrrrrrroooooooooooooooOOOooOOOOOOOQUAAAAAAACCCKK KKKK |
#36 |
Ashes to ashes.
Drives: Asphalt FR-S
Did it. Sounds nice. Can hear the tap tap tap from my engine more though at idle :|
Sent from my Nexus 7 using Tapatalk 2
It is in change that we find purpose.
#37 |
Tire Destroyer
Drives: Firestorm+snail
I hear more tapping at idle too but that's because you hear more engine noise. I like it. FYI the soundtube just pops out from the rubber hose, moving it back and forth helped me. And also, there is foam inside along with a cross section of plastic, and 2 small foam pieces (on the sides). I removed all foam with a drill-bit and left the plastic cross section. I would recommend leaving the side foam pieces for others, they're small and could maybe reduce the idle tapping? who knows...
322whp/273wtq
#38 |
Drives: 2013 Firestorm FR-S
I did this mod yesterday and I would describe the sound difference as maybe slightly louder but more mechanical. I like it. Reminds me of some of the older (60's & older) sports cars. The side foam came out with a touch of the drill bit and the foam piece down on the plastic cross section just pulled out with needle nose pliers. I saved this foam plug in case I wanted to put it back, but I don't think so.
#39 | |
Drives: 13 BRZ Limited WRB
Usually only in 2nd or 3rd shifting. Anyways, I have full perrin intake and i've capped that tube, so I doubt it has anything to do with that.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 Last edited by Gopherboy6956; 07-08-2013 at 12:00 AM. |
#40 |
I did this mod a while ago, It definitely changes the sound a bit, but after adding my Invidia N1 I can't even hear the sound tube. All the sound is behind me. No complaints.
#41 |
Drives: 2013 BRZ SWP
anyone ever find out if in the elbow before the one that goes into the firewall if there is cotton ball and whatnot as well?
#42 | |
Drives: 13 brz, 06 STI
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car) 1988 CRX si- b16A1 (Sold) RIP 2003 WRX Last edited by Boosted; 06-21-2013 at 07:36 PM. |
| The Following User Says Thank You to Boosted For This Useful Post: | lxsedan (06-22-2013) |
| DIY - Installing TRD Sound Changer | Killerbee | DIY (Do-It-Yourself) Guides | 67 | 02-19-2015 02:31 AM |
| Remove intake sound pipe tube? | speedtrip | Engine, Exhaust, Transmission | 12 | 12-24-2012 05:01 PM |
| TRD sound changer | MACCAA | Australia Classifieds | 9 | 12-23-2012 11:42 PM |
| TRD sound changer! | Surok | Engine, Exhaust, Transmission | 2 | 08-26-2012 10:20 PM |
| The intake sound tube | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-09-2011 07:32 PM |
