Old 02-08-2013, 12:24 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Virtual Dyno ?
Is using Virtual Dyno a good tool to compare differnt tunes?
How far off is it?
I have been comparing differnt logs that I have from all the different tunes. It seems to compare to the butt dyno, if it feels better it usualy looks better on the virtual dyno.
Here is my last tune.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-08-2013, 12:50 PM   #2
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I have Dynolicious on my iPhone, it was like $13.00. I bought it after reading a review in one of the many car magazines I get and they basically said its not perfect, but for the price its damn close. I find it to be pretty fun, doesn't really show small differences from things like a pulley but for $13 its worth it.
Flat Black VW is offline   Reply With Quote
Old 02-08-2013, 01:08 PM   #3
2forme
You could always dyno it and compare. It really depends on the road. I've had it be fairly accurate on level road, but any small incline/decline/potholes will cause disruption.
Old 02-08-2013, 01:16 PM   #4
Simmons
Simmons's Avatar
I always use flat smooth roads when I log.
I am trying to save th dyno money aand use this toffind the best one first.
Simmons
Old 02-08-2013, 01:31 PM   #5
2forme
Simmons
Yea, I do too, but bumps will register on the virtual dyno lol.
Old 02-08-2013, 01:35 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
VirtualDyno is a great tool, if you take it for what it is. Increases or decreases in power will appear and give you a good idea of what is happening, but the numbers will not match up perfectly to a chassis dyno,
Consistency with virtual dyno is important. The less variables changing, the better. Always try to use the same gear. The same stretch of road. Etc.
Old 02-08-2013, 02:20 PM   #7
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Most of the phone dyno's are actually pretty good, but require a very accurate vehicle + driver + fuel weight.
b.e is offline   Reply With Quote
Old 02-08-2013, 04:06 PM   #8
Simmons
Simmons's Avatar
I use the same road every time, and the same gear.
Simmons
Old 02-08-2013, 05:43 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Simmons
Then it should give you a decent idea of what's happening. also note that things such as full tank vs empty tank, passenger vs no passenger, ambient outside temperature all can impact the results.
It's still a great tool though.
Old 02-08-2013, 05:56 PM   #10
Simmons
Simmons's Avatar
Definetly, I enter the weight of the driver and the car. Temperature does have an effect on these cars.
Do you have any of your results?
Thanks,
Simmons
Old 02-08-2013, 06:52 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks,
Simmons
This is the only one i have handy, it's of @FA20Club.com 's stg2 tune. However we've still got a bit of tuning to do (also worth noting, the road i use to datalog has a moderate incline). Toni has the log files from these runs and i've been waiting on an update to continue the process. Very happy so far. In the mean time, i'm headed out the door to the new local(ish) e85 station and will be flashing either Toni's or @Visconti 's e85 tune. maybe i'll get a datalog of that tonight, we'll see.
FA20Club.com (02-09-2013)
Old 02-08-2013, 08:56 PM   #12
wparsons
wparsons's Avatar
If you're using the same road, same direction, same gear every time it should be pretty accurate to itself. It might not compare well to a chassis dyno, but it will definitely show you how mods are reacting to your car compared to previous runs.
flickr
Old 02-08-2013, 09:12 PM   #13
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
virtual dyno is as accurate as you set it up, mine is exactly the same as a dynojet. Be sure to use the same road, going in the same direction every time, use smoothing level 3, and clip the last time stamp off the end to make sure you are not getting false rpm reading caused by shutting the logger.
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 02-08-2013, 10:48 PM   #14
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Virtual dyno is very close to reality if you put all the right numbers, temp,weight, atm pressure. Also if you wanna compare be sure to always have your tank full before making a run otherwise you will have weight reduction.
I'm doing some test, to compare the differance in power as when you just flash the car and 2 weeks after' power. You will be surprise by the results.
I will post that as soon as I have the data, I think some people won't be happy.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Cheap Dyno? Sponsored Dyno? swift996 Mid-Atlantic 3 02-09-2013 12:29 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
Coverage of Toyota FT-86 online virtual reveal on Toyota Metapolis Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 10-27-2009 11:20 AM
