Old 02-13-2013, 12:05 PM   #169
OrbitalEllipses
Drives: Attitude
Originally Posted by RallySport Direct View Post
Correct, these are the Brembo GT kit, 6-piston front and 4-piston rear. The exact specs are above
Thanks again!
Rick
That's what I get for loading the previous page.
Old 02-13-2013, 01:00 PM   #170
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
haha no worries
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 02-13-2013, 01:01 PM   #171
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
It might be a similar 6-pot but the rotors and pads are very different for the STi version.
Beyer Subaru is offline   Reply With Quote
Old 02-13-2013, 01:17 PM   #172
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Looks very expensive. I guess for those guys competing in time attack battles, this is ok. But with 200hp, talk about overkill lol. Do these ever reach temp?
Coheed is offline   Reply With Quote
Old 02-13-2013, 01:34 PM   #173
RallySport Direct
Yeah, they do cost a pretty penny, but the quality is there for sure, and would be great for someone looking for or needing brakes of this caliber. Overkill? You know it LOL. The Brembo GT kit will come with the Ferodo FM1000 brake pads, which are very close in specs to the Ferodo DS2500, so they should have an effective operating range around 60-1040°F. Even with pure street use, you can still use these pads every day. They sure like to dust, but other than that, we have been very pleased with the pads, and the brake kit as a whole.
Thanks,
Rick
Old 02-13-2013, 01:37 PM   #174
Coheed
Coheed's Avatar
Yeah, they do cost a pretty penny, but the quality is there for sure, and would be great for someone looking for or needing brakes of this caliber. Overkill? You know it LOL. The Brembo GT kit will come with the Ferodo FM1000 brake pads, which are nearly identical to the Ferodo DS2500, so they should have an effective operating range of 60-1040°F. Even with pure street use, you can still use these pads every day. They sure like to dust, but other than that, we have been very pleased with the pads, and the brake kit as a whole.
Thanks,
Rick
that's great man. Looks killer.
The Following User Says Thank You to Coheed For This Useful Post:
RallySport Direct (02-13-2013)
Old 02-13-2013, 05:52 PM   #175
djdnz
1337
Drives: 2013 BRZ WRB S/C
Keeping those white is going to be a giant headache, but man do they ever look good!
djdnz is offline   Reply With Quote
Old 02-13-2013, 06:24 PM   #176
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
is this the only kit they will be making for the twins?
Lee358 is offline   Reply With Quote
Old 02-13-2013, 06:56 PM   #177
RallySport Direct
HAHA they were already dirty right after the bed in procedure, and you are right, they do require a bit more time to keep them looking nice. Though on something like this, I don't mind at all
Thanks,
Rick
Old 02-13-2013, 06:58 PM   #178
RallySport Direct
I would imagine there will be more offerings here in the future, but we can get in the complete GT line up specific for these cars at the moment as there are a few options within these kits. Let me know if you have any questions.
Thanks,
Rick
Old 02-13-2013, 07:38 PM   #179
Nardi330
Nardi330's Avatar
Drives: 86
so the Kiwamis fit the calipers without the need for spacers?
thanks
Nardi330 is offline   Reply With Quote
Old 02-14-2013, 12:42 AM   #180
Coheed
Coheed's Avatar
Does the stock master cylinder move enough fluid for all those pistons? How is the pedal feel?
Old 02-14-2013, 12:42 PM   #181
RallySport Direct
Dem Rear Brakes
Kirill
RallySportDirect.com
The Following User Says Thank You to RallySport Direct For This Useful Post:
SkAsphalt (03-05-2013)
Old 02-14-2013, 01:34 PM   #182
RallySport Direct
Brembo does extensive research before releasing kits to ensure that the proportioning valve balance front to rear along with master cylinder sizes are proper for the kits to make sure these components do not need to be replaced with the kits.
As for pedal feel, they pedal travel is not effected in anything that could be felt as noticeable. Also being that the calipers are much stiffer then stock, the pedal does not need to be pressed as hard either to get the same "bite". However that can also be contributed to the fact that the compound of the pads is also much better then stock as well.
Overall there is not a single downside to this kit, other then a slight increase in sprung weight as you can imagine. But that is a given with any kit that used a caliper and brake system that is that much bigger then stock.
Kirill
