Old 02-03-2013, 09:11 PM   #57
J-Money
J-Money's Avatar
Drives: GT-86
Originally Posted by sw20kosh View Post
You will be consuming 30% more fuel while tuned for e85 so the net effect may cancel out your cheap price for e85
id be saving more then the people that have e85 priced higher then premium.
Must be cheap cus we got all these dang farmers here in texas lol
J-Money is offline   Reply With Quote
Old 02-04-2013, 03:00 PM   #58
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Pure Automotive View Post
You do not have to drop the tank, there is access under the rear seat. The aftermarket fuel pumps are taller than the stock unit. As a result you have to lengthen the stock pump pickup to fit it. The injectors are where they would be on any car, on the intake manifold facing into the cylinder heads.
This is going to sound rude, but its real advice- if you do not know where the fuel injectors are by glancing at the engine, you probably shouldn't attempt to change them, the aftermarket injectors are taller and require a spacer, but if you put them in wrong it is going to be a hazard. The same thing applies to the pump, if you haven't done a fuel pump before, modifying the pump assembly is not a good place to try your first one. Again, I'm not trying to be rude, I just don't recommend messing with fuel components unless you are sure of what you're doing.
While doing the pump and injectors is not by any means easy. With proper photo documentation it can be done by an enthusiast in his driveway. I sure wish I had the FBM fuel pump photos before I put the pump back in and realized I wasn't getting any fuel to the fuel rails. Their pictures really me understand how best to modify the bucket to get the taller pump to fit. It involved a drill, hack saw, and zip ties.
Old 02-04-2013, 04:10 PM   #59
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I just tend to be a little cautious because, not every enthusiast has the know how that you do. I can tell you HORROR stories of fuel related installs gone wrong, but I also work closely with the Honda world which is a whole other realm of "enthusiasts", lol
Pure Automotive is offline   Reply With Quote
Old 02-04-2013, 04:23 PM   #60
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I remember doing a Walbro and 550cc injectors on an LS motor as part of a custom turbo kit build I did back in 2005. I think the install on a "Honda" was easier than the install on the BRZ was this weekend, haha.
Old 02-16-2013, 07:35 AM   #61
Unleashed
Unleashed's Avatar
Drives: 13' WRX
@Pure Automotive
Will you include pictures and install instructions with any kits purchased through you? Do you include the injector spacers? What are the estimated costs for an install like this one? How much would you estimate it costs to modify the oil pan accordingly?
Unleashed is offline   Reply With Quote
Old 02-24-2013, 04:27 PM   #62
Alhammadi
Drives: 2013 Toyota FT86
@Pure Automotive
Have you relocate the coolant reservoir to a different place? is it possible to install the piping without removing the passenger side head lights and the coolant reservoir?
Alhammadi is offline   Reply With Quote
Old 02-24-2013, 07:54 PM   #63
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by Alhammadi View Post
@Pure Automotive
Hey bud, we provided the brackets to relocate the reservoir
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Alhammadi (02-25-2013)
Old 02-24-2013, 09:18 PM   #64
Pure Automotive
@Pure Automotive
The reservoir still sits in the same place, just a new bracket. The passenger side piping can be installed without removing the headlight, but we chose to remove it because it allows for easier access, you have the bumper off already anyway, so its just a few extra bolts.
The Following User Says Thank You to Pure Automotive For This Useful Post:
Old 02-24-2013, 09:24 PM   #65
Pure Automotive
Originally Posted by Unleashed View Post
@Pure Automotive
There is a set of installation instructions/pictures that can be supplied to you. The injector spacers are included. I recommend professional installation at an experienced shop. Installation is going to vary based on where you go and what their labor rate is. It can be anywhere from $800 to well over $1000 depending on where you take it. I highly recommend having the oil pan mocked up and angled properly, then tack welding it in the car to ensure that it holds in the correct place and angle. Once it is tacked in place, remove it and take it to an experienced welder to make sure you get a perfect seal to avoid leaks.
Old 02-25-2013, 01:18 AM   #66
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I was hoping I'd be able to do this in my garage oh well.
How long does it take you guys to install the kit? Is it just a day or closer to a week?
campy is offline   Reply With Quote
Old 02-25-2013, 05:02 AM   #67
Unleashed
Unleashed's Avatar
Drives: 13' WRX
I say go for it then man. If you have the mechanical knowledge to install it and the right tools, go for it. Mock up the return on your oil pan by holding it in place and running the line to it to see where it will fit the best, leave some room for error (make it a little closer rather than further because you can always trim the line back some) and then drop the oil pan and take it to a professional to have welded on. I was quoted $40 by a local shop for them to tap and weld the fitting if i brought them the oil pan.
Old 02-25-2013, 08:11 AM   #68
Alhammadi
@FullBlown @Pure Automotive
Thanks guys appreciate the reply.
Old 02-25-2013, 12:06 PM   #69
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You can do it. I would plan for two full days if everything goes well, but levae a third as a backup. I just posted my thread about my install experience.
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
Review of ACT 6 Puck @ Pure Automotive Performance Pure Automotive Mid-Atlantic 3 01-10-2013 02:06 PM
**Everything Invidia is on SALE!!** @Pure Automotive Performance Pure Automotive Engine, Exhaust, Transmission 0 01-08-2013 02:32 PM
