#253 | |
hi
Drives: 2013 BRZ Limited
man.. i really like DGM.. i was so torn when it came to colors! Last edited by JEFFSTYLE; 02-15-2013 at 07:13 AM. |
| The Following User Says Thank You to JEFFSTYLE For This Useful Post: | Phaedrus29 (02-20-2013) |
#254 |
Custom made muffler delete from another forum member.
| The Following User Says Thank You to jshadeck For This Useful Post: | Minovsky (02-16-2013) |
#255 |
F Z1LLA
Drives: Lexus IS-F Series 2
![]() Thanks for the pics and info, took me less than 2 minutes to swap these wires Sent from my Note 2 on Omega Rom
2URGSE |
| The Following User Says Thank You to JPxM0Dz For This Useful Post: | Phaedrus29 (02-20-2013) |
#256 |
Drives: 2017 WRB PP
What the heck is this red reflector thing for?
#257 |
Lol mine made a great addition to "spare car parts bin"
But they are intended to be placed somewhere on the rear/side of your car as the states requires that all vehicles have an orange reflector on the front side (wheel well arch on the twins, which my clear sidemarker technically makes me illegal) and a red side marker on the rear/side (was built into the side of the stock taillights, colins dont have any reflector in them, just lights) |
#258 |
F Z1LLA
Just a heads up for anyone with a BRZ...
Here are the part numbers for Tail Lamp packing gasket if needed from Subaru 84940CA020 R/H $13.03 Canadian 84940CA030 L/H $13.03 Canadian
2URGSE |
#259 |
So nice!
I may have to have someone "accidentally" take a baseball bat to the OEM ones so I have a reason to replace them. I have had the good fortune to follow behind a Raven FR-S in traffic a couple of days this week, and I was underwhelmed by the amount of light the OEM taillights put out. It almost borders on a safety issue to me.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#260 |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
#261 |
((•||=(86)=||•))
Shit now the blue one is off the crimped end too
I guess I quit for the might I should have just cut and soldered them Shit |
#262 |
((•||=(86)=||•))
Aaaargh!
#263 |
If you were local id offer to fix for you :/
Worst case u can cut off the factory ones and splice them onto the new tails, then worry about the stock lights later |
| The Following User Says Thank You to jshadeck For This Useful Post: | FRS_Ken (04-05-2013) |
#264 | |
Drives: 2013 Subaru BRZ
The only thing I can think of is that maybe you aren't pushing the tab AWAY from the wire you're trying to remove...it definitely seems opposite of what you would think. The wifey helped me...so if you have someone with small hands and good eyes, try to get some help! |
| The Following User Says Thank You to Phaedrus29 For This Useful Post: | FRS_Ken (04-05-2013) |
#265 |
((•||=(86)=||•))
I guess I need to use a thinner wire than small flat screwdrivers?
Not same connector but similar design... [ame="http://www.youtube.com/watch?v=1tddRXRLcdU"]LS1 coil plug pin removal tool - YouTube[/ame] |
#266 |
It took me a fair amount of messing w it before i got the first one, then the second one was easy. Im trying to remember, there was a piece on the side that i popped loose first (doesnt come out but "releases") then i was able to use a thin nail to press on the tab inside the connector and release them from it
| TYC tail lights | doggy | Cosmetic Modification (Interior/Exterior/Lighting) | 90 | 02-13-2014 02:03 AM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| frs tail lights.. | frsguy707 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 11-11-2012 04:53 PM |
| Fatlace FR-S/BRZ Tail Lights? | Broz | Cosmetic Modification (Interior/Exterior/Lighting) | 69 | 11-02-2012 09:55 PM |
| Are you going to smoke out your tail lights? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-06-2012 09:02 AM |
