Old 02-12-2013, 12:33 AM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by robispec View Post
we will be logging pressures at the track this weekend with the stock system then put our overkill solution back on and relog to see how everything changes.
where are you logging pressure from?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 12:37 AM   #30
robispec
Drives: Black frs project
same location you are. I want to get some stock temps and pressures and then compare how our total solution compares
Robi
robispec is offline   Reply With Quote
Old 02-12-2013, 12:39 AM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Robi
Awesome. I'll test the sandwich plate before then. I came home from work and crashed tonight so I accomplished nothing
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 12:41 AM   #32
ayau
Drives: Some rust bucket
@Dave-ROR, mind sharing which gauges you have installed?
Old 02-12-2013, 12:45 AM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Defi Advance CR oil pressure and oil temp, although oil temp isn't in the oil yet. Will buy the adapter tomorrow and install that this weekend if I don't have to drive up to NC.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ayau (02-12-2013)
Old 02-12-2013, 12:50 AM   #34
ayau
Where do you have the gauges mounted?
Old 02-12-2013, 01:14 AM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A pillar. My most hated location. I'll post pics tomorrow.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 02:05 AM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why didn't you go with Prime Motoring solution, two in the dash?
Old 02-12-2013, 08:16 AM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
From my seating position I can't see those locations. Gauges would be 50%+ blocked
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Sportsguy83 (02-12-2013)
Old 02-12-2013, 11:05 AM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Oh also.. I'm hoping to not take a nap after work tonight and hopefully will do the following testing:
Tonight: Install the gauge sender sandwich plate after the oil cooler sandwich plate, install oil pressure there (and temp, or I may just move temp over to the location the pressure is currently read from). If I don't put the temp in the current spot in the block I'll reinstall the OEM plug there.
Tomorrow night: Move the gauge sender sandwich plate between the spacer and oil cooler sandwich plate if possible (lines are exact length more or less but hopefully they'll move up 3/4"), otherwise, remove oil cooler sandwich plate and drain the cooler or loop the lines.
Possibly Friday/weekend, bypass cooler and test pressure sender in both locations again, although I suspect the tests above (plus original/current config) will show the same data as this test.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 06:53 PM   #39
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Here ya go: http://www.ft86club.com/forums/showp...&postcount=210
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 09:43 PM   #40
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Really?! Gauge pods? Dave, you're killin' me!
PRO86 | WTCC | STL
Old 02-12-2013, 11:02 PM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Dude it's killing me. In that gauge thread I posted some options I'd prefer but no one has made them yet. I *HATE* a pillar pods. I will say if you want an A-Pillar pod the MSA one is nice since it's based on an OEM unit.
I'm waiting for a better solution though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 12:17 AM   #42
bpracer
Drives: Asphalt FR-S
Smaller lines increase pressure...thinking about water pipes coming to your house. Same thing.
No.
It is about resistance to flow over distance. Get a 2 foot long drinking straw and try to breath through it. Then cut that straw to 2 inches long and try to breath through it.
You want bigger diameter lines the longer the distance. The pressure drop over the length of the lines will be less.
I have -12 on my vintage race car, but for these cars I would think -10 is enough.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Oil Pressure Observations - Anyone else using a gauge? Dave-ROR Engine, Exhaust, Transmission 29 01-20-2014 12:56 AM
Tire Pressure Warning pinoyplaya Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-21-2012 10:55 PM
Oil Pressure Specification Captain Snooze Engine, Exhaust, Transmission 0 12-05-2012 06:44 PM
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 12:49 AM
