Old 02-11-2013, 02:50 PM   #15
OrbitalEllipses
Drives: Attitude
Ask Dave, he probably has some Yeungling in his fridge RIGHT now and I'm not about to share my bottle of Dogfish Head Miles Davis Bitches Brew with you.
Old 02-11-2013, 03:07 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Surprisingly I don't at the moment.. Leffe Brown, Sierra Nevada Pale Ale and some Henry Weinhard's Private Reserve currently.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2013, 03:16 PM   #17
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
So now that we're on to beer, is it safe to say your problems are solved?
BTW: when testing with the cooler bypassed and no bypassed, make sure you're testing at identical oil temps, most preferably identical-very-hot-oil temps.
PRO86 | WTCC | STL
Old 02-11-2013, 03:20 PM   #18
CSG Mike
CSG Mike's Avatar
:glare:
Yes, I agree with what sw20blahblah and Dave-ROR said. Yes, I also confused Dave-ROR. Yes, I would not buy you a beer.
(ノಠ益ಠ)ノ彡
I will not be sharing my allagash curieux either.
Old 02-11-2013, 03:34 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's safe to say I haven't touched the car since I posted this thread
Until I get to the track I won't see any high oil temps, they'll just be normal DD conditions. I want to either determine it's not an issue or fix it before I track the car
Using the second sandwich adapter I can add the temp gauge in (it's unplugged currently as I haven't dropped the pan to weld the bung in yet). Then I can swap the temp to the block and pressure to the sandwich plate and retest.
Depending on those results I can remove the oil cooler adapter and just run the spacer and gauge sender sandwich plate and get more data that way.
I'll try to add the additional sandwich plate in today. Accessing the pressure sender sucks so I might be too lazy to deal with that tonight. I don't rev high on the street so I can easily avoid the lower pressure above 7k. I'd love to see how another car compares to mine though. Someone else needs to install an oil pressure gauge
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2013, 04:15 PM   #20
rice_classic
In that Honda Tech thread you link I have a post on the 2nd page of it about the oil temp gauge/sender I use. I personally like getting temps from the oil pan because that's where the oil is after it's done its job being cycled through the engine. Most folks tap the pan but using a drainplug sender is massively easier.
I like my temps from the pan and my pressure from the block (just before the oil makes it to its intended location). Like what you and I are used to on the Hondas. My oil pressure sensor is on the back of the block on the D16.
Just a thought.
PRO86 | WTCC | STL
Old 02-11-2013, 04:42 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Just a thought.
That sensor would be nice actually if the Defi would use it.. sadly it doesn't. I wonder if someone makes a simple drain plug replacement with a tapped hole in 1/8"NPT for a sensor though.. will have to google
That or I'll weld a bung (or tap) the pan for temp which was the original plan.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2013, 04:51 PM   #22
xwd
I will install one next weekend if I get the gauge. I planned on using the extra spot on top of the block for the pressure and replacing the stock oil pressure switch with a temp probe.
I am a fan of using the pan for oil temp but I have a Fumoto valve and don't want to weld a bung in the pan. Greddy makes a 1/8 PT (not NPT) oil pan adapter.
Old 02-11-2013, 05:04 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I think the Defi sensor is technically 1/8" PT but 1/8" PT fits in the common US 1/8" NPT so I normally just look for 1/8" NPT. Never had a leak using that combo.
I'll look for that Greddy-likely-overpriced piece
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2013, 05:07 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
@dwx or others, do any of you know the oil drain plug thread pitch?
Thanks!
So far I've seen M16-1.5 and M20-1.5 on the internetz.
M16-1.5 I can easily find adapters from Greddy, Autometer, Glowshift, etc.. M20-1.5... not so much.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2013, 06:20 PM   #25
OrbitalEllipses
Drives: Attitude
Thanks!
I believe M16x1.5. M20x1.5 is the standard Subaru fitment, but I'm showing a GReddy drain plug for our models is M16x1.5.
I quote: "A couple of years ago (Late 2010) Subaru began using a new size engine drain plug on some models from an M20 to the smaller M16X1.5. If the wrench required to take off the plug is 14mm then your car needs the M16 plug."
Old 02-11-2013, 06:27 PM   #26
xwd
Yeah the BRZ plug is smaller than the older ones, it is 14mm.
Old 02-11-2013, 10:25 PM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks!
It is M16-1.5
http://www.ft86club.com/forums/showp...11&postcount=3
Originally Posted by sparks View Post
Subaru drain plug # 807016160, used on 2010 and up Outback/Legacy, 2012 Impreza, and BRZ. Uses gasket 803916010.
Originally Posted by Draco-REX View Post
If this is correct, then the BRZ oil drain plug is a M16x1.5. Fumoto valves F-108 and F-108N should work as those are for the '10+ Outbacks.
http://www.quickoildrainvalve.com/Se...lts.asp?Cat=40
Old 02-12-2013, 12:08 AM   #28
robispec
Drives: Black frs project
we will be logging pressures at the track this weekend with the stock system then put our overkill solution back on and relog to see how everything changes.
robispec is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Oil Pressure Observations - Anyone else using a gauge? Dave-ROR Engine, Exhaust, Transmission 29 01-20-2014 12:56 AM
Tire Pressure Warning pinoyplaya Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-21-2012 10:55 PM
Oil Pressure Specification Captain Snooze Engine, Exhaust, Transmission 0 12-05-2012 06:44 PM
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 12:49 AM
