Old 01-23-2013, 04:00 PM   #71
Racecomp Engineering
Swaybars are just one part of the system. Can larger ones be used to make a car faster? Yes, of course. Can you really screw things up? Yeah you can do that too. You have to look at the complete set-up when choosing bars and you're goals. OEM has it's own design goals.
Our bars are designed to be used as a set and I wouldn't recommend them for every single customer either. We do still sell the Whitelines.
- Andrew
ATL BRZ (01-23-2013), ill86 (01-23-2013)
Old 01-23-2013, 08:18 PM   #72
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Here's my inexperienced input: I didn't like the body roll that much so I got some Hotchkis front and rear sways. Doesn't make my daily any faster but I can definitely notice the difference. Do I need it? Not really, the car handles great already BUT I got a great deal and they're adjustable.
It's a cheap upgrade and really up to you. There's no "need" for any upgrades in a daily as the car handles awesome to begin with.
Books is offline   Reply With Quote
Old 02-10-2013, 10:49 PM   #73
Not4off
Not4off's Avatar
Drives: White Premium Manual
What about adding negative camber first?
I agree with the statement that the car handles pretty well right off the showroom floor. Certainly less body roll than a stock Miata. But once the car ventures onto the track...shouldn't the first mod be to increase negative camber particularly in the front which is practically zero from the factory? The idea being to improve the contact patch and save the outboard tire shoulder from premature wear. Once that is attended to...then better tires.
Is there anyone out there that has just added front camber bolts?
2013 BRZ Premium Manual
2009 Porsche Carrera S Manual
Not4off is offline   Reply With Quote
Old 02-10-2013, 11:07 PM   #74
fatoni
an alignment should always be the first "mod." if not to be more aggressive, simply to get a more precise alignment as the tolerances from the factory are pretty wide. that being said, a sway bar may or may not provide the visceral improvement over an alignment. with a low cog and little body roll, i dont know how much camber you need
Old 02-11-2013, 09:24 AM   #75
I agree that an alignment should essentially be done once off the showroom floor.
- andrew
Old 02-11-2013, 09:27 AM   #76
OrbitalEllipses
Drives: Attitude
- andrew
On principle I agree, but how many of us are installing alignment-altering items within the first few thousand miles? That's why I haven't bothered with one yet.
Old 02-11-2013, 10:01 AM   #77
An alignment should be done off the showroom floor....along with springs, bushings, wheels, tires, recaros, alcantera steering wheel, swaybars, etc.
Okay maybe not.
- Andrew
ill86 (02-11-2013)
Old 02-11-2013, 07:38 PM   #78
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I installed the Subaru camber/crash bolts before my BRZ hit 1500 miles. I usually do my own alignments though.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-26-2013, 06:19 AM   #79
nix
nix's Avatar
Drives: AVO BRZ
I have KW v3s with whiteline front caster bushings, subframe & diff inserts and whiteline 20/16mm adjustable sways. Very happy with the front end on the middle setting but the rear bar is a bit too durifto for me in mid/high speed.
nix is offline   Reply With Quote
Old 08-26-2013, 08:58 AM   #80
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
go softer
448hpsti is offline   Reply With Quote
Old 08-26-2013, 11:41 AM   #81
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
What type and size tire?
Tire pressure front and rear?
Alignment settings?
What do you consider mid/high speed?
My point? Too many variables. Suspension setup is both an art and science. But in the end, usually left up to the driver's / team's preference.
Thanks for sharing.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-26-2013, 02:54 PM   #82
frs10
Drives: tezla
my question goes back to OP, why do you need this for a DD?
unless ur DD consist of F&F racing in the streets?
frs10 is offline   Reply With Quote
Rear/Front Sway Bars on the BRZ mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-24-2013 05:54 PM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
Cusco Sway Bars? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-04-2012 05:31 AM
Perrin Rear Sway Bars at Redline360 Redline360 Brakes, Suspension, Chassis 0 06-28-2012 10:38 PM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
