Old 02-18-2013, 02:58 PM   #15
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Originally Posted by pete39sp View Post
I was thinking of putting one were the fog lights would go.
That's great if you don't mind risking hydro induction. A high mount intake port almost eliminates this completely and it's a short /direct air inflow path.
I've actually seen that port in a 350Z. I too believe it may not be car specific.
Wolfking is offline   Reply With Quote
Old 02-18-2013, 03:21 PM   #16
pete39sp
pete39sp's Avatar
Good point! After seeing the fog lights I'm getting some! I'll put the intake some ware safer. But my car stays in on most bad days!
Keep it safe but always have fun.
pete39sp is offline   Reply With Quote
Old 02-18-2013, 03:49 PM   #17
FasterpromsFRS
FasterpromsFRS's Avatar
Drives: FRS
There is no point in this, I cut a bigger hole right where the perforation is at the beginning of the nose, I can hear the intake(stock) sucking so much harder now. An aftermarket hole is not needed imo.
FasterpromsFRS is offline   Reply With Quote
Old 02-18-2013, 04:02 PM   #18
Shit Luck
Drives: red frs
its not about noise...
this mod is to lower the air temp at the intake.
somebody posted a log of intake temps between an afe and air raid intake, something like 15 degrees difference at the maf.
this would allow a much cooler air charge to reach the snorkle or filter depending on the intake you are running.
Shit Luck is offline   Reply With Quote
The Following 2 Users Say Thank You to Shit Luck For This Useful Post:
LeeMaster (02-19-2013), Tim_Asphalt_FRS (02-19-2013)
Old 02-19-2013, 01:42 AM   #19
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
This.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 02-19-2013, 02:20 AM   #20
sw20kosh
Drives: 2013 Black FR-S
This is not necessary if you are using the snorkel to funnel air into the intake (be it stock or aftermarket).
There is no problem with the stock snorkel or its location.
Old 02-19-2013, 08:26 AM   #21
Shit Luck
Drives: red frs
you can't tell me that this won't lower intake temps. You really believe the stock s orkle laying in front of the radiator/ on top of the bumper beam is pulling the coolest intake charge possible?????
Old 02-19-2013, 08:47 AM   #22
FT_Monk
Drives: Over the hill WRX
Yes it will lower the intake temp, But it will also makes the car run like crap.
FT_Monk is offline   Reply With Quote
Old 02-19-2013, 11:59 AM   #23
Shit Luck
Drives: red frs
more info?
the maf should calculate for this.
Old 02-19-2013, 12:36 PM   #24
sw20kosh
During the conditions you would WANT lower intake temps (ie moving) the heat from the radiator does not enter the snorkel because it is blown back into the engine bay. The only air it would be inhaling is cool air from the front air dam. Think about it please.
Old 02-19-2013, 12:47 PM   #25
Shit Luck
Drives: red frs
the snorkle is covered by the nose cone the bumper creates.
The radiant heat from the cooling system/engine will have raised the temp of the snorkle and the intake plumbing. Thus heating up the intake charge.
Old 02-19-2013, 12:51 PM   #26
2forme
LOL, the air is cold in front of the radiator, not so much behind it.
If an AFE has a delta of about 10 degrees above ambient and doesn't even extend into the bumper (but still sucks air from it), then there isn't much to be gained, temp wise, from this.
Old 02-19-2013, 01:01 PM   #27
Shit Luck
Drives: red frs
here is the info i was talking about..
Originally Posted by 2forme View Post
They have high speed dyno fans for wind simulation.
I've done temperature testing at the intake level on several intakes. The AIRAID is marketed as a CAI and was much hotter than the AFE which extends further towards the bumper hole.
This was done in 3rd on the freeway. Now imagine an SRI that sits even further back toward the motor.
*DISCLAIMER* this is just for comparison purposes, I am not trying to say the AFE is the best intake EVAR!
air raid uses the stock snorkle i beleive.
Old 02-19-2013, 01:03 PM   #28
2forme
Those tests were done without the snorkel. The snorkel has been proven to lose around 2-3whp on average. Airaid even suggests removing it for the most "power".
I F'd up my front bumper :'( TOTO_86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 48 08-14-2013 03:09 PM
WTB: Front BRZ WRB Bumper scraejtp Exterior Parts (Aero, Lighting, Etc.) 2 12-23-2012 08:56 PM
Front Bumper Lip ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-22-2012 12:29 AM
WTB: SWP Front bumper xjohnx Exterior Parts (Aero, Lighting, Etc.) 0 09-26-2012 11:57 AM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 03:30 PM
