Old 02-17-2013, 09:11 PM   #15
Hardrock4445
Hardrock4445's Avatar
Not trying to sound rude. But if you were a car guy you would top it up when you check fluids at fuel fill up. You never run out of any fluids that way!
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following User Says Thank You to Hardrock4445 For This Useful Post:
immortal_suby (02-17-2013)
Old 02-17-2013, 09:21 PM   #16
immortal_suby
Drives: 2015 BRZ Limited 6MT
In a pinch you can pee on the windshield. It works surprisingly well as a de-icer.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
The Following 2 Users Say Thank You to immortal_suby For This Useful Post:
Allch Chcar (02-18-2013), infinite012 (02-18-2013)
Old 02-17-2013, 09:22 PM   #17
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
Every time you fuel up? That seems a bit excessive on a modern car...
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
Old 02-17-2013, 09:26 PM   #18
Hardrock4445
A little pm goes a long way.
Old 02-17-2013, 09:27 PM   #19
The359
X Rated
The359's Avatar
Sure, a little. Every fill up is a tad bit more than a little in my book.
My BRZ
Old 02-17-2013, 09:33 PM   #20
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Originally Posted by Burrcold View Post
Really? I don't think I've ever owned a car that DIDN'T have one (the little icon on the gauge cluster).
This kind of answers the question. I work at a toyota mfg. auto plant and all the Camry's built that are Canada bound have the low windshield washer fluid indicator light on the meter cluster.
mdf4uk is offline   Reply With Quote
Old 02-17-2013, 09:42 PM   #21
Burrcold
Drives: Subaru BRZ Limited
I worked for Denso and was a project manager for the TMMC plant here in Cambridge (I've been to TMMK many times). I already knew that the indicator was on most of the Canadian vehicles, but from what I saw of the RX and Corolla production, most of the northern US states got it as well. (Denso actually produces both the washer tank, sensor, and the meter cluster for the Camry).
Old 02-17-2013, 09:49 PM   #22
NOHOME
Drives: RAVEN
Have to agree with you, never had a car without the indicator..
But dont worry, we do have a spare useless speedometer to make up for it.
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
Bg8780 (02-23-2013)
Old 02-17-2013, 09:52 PM   #23
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
yes, pee contains ammonia which has lower freezing point. highly recommended to pee in your windshield fluid reservoir or pee directly on windshield in case of emergency.
chenshuo is offline   Reply With Quote
Old 02-17-2013, 10:56 PM   #24
Hardrock4445
I don't do the half tank fill ups and the $10 dash and go. So I'm 1 1/2 - 2 weeks between, not a bother.
Old 02-17-2013, 11:18 PM   #25
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
must be on Canadian cars for snow/ice purposes
Old 02-17-2013, 11:19 PM   #26
n2oinferno
Praise Helix!
n2oinferno's Avatar
My Camry has an awesome indicator. When there's no more fluid spraying, that indicates I'm out.
The Following User Says Thank You to n2oinferno For This Useful Post:
BRZfan (02-18-2013)
Old 02-17-2013, 11:40 PM   #27
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
Civic, Celica's, Lexus IS, GTI, G35 Coupe, Genesis Coupe, Maxima, etc.
Don't have one in my GTI and it was dry to the bone.
Andrew360 is offline   Reply With Quote
Old 02-17-2013, 11:42 PM   #28
norsamerican
Drives: WRB BRZ
Most Canadian cars are equipped with a low washer indicator. google is your friend
Why this car in Canada doesn't i dont know
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
Deos this car not warn you when you are low on washer fluid? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 28 02-07-2013 12:00 AM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 04:18 PM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 02:06 PM
