#323 | |
Turbo Mafia Presidente
Drives: U Mad?
Yep, but if it's the 5x100 from Subaru's parts bin then you'd know that the bearings on their 5x100 majorly suck when combined with wider and stickier tires. I've went thru a lot of them.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
#324 | |
Site Moderator
Drives: ichi 86 Project
My friend have sedan ver Impreza (GC6) and had stock wheels (16x7) w sticky tires for 9 yrs... close to 10 yrs (of course tires been replace every 1~2 yrs due to tracks/autox) and not til this yr he had to replace the bearing. vs me w 17x7.5 lil bit crazy offset first yr into crazy wide wheels, bearing went out... and next yr prob need to replace the again (4yrs since replaced it). |
#325 | |||||||
Do you know how a Centrifugal supercharger works? Properly designed? That don't make much sense to say that when the companies that produce S/C'ers have been doing it for decades. Quote:
Thanks for confirming what I already wrote. If it's a V8 then the difference is minor from S/C to turbo on the same applications. Everything you listed was American Muscle V8's. They are not Import Motors. Quote:
Like I said, I'm going to be running a set of 18x10 XXR's on the tC and XXR's are cheap. I would prefer a set of CCW's though. Eventually I will pick up some CCW's. |
#326 | ||
One wheel? And that wheel was JUST released. Quote:
Only a Roots Type S/C is instant boost. Not all of the S/C'ers are instant. |
#327 |
Drives: WRB BRZ limited 6MT
Actually it is still a rumor that it is using 5x100 bolt pattern. It's nowhere in the current specs...maybe we will find out for sure at the tokyo motor show...
#328 |
The 5x100 was by deducing what wheels have been used on the spy shots and display models/prototypes.
#329 |
Both are tC's. My boy's tC is a 2008 and mine is a 2006. Both are running GT3076R turbo's except I'm running a Tial SS housing on mine so my turbine is actually a little lighter than his in weight. But tuning makes a difference as well as the variation in the head design when made slight changes to the internals of the 2007+ tC's.
His ![]() Mine
#330 |
Drives: 2007 saturn ion(dd)
his
2014 FRS
#331 | |
Drives: Slowly
The combination of sticky tyres, high cornering forces and high brake temps kills those old wheel bearings. I had two sets of sets of hubs at one stage. One on the car and one getting new bearings. Went through 7 sets of bearings - using standard wheels. The move to 5x114.3 came with bigger hubs and bearings, but even the newer 5x100s are much better than the old ones. |
#332 | |
Prototypes are prototypes...there could be some out there with 5x100 and 5x114. |
#333 |
#334 | ||||
Drives: 2010 Evo X MR-T
and roots blowers have NO lag, make boost linearly, and DO give you a flatter tq curve boost for boost. this is a 2.0L ecotec (on 100 octane) ![]() and this is a RSX with a custom lysholm kit (@16.4 psi) ![]() find me a turbo 2.0L 4 cyl that makes that much power with a flatter tq curve. who said anything about power?
#335 |
Site Moderator
Drives: Stuff
The race car used 5x100. It will be 5x100.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#336 | |
Site Moderator
Friend's GC6 on track Hoosier R series, summer Potenza RE series and winter some kind of Pireilli. Track close to dozen time in summer plus auto-x half dozen times, 3~4 times in winter and hub lasted him 9yrs (close to 10 yrs)... & MMP track isn't slow corning and it require pretty hard braking. |
| Tags |
| fr-s trd, fr-s trd parts, frs trd, ft-86 trd, ft-86 trd parts, scion fr-s trd, scion frs trd, toyota ft-86 trd, trd fr-s, trd frs, trd ft-86, trd scion fr-s, trd scion frs, trd toyota ft-86 |
| How much would custom parts be? | LexusFman | Other Vehicles & General Automotive Discussions | 10 | 07-23-2012 12:59 AM |
| How do you buy aero kit / TRD parts? | scwewywabbit | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 03-17-2012 10:45 PM |
| Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 06:17 PM |
| after market parts | serchmarc | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 05-31-2011 08:18 PM |
