Old 02-04-2013, 05:51 PM   #15
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Originally Posted by Tylub View Post
just got mine today... let the install begin! thanks for the diy
Good luck. A number of people have been PMing me to ask questions so if you have any dont be afraid to ask. Ill answer as best as I can.
FR-Shadow is offline   Reply With Quote
Old 02-04-2013, 08:27 PM   #16
FR-Shadow
FR-Shadow's Avatar
I posted a couple pictures after finally cleaning off the car. They are in my member thread.
Old 02-05-2013, 05:40 AM   #17
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
I couldn't find how you tapped into the cigarette lighter so I just tapped into my parking lights. a lot easier in my opinion and I can go stealth when I want to. I appreciate the DIY though, helped me a lot
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-05-2013, 09:15 AM   #18
FR-Shadow
FR-Shadow's Avatar
The cigarette outlet had a white wire coming out of it. When you look up there you should be able to see it. Ill update the diy to state that.
Old 02-05-2013, 09:59 PM   #19
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
Originally Posted by Honeydew View Post
Is it possible to still have the original Drl on in the headlights while having these on? Also would you be able to take some closer images of the light when lit up and off TY
that actually looks really nice @@!!!! where did you get these from? Thanks alot for the pics man!!
did you really have to quote all those images both times.
RAN94A is offline   Reply With Quote
Old 02-05-2013, 10:25 PM   #20
Alabang 86
Alabang 86's Avatar
Drives: GT86
wow, it looks really cold there.
nice job on the DIY.
and no, I won't hold you responsible.
Alabang 86 is offline   Reply With Quote
Old 02-07-2013, 11:18 AM   #21
FR-Shadow
FR-Shadow's Avatar
Originally Posted by sega_102 View Post
What do you guys thinking of tapping into the stereo power wire instead of the cig lighter? There'd be more room to work behind the stereo.
Then wouldnt it only turn on when you turn on your stereo?
Old 02-07-2013, 12:23 PM   #22
FR-Shadow
FR-Shadow's Avatar
Does the stereo ever really turn off though? I think power is always running to it.
I could be wrong though.
I dont know for sure, i have never tried. you can always tap into it and let us know. Then again it may be hard to run wire that far. You may have to purchase extra wire.
Old 02-12-2013, 02:07 AM   #23
howsouknow
Drives: 2013 Scion FR-S - Whiteout
Thanks for the DIY! I followed everything except I actually went with what Tylub did and tapped to the parking light wire. Works like a charm, and gives the option that I can turn it on or off.
SOrry bad ipod cam. :P
howsouknow is offline   Reply With Quote
Old 02-12-2013, 03:13 AM   #24
Tylub
Tylub's Avatar
@howsouknow looking good!
instagram @Tylub
Old 02-14-2013, 10:36 PM   #25
Arrakis
Arrakis's Avatar
Connecting the DRL to your parking lights....
Gentlemen,
When you chose the route of connecting these LED DRLs to your Parking lights, do you still have to use the LED Control Module that comes with the kit? Appreciate your help!
Arrakis is offline   Reply With Quote
Old 02-14-2013, 11:50 PM   #26
howsouknow
Originally Posted by Arrakis View Post
Gentlemen,
Yep, LEDs wont light up with out the LED Control Module aka "LED Driver." I used everything that came in the kit except for the extra T taps and Zip ties. Good luck!
Old 02-16-2013, 08:55 PM   #27
Arrakis
Arrakis's Avatar
LED DRLs successfully installed.
Thanks to F-T and all the helpful suggestions. I am very happy with the new DRL lights. I simply tapped the power from the turn-signal light and it worked out very well. I like their brightness a lot.
Old 02-26-2013, 12:09 AM   #28
Otterbrawten
Drives: Firestorm FR-S
Can someone tell me where the red wire from the LED's connects to, to use the stalk for your switch? I'd like to just connect it to on of the wires running from the headlights. Essentially is there a way to avoid running the final red wire into the car?
Otterbrawten is offline   Reply With Quote
