View Poll Results: Did your crickets return and how many pumps have been replaced?
My crickets are gone and the pump replacement worked 18 32.14%
My crickets are still here, and I've had one replacement 32 57.14%
My crickets are still here and I've had two replacements 3 5.36%
3+ Fuel Pumps replaced and still have crickets 3 5.36%
Voters: 56. You may not vote on this poll
Old 02-12-2013, 02:50 AM   #15
rider86
rider86's Avatar
Drives: 2013 Five Axis FR-S
Fixed at 8k; chirping returned at 9k.
rider86 is offline   Reply With Quote
Old 02-13-2013, 12:16 AM   #16
Gavin Albright
Drives: Scion FRS Whiteout
If you want it going switch to non-ethanal gas. I did and noticed a diffrence after 1 tank. Here is a link to stations that sale it.
I use this site to find stations
http://pure-gas.org/
Gavin Albright is offline   Reply With Quote
Old 02-13-2013, 12:33 AM   #17
Arctek83
Arctek83's Avatar
Drives: FR-S Raven
At first I had plenty of chirping, but since I've been using non-ethanol, no chirping going on here. But if I'm not near the station I go to, then I'll put a couple gallons of 93 with ethanol and the chirp comes back until I can get the good stuff in it. Another good reason for non-ethanol is not just to eliminate the chirp, but I've been getting better gas mileage (average 3mpg more) and noticeable performance...especially being that the comp ratio is 12.5:1
I plan on waiting until later to get a new fuel pump, since the TSB is good until 60 months/60,000 miles.
Arctek83 is offline   Reply With Quote
Old 02-13-2013, 07:23 AM   #18
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Mine returned and i just had another pump put on Monday.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 02-13-2013, 08:42 AM   #19
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I have no interest in having my car worked on for a noise that (based on the responses here) has a decent chance of coming back.
Admittedly I am biased as I have no interest in having my car worked on for a noise that has been stated to be no harm.
Chimpo is offline   Reply With Quote
Old 02-13-2013, 09:09 AM   #20
leon78
leon78's Avatar
Drives: 13 Whiteout
Holy fuck...this must be every ones first DI car...let it be...HPFP are noisy.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
The Following User Says Thank You to leon78 For This Useful Post:
Chimpo (02-13-2013)
Old 02-13-2013, 12:01 PM   #21
DieselxIndustry
Drives: 2013 Firestorm FR-S
My stealership now claims that its teh direct injection causing the noise and not the pump, I'm sick of this shit.
DieselxIndustry is offline   Reply With Quote
Old 02-13-2013, 12:12 PM   #22
mangostick
Drives: whiteout FRS
Originally Posted by Asphalt~86 View Post
I haven't had this issue but I know of ALOT of people complaining about this on other forums and threads.
I haven't had it either.. almost 4K mi on the car now and no chirping. Granted I also picked up my car in early december.. likely a later production run where the problem might have already been corrected on the assy line.
mangostick is offline   Reply With Quote
Old 02-13-2013, 10:14 PM   #23
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
i didn't wanna start a new thread or do an hr worth of searching, but if you don't get the chirping fixed, will anything break? or is it mostly just something noisy?
sofrsnsokleen is offline   Reply With Quote
Old 02-14-2013, 09:21 AM   #24
FR-S Matt
Nothing will break. The part is functioning just fine and doing its job. It's just making an "annoying" noise to everyone that sounds like crickets. The pump itself has no issues.
Until there is a new part number for the HFFP, I won't be replacing mine. I started this thread to see how successful Subaru/Toyota's TSBs are working out for FR-S/BRZ owners.
Old 02-14-2013, 11:01 AM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mine returned within a month. Or at least to a point, it's reduced though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-14-2013, 11:02 PM   #26
whtchocla7e
Drives: 2013 FR-S Hot Lava
No crickets 1500 after the pump replacement last month. Supposedly it was the newer pump version... but the car still sounds like shit at idle. You could say I traded one sound for another... Just can't win... I'm not going to worry about it anymore.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 02-23-2013, 12:30 AM   #27
EBMCS03
Drives: Argento FR-S
I finally noticed some sound from the hood today and opened the hood to listen to the engine while the car is on... i cant tell if I'm hearing this pump chirping or if its the direct injection ticking...
EBMCS03 is offline   Reply With Quote
Old 02-23-2013, 09:33 AM   #28
FR-S Matt
You can tell right away when you give it a little gas and let it go back to idle. If you hear the tone get more rapid then slow down to a chirp, you'll know it is the fuel pump rather than the DI.
The Following User Says Thank You to FR-S Matt For This Useful Post:
EBMCS03 (02-23-2013)
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 08:53 AM
Fixing crickets/chirping sound in Canada? i_4got CANADA 54 06-30-2013 01:48 PM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-05-2013 11:29 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
