Old 02-09-2013, 04:52 AM   #15
Xdragonxb0i
Drives: ex500r
whats a good dyno app for android? that i dont have to pay 200 for. The ones i downloaded are kinda glitchy and doesnt let me tweak the engine settings.
Xdragonxb0i is offline   Reply With Quote
Old 02-09-2013, 10:49 AM   #16
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by xjohnx View Post
This is the only one i have handy, it's of @FA20Club.com 's stg2 tune. However we've still got a bit of tuning to do (also worth noting, the road i use to datalog has a moderate incline). Toni has the log files from these runs and i've been waiting on an update to continue the process. Very happy so far. In the mean time, i'm headed out the door to the new local(ish) e85 station and will be flashing either Toni's or @Visconti 's e85 tune. maybe i'll get a datalog of that tonight, we'll see.
Great looking base for now working on everyones logs tomorrow
FA20Club.com is offline   Reply With Quote
Old 02-09-2013, 10:57 AM   #17
2forme
It's a good thing the stock O2 sensor isn't very accurate. Those readings look quite lean!
Old 02-09-2013, 11:02 AM   #18
xjohnx
Grip>Slip
xjohnx's Avatar
Nice. I'll get you some E85 logs this afternoon. I switched back over last night.
Old 02-09-2013, 12:26 PM   #19
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
This one has the best (least) TQ Dip so far. This is on Smoothing 3
I forgot to mention these are all tuned by Moto-East.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-09-2013, 02:36 PM   #20
xjohnx
Grip>Slip
xjohnx's Avatar
Simmons
Smoothing on 3 will make almost any torque dip look flat.
u/Josh (12-08-2013)
Old 02-09-2013, 02:40 PM   #21
xjohnx
Grip>Slip
xjohnx's Avatar
Here's an E85 run (red) from this morning compared to the pump gas run (blue) that I posted earlier. I'll have an E85 log from the other vendor I use later tonight to compare the two.
Old 02-09-2013, 03:21 PM   #22
Simmons
Simmons's Avatar
OK, here is on smoothing 1
Simmons
The Following 2 Users Say Thank You to Simmons For This Useful Post:
tripjammer (04-23-2013), xjohnx (02-09-2013)
Old 02-09-2013, 03:45 PM   #23
xjohnx
Grip>Slip
xjohnx's Avatar
Cool. I'm curious about how were you datalogging (running inside a VM?)/what gear the run was made in? Trying to figure out why your sample rate seems to be low compared to mine when i select show data points.
Edit: just saw it was a second gear run. Perhaps that's the difference in sample rate.
Old 02-09-2013, 09:38 PM   #24
Simmons
Simmons's Avatar
Yes they are done in 2nd gear. Using Ecutek for logging.
Simmons
Old 12-08-2013, 05:38 AM   #25
sw20kosh
Drives: 2013 Black FR-S
Resurrecting this to see if you guys have been able to see more changes from mods/tunes. Never knew about this software and if it can accurately determine power gained and lost...yum
If I understand it correctly, all you do is log your WOT pull in ecutek and open it up in Virtual Dyno?
Also, what did you put as the frontal area?
Old 01-12-2014, 11:47 PM   #26
Jay M
Drives: EVO 8 RS
Hello,
I helped Brad develop and test Virtual dyno. I just had him add the BRZ and the FRS to the cars list. It works with ECUTek & BRZedit logs as of now.
Virtual Dyno can be very accurate if used properly. I have tested it again and again on a real dyno. Here is some of that testing
Virtual Dyno Comparison
I have also written an how to on using virtual dyno correctly. Located here:
How to use Virtual Dyno Properly
Most of the charts in this thread need more smoothing.
Jay M is offline   Reply With Quote
Old 01-12-2014, 11:52 PM   #27
Jay M
Drives: EVO 8 RS
Simmons
Logs should be done in 3rd gear, not 2nd, to use VD properly.
Old 01-28-2014, 05:56 AM   #28
yoruck
Drives: ford fiesta st 150
is it possible to include oft log to Virtual dyno too,
i have some trouble to make it works.
tanks
yoruck is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Cheap Dyno? Sponsored Dyno? swift996 Mid-Atlantic 3 02-09-2013 01:29 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
Coverage of Toyota FT-86 online virtual reveal on Toyota Metapolis Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 10-27-2009 12:20 PM
