Old 02-10-2013, 09:45 PM   #1
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
Help, 17x9 +35 or +45 RPF1?
I am getting ready to order a set of 17x9 rpf1 for my BRZ but still can't decide on the offset. I am not a fan of "poke" so the +35 has me a little nervous. However, according to FT86Speedfactory's post, this offset leaves space for a BBK. Now for the +45, I'm concerned about spring/strut clearance. Also, a BBK probably won't work this setup seeing how tight the space is on the +35 wheels.
The BBK fitment isn't a deal breaker since I wouldn't have the money for that for a long while. Also, I'd be going with 245/40 tires with either offset.
Help me decide!
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 02-10-2013, 09:54 PM   #2
Supersonics
Supersonics's Avatar
Drives: 2013 BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=26257
Here's the 17x9+45, I think both look great but as you said, the +35 offset leaves room for a BBK in the future and also gives you a little more strut clearance.
Keep in mind that there aren't any 17x9+35's in stock usually as it is a special order wheel with a minimum of 10 sets. I only know of one vendor that has any coming in, and that will be a couple months or so before they get them. I believe the +45 is typically in stock as it is a standard offset in 5x100.
Supersonics is offline   Reply With Quote
Old 02-10-2013, 09:57 PM   #3
_F-R-S_
Drives: 13 whiteout scion frs
Go 255
_F-R-S_ is offline   Reply With Quote
Old 02-10-2013, 10:03 PM   #4
wgnzlz
wgnzlz's Avatar
Thanks for the quick responses. I think I found on vendor that has the +35 in stock. If they don't, I will probably go with the +45. Hopefully I won't have any inner clearance issues.
The Following User Says Thank You to wgnzlz For This Useful Post:
jkonquer (02-11-2013)
Old 02-10-2013, 10:27 PM   #5
whataboutbob
AutoX-10/10ths every run
If you have the factory struts on the front the +45 is going to be REALLY close, especially if you add neg camber using bolts. I got a set of the +35s from LSD Motorsports and have RCE springs/Whiteline camber bolts. Test fit the wheels and I have less than 1/2 in clearance (http://www.ft86club.com/forums/showp...3&postcount=26) between the strut and the inside edge of the rim in the front. If you end up going with coilovers you'll have more room and the +45 probably would be fine as far as clearance with the strut is concerned.
Build thread:Here
Old 02-11-2013, 01:38 PM   #6
wgnzlz
wgnzlz's Avatar
I just found a set of +35 in stock. It's decision time.
Old 02-11-2013, 01:40 PM   #7
p00mba
p00mba's Avatar
Drives: FR-S :)
^ where did you find this! lol i want a set too.
p00mba is offline   Reply With Quote
Old 02-11-2013, 01:57 PM   #8
leon78
leon78's Avatar
Drives: 13 Whiteout
I needed a 5mm spacer for front clearance with 17x9 +42 rota grids w/ 245 Z1's on stock suspention.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 02-11-2013, 05:45 PM   #9
RAYSSPL
Drives: bicycle
go with 17x9 +35
RAYSSPL is offline   Reply With Quote
The Following User Says Thank You to RAYSSPL For This Useful Post:
wrussi (05-29-2014)
Old 02-11-2013, 09:04 PM   #10
D1cker
Drives: B9 S4/ND2
+35 if you can get them. They cleared my fenders fine with only camber bolts
D1cker is offline   Reply With Quote
Old 02-11-2013, 09:06 PM   #11
wgnzlz
wgnzlz's Avatar
How much camber did you have to run?
Old 02-11-2013, 09:47 PM   #12
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
I think the +35's poke out too much for my taste...have you looked at the Mach V rims yet..I think they are a +42 and they look like they clear everything and work with BBK
Gearhd79 is offline   Reply With Quote
Old 02-11-2013, 09:53 PM   #13
wgnzlz
wgnzlz's Avatar
Any pictures of your setup?
Gearhd79 - I have considered the Mach V and still have not ruled them out.
Old 02-11-2013, 10:23 PM   #14
lightdir
Drives: 2013 Raven FRS 6MT
Get +35, it does poke a little till you upgrade your suspension though.
lightdir is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
