Old 01-27-2013, 01:35 AM   #15
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by lbroskee View Post
any ideas how this would work on an iPhone? curious if the magnets will effect it
It shouldn't affect solid state memory like the ones used in iPhones.
was385 is offline   Reply With Quote
Old 01-27-2013, 01:39 AM   #16
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
cool. now if only the magnet links actually worked....
lbroskee is offline   Reply With Quote
Old 01-27-2013, 01:47 AM   #17
was385
http://www.kjmagnetics.com/proddetai...prod=DX04B-N52
http://www.kjmagnetics.com/proddetai...prod=DX001-N52
Old 01-27-2013, 01:49 AM   #18
lbroskee
lbroskee's Avatar
2nd link is for inside the phone case correct?
The Following User Says Thank You to lbroskee For This Useful Post:
spgrizz22 (03-13-2013)
Old 01-27-2013, 04:31 AM   #19
lbroskee
lbroskee's Avatar
maybe the iphone is different but how does this affect turn by turn navigation? im hearing magnets can mess up iphone compass which cud affect turn by turn and curious how this is on android? im sure turn by turn is controlled the same way
Old 01-27-2013, 11:05 AM   #20
John_Duh
Thinker with everything
Drives: Celica TS
Interesting question ... would like to know the answer to this one aswel before attempting something similar.
John_Duh is offline   Reply With Quote
Old 01-27-2013, 11:17 AM   #21
Foobar
SLO NO MO
Foobar's Avatar
Came here to say this. You can mess up your phone's compass by placing magnets next to it for a prolonged period of time. Depending on your phone model, there may be a way to manually recalibrate it if so. I know for some (perhaps all?), you have to wave the phone in front of you parallel to the ground in a figure 8 pattern.
So if you start to notice your compass getting all wonky, give this a try.
The Following User Says Thank You to Foobar For This Useful Post:
lbroskee (01-27-2013)
Old 01-27-2013, 01:39 PM   #22
was385
Yeah, those are the magnets he referred to in the first post.
Old 02-01-2013, 03:50 PM   #23
Xdragonxb0i
Drives: ex500r
how is your phone holding up? i found that two 15lb Magnets, on the phone case and my GS3 is enough to hold it in place.
i also have a n52 magnet with 80lbs of force will cause that colored pixels on the lcd to mess up. but it doesnt cripple the phone.
also how do i take the bezel around the HU off without taking everything else out.
i discovered this by accident. but buy using two magnets i can make the the phone tilt.
Xdragonxb0i is offline   Reply With Quote
Old 02-02-2013, 12:15 AM   #24
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Wonder if the magnets do anything to the electronics like screw up the memory?
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 02-02-2013, 12:19 AM   #25
was385
Not if you're using flash memory like all smart phones. Just don't attach a traditional disc drive.
Old 02-12-2013, 11:19 AM   #26
was385
Well I ended up trying this. It works pretty well (better for my very light radar detector display), but if anyone else is going to do it, FIND SOMEONE OTHER THAN K&J!! I have never worked with a worse company in my life.
My entire order was like $8 for magnets and $5 for shipping. When I got it, the two thinnest magnets were cracked in half. I sent an email explaining the situation with a picture, and then asking for them to just replace them with a cheaper, thicker magnet that would hopefully stand up to the trip. I got a form response saying they weren't responsible for any damage after it left their facility. I responded saying that this was a simple fix and that I paid for four magnets and they shouldn't be fine with two showing up broken. And then I was ignored for a couple of days, so I finally sent another saying if they either didn't refund or replace, I would be disputing charges and negatively review them everywhere I could. Finally I got a response saying they were refunding the $1 cost of the actual magnets (but not shipping) that they very plainly blamed me for breaking. I will still be disputing charges and will never use these guys again.
Old 02-12-2013, 11:51 AM   #27
lbroskee
lbroskee's Avatar
Thanks for the heads up
Anybody know any other magnet dealers?
Old 02-12-2013, 12:15 PM   #28
was385
Sorry I can't help you with that. But yeah, they pretty much told me in one email how they are brittle and very breakable by nature, so they can't take responsibility, and then in another told me they know it's my fault because there is no way that only two magnets (even though the other two were much thicker) could be broken in a box.
Custom phone mount so26 DIY (Do-It-Yourself) Guides 20 11-07-2016 05:15 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 11:11 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 07:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 11:19 PM
Greddy Neodymium Magnetic Drain Bolt Subaru FRZ Scion FR-S Toyota GT86 any reviews? FRS-HHH Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 12-22-2012 05:55 AM
